Local Time 00:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Is this too silly for MMBasic or is it useful?
Posted: 10:04am 09 Mar 2023
Have a play with this and see what you think - VGA only for test
PicoMiteVGA.zip
for normal string input and quoted DATA statements (but not unquoted DATA strings)
Implements
Escape sequence Hex value in ASCII Character represented
\a                           07                 Alert (Beep, Bell)
\b                           08                 Backspace
\e                           1B                 Escape character
\f                           0C                 Formfeed Page Break
\n                           0A                 Newline (Line Feed); see notes below
\r                           0D                 Carriage Return
\q                           22                 Quote symbol
\t                           09                 Horizontal Tab
\v                           0B                 Vertical Tab
\\                           5C                 Backslash
\nnn                       any                The byte whose numerical value is given by nnn interpreted as a decimal number
\xhh                       any                The byte whose numerical value is given by hh… interpreted as a hexadecimal number
e.g.
s$="\qHello world\q"
Edited 2023-03-09 20:10 by matherp
Posted: 04:06pm 09 Mar 2023
I think this is a much-needed feature however implemented (and however broadly implemented across MMBasic platforms). The "\" option immediately above looks good to me.
Bleep
Posted: 10:34am 10 Mar 2023
Hi Peter,
Yes please I like this feature. :-)
Using the above install I'm getting an "Error : Not enough memory" after running a small mode 2 program, and then going into edit it.
PicoMiteVGA MMBasic Version 5.07.07b26
OPTION SYSTEM I2C GP22,GP15
OPTION COLOURCODE ON
OPTION KEYBOARD UK
OPTION DISPLAY 30, 53
OPTION SDCARD GP5, GP2, GP3, GP4
OPTION AUDIO GP6,GP7, ON PWM CHANNEL 3
OPTION RTC AUTO ENABLE
OPTION DEFAULT FONT 7, 1
> memory
Program:
  1K ( 0%) Program (35 lines)
 97K (100%) Free
RAM:
  0K ( 0%) 0 Variables
  2K ( 1%) General
124K (99%) Free
> edit
> clear
> EDIT
If I then change to mode 1 edit works fine, Any ideas?
Regards, Kevin.
Edited 2023-03-10 20:37 by Bleep
Posted: 11:02am 10 Mar 2023
Need more info - program?
Can't replicate with trivial test
Bleep
Posted: 12:09pm 10 Mar 2023
' Bubble Universe
MODE 2
Dim Float u,a,p,q,t,v=0, x=0
Dim Integer g,b,i,j,c(51),d(51),e(51),n(51),nn
Dim Integer f(13,41),l(13,41),m(26,41),dd,cc
Const w=MM.HRes/2, h=MM.VRes/2
Const r=(2*Pi)/235, o=h/2
CLS RGB(black)
t=Rnd*10:Math set 1,e()
t=1
nn=Peek(varaddr n())
dd=Peek(varaddr d())
cc=Peek(varaddr c())
For g=0 To 41
For b=0 To 51
  n(b)=RGB(g*6,b*5,128*(g+b>30)*(g+b<60))
  If g<26 And b<13 Then n(b)=RGB(0,128,0)
Next
Memory pack nn, Peek(varaddr m(0,g)),52,32
Next g
Inc t,0.01:g=0':Print Timer:Timer =0
For i=50 To 255 Step 5
b=0:a=r*i
Memory unpack Peek(varaddr f(0,g)),cc,52,16
Memory unpack Peek(varaddr l(0,g)),dd,52,16
Box c(),d(),e(),e(),0,,0
For j=50 To 255 Step 4:u=Sin(i+v)+Sin(a+x):v=Cos(i+v)+Cos(a+x):x=u+t:c(b)=w+u*o:d(b)=h+v*o:Inc b:Next
Memory unpack Peek(varaddr m(0,g)),nn,52,32:Box c(),d(),e(),e(),0,,n()
Memory pack cc,Peek(varaddr f(0,g)),52,16
Memory pack dd,Peek(varaddr l(0,g)),52,16
Inc g
Next i
Posted: 01:32pm 10 Mar 2023
Still works for me after running your program
Bleep
Posted: 03:27pm 10 Mar 2023
Hi Peter,
Just done a flash wipe & re install, I then put all the options back as above, loaded the same program from the SD card, ran it, ctrl-C out F4 to edit and am still getting the Error : Not enough memory
If I go to mode 1 and then edit works fine, but then going back to mode 2 and then edit same error.
