Forum Index : Microcontroller and PC projects : Practical Electronics PicoMite display problems
It is not if you are running V5.07.06 or above |
Over here he says he is. Worth printing mm.ver I think... John |
@JohnS - you're right. this display board is using v5,7,04. updated to v5,7,06 and sd card is "b:/" I should have tested my other display board which is updated. |
It's good to hear it's working :) John |
