Local Time 05:35 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : picomite mmbasic howto
Frank N. Furter
Posted: 01:02pm 08 Oct 2025
Hi Volhout,
our intern would like to use the MLX90614 for a measurement. However, with your code (MLX90614-DCI_V02.zip), we are getting values that deviate by approx. 3°C (IR values too low, T ambient too high). Do you have any idea why this might be?
Thanks!!!
Frank
Posted: 01:55pm 08 Oct 2025
Hi Frank,
The inside of the sensor (with it's DSP) could be few degrees warmer than actual ambient. I see 1-2 degrees difference.
The IR value being different is (I expect) caused by the emission coeficient of the surface you are probing. I have several sensors here at my desk that are within 1 degree C when pointed at a rough black surface at controlled temperature. Shiny surfaces should be avoided. On unknown surfaces I add a black sticker before measuring.
You can make a suitable surface with a piece of kitchen alu foil that you blacken with smoke or charcoal.
Another reason for the lower value could be that the emissive surface is not lighting the pixel sensor completely. Calculate the (6 degrees opening angle) surface you are viewing, and the size of the hot surface/component. If you are observing a small spot, the camera lens should be right above it, and not at 20mm distance.
I think the program you are using has some compensation value hidden somewhere that I took out in later versions.
My latest version is here (for Game*Mite)
MLX90614
P.S. if you know the emission coeficient, you can program it's value in the sensor (register 4).
Edited 2025-10-09 00:01 by Volhout
Frank N. Furter
Posted: 08:37am 09 Oct 2025
Hi Volhout,
thank you very much for your link!
The only difference I can see is the averaging function you have implemented in the new version.
We have now compared the values with an MLX90640 and a commercial IR thermometer – there are actually no significant differences...
Frank
Frank N. Furter
Posted: 07:05am 13 Oct 2025
Hi Volhout,
have you evver changed the emissivity factor? I can't figure out from the data sheet what I need to enter where...
Frank
Posted: 09:05am 13 Oct 2025
Hi Frank,
For the MLX90614 I did never change the emissivity factor. I saw it was register #4, but I have not got into it to find the format (fixed point/floating point/divider ratio).
If you look at the datasheet for the MLX90641, you see that they pack data in these registers in the strangest ways. I had to decode the formats for my thermal camera. Maybe the format is the same as in the MLX90641 (or 90621 for that matter).
Frank N. Furter
Posted: 09:17am 13 Oct 2025
Yes, it seems very unclear how this factor is created and transferred.
Thank you for your reply!!!
Frank
