Local Time 00:59 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PICOMITE: Can you read them?
Posted: 08:48am 07 Feb 2023
  Grogster said  Lets be honest and have a wee comparison here - even the PIC32 chips can be read like that, to create a HEX file that contains MMBASIC and the program code, provided the chip has not been copy protected.  I've never done that(copy protected them) with the MM2 series of chips
But the point is to use the PIC32's protection feature.
It's really tough to beat.
Posted: 08:53am 07 Feb 2023
Just to make it less obvious in your code it might be an idea to do a convoluted comparison like:
If MM.INFO(ID) AND NOT(&H6A) THEN ...
It would be less obvious to the casual observer than something like:
IF MM.INFO(ID) = 3124 then
I'm not saying that either of these would work, it's just an idea.
You could even have a VAR SAVE value or two that you do a logical operation on with the ID to get something important.
I think that if you want something like the PIC32's protection then you'll have to use a PIC32, not a RP2040 with a non-protected flash chip. The latter simply isn't designed for secure data, the PIC32 is (it's intended for embedded processing).
Edited 2023-02-07 18:57 by Mixtel90
Posted: 09:00am 07 Feb 2023
This security issue is the same for all XIP (execute in place) processor chips with no in-built flash memory - same for the ESP chips. It is just a limitation that users have to accept or not.
Posted: 01:42am 08 Feb 2023
Understood.
This thread has come up with some very clever ideas though, so thanks for all the posts.
Posted: 01:03pm 08 Feb 2023
  JohnS said  [...] use the PIC32's protection feature.
with the MX170 version of MMbasic, i take it this is not 'turned on' by default. is it possible to enable the protection after the MMbasic firmware has been loaded onto your MX170, and once enabled is it still possible to edit basic programs, save variables, change options, etc?
rob   :-)
Posted: 02:11pm 08 Feb 2023
rob   :-)
Have a look at the PIC32 device config words - Section 32 of the PIC32 docs - DEVCFG0, DEVCFG1, DEVCFG2, DEVCFG3, especially bits CP, BWP & PWP.
I think by default all PIC32 MMBasics leave protection off.
I'm doubtful they can be turned on at runtime but they need to go from 1 to 0 so maybe?
Quite easy to set the right values before programming the chip, though (worst case, edit the HEX file).
I don't know whether you'd be able to make the changes you asked - try it :) - but probably OK as it's the running code that is doing stuff whereas these settings are to prevent outside stuff doing much other than a chip erase/reprogram.
Edited 2023-02-09 00:14 by JohnS