Was going to try resetting all options then re-introduce them 1 at a time, but doing option reset locks up the Pico. powering off and on and they are still all there.
So did a flash wipe and re install.
didn't put any options back and it happened.
So all I have now is
OPTION KEYBOARD US
OPTION DISPLAY 20, 40
> RUN   (Ctrl-C out)
> EDIT
This is the program, even smaller.
'mandelbrot
'inspired by Matt Heffernan s 8-BIT BATTLE
'https://www.youtube.com/watch?v=DC5wi6iv9io
'for PicoMite is a Raspberry Pi Pico running the free MMBasic interpreter.
'2022 by M. Herhaus
'2022 adaptation for picomiteVGA by Volhout
'clear screen, home and cursor off
Dim Integer DX,DY,py,px,i
Dim Float p,q,x,y,xy,xz,xt
MODE 2
CLS
'read colours
Dim color(15)
For i=0 To 15
Read color(i)
Next i
'MANDELBROT
Timer =0
' max x and max y
DX=32:DY=22
For py=0 To DY-1
For px=0 To DX-1
 xz=px*3.5/DX-2.5
 yz=py*2/DY-1
 x=0
 y=0
 For i=0To 14
   p=x*x: q=y*y: If p+q>4 Then Exit For
   y=2*x*y+yz: x=p-q+xz
 Next
 Box px*10,py*10,10,10,1,0,color(i)
Next
Next
Print @(10,230) "time = ";Timer;
Do :Loop While Inkey$=""
End
'indexing the colors
Data RGB(white),RGB(yellow),RGB(lilac),RGB(brown),RGB(fuchsia),RGB(rust)
Data RGB(magenta),RGB(red),RGB(cyan),RGB(green),RGB(cerulean),RGB(midgreen)
Data RGB(cobalt),RGB(myrtle),RGB(blue),RGB(black)
I have no idea why you can't reproduce, are you using the same zip file installation from the top of this page? Hopefully you can reproduce now.
Regards, Kevin.
Edited 2023-03-11 01:39 by Bleep
Posted: 05:45pm 10 Mar 2023
  Quote  OPTION DISPLAY 20, 40
How are you getting this? There is something you aren't telling me
Try this although I'm not aware I have made any relevant changes
PicoMiteVGA.zip
Edited 2023-03-11 03:55 by matherp
Bleep
Posted: 10:09pm 10 Mar 2023
Hi Peter,
Honest I'm not, that option appears when I or a program sets mode 2.
> option list
OPTION KEYBOARD US
> mode 1
> option list
OPTION KEYBOARD US
> mode 2
> option list
OPTION KEYBOARD US
I'll try the new one, probably tomorrow now.
Regards, Kevin.
Bleep
Posted: 10:20pm 10 Mar 2023
Hi Peter,
Ok the new zip does not give me the not enough memory error, but I do still get the OPTION DISPLAY 20, 40 when using mode 2.
> option list
OPTION KEYBOARD UK
> mode 2
> option list
OPTION KEYBOARD UK
I'm fairly certain it has always done this, certainly when I set OPTION LCDPANEL CONSOLE 7 I then get different Option displays, like OPTION DISPLAY 30, 53 in Mode 2 and OPTION DISPLAY 60, 106 in mode 1.
Thanks Kevin.
Edited 2023-03-11 08:35 by Bleep
Posted: 10:52pm 10 Mar 2023
  Quote  I'm fairly certain it has always done this, certainly when I set OPTION LCDPANEL CONSOLE 7 I then get different Option displays, like OPTION DISPLAY 30, 53 in Mode 2 and OPTION DISPLAY 60, 106 in mode 1.
+1
