Local Time 02:42 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WAVE recording with Picomite possible???
Nimue
Posted: 08:21am 13 Sep 2022
  phil99 said   Better still would have been to scan all the data to find the average number of samples for long and short elements then decode based on that. It just seemed too much effort for something that had no practical value.
^^ This is important - for me, this is educational only, not attempting to recreate a better way of encoding / decoding data.  I'll be happy with the simplest, slowest speed process that can demonstrate encoding a BASIC listing, saving as audio and then decoding.
I almost want it to be unreliable and slow as it gives me the opportunity to discuss how and why things need to improve.
I see mentioned punch cards -- we had discussed this -- card with eight punched holes and pairs of LEDs / LDRs to read thing in bitwise / bytewise ---
Some really interesting suggestions here.
Pesky day job getting in the way!!
N
Posted: 08:36am 13 Sep 2022
About the LM567
It is a PLL tone detector. It has a variable oscillator with centre frequency (set by component values) and a build in tuning range for that frequency, the "lock range".
From the datasheet: the maximum lock range for the single LM567 is 14% (typical, maximum 16%). This means that you need worst case 1/0.14=7 cycles to achieve lock, and that is reflected in the attached graph (from the datasheet).
This means that you may have a good chance of detecting 8 cycles of 2400Hz (not guaranteed, but possible), but 4 cycles of 1200Hz is far below what a single LM567 can do. If you narrow the range, it takes even more cycles to lock (detect).
There is an application note where they use 2 LM567's each with a 14% lock range, to expand the lock range of the set.
This circuit diagram should fulfill your needs for the 1200Hz detector for FSK cassette tape. Ue is the input (20mV..200mV input voltage, Ua is the digital output, when powered from 5V (Ub) this circuit will output 5V logic).
Good luck...
P.S. NE567 and SE567 and LM567 are compatible.
Edited 2022-09-13 18:40 by Volhout
Nimue
Posted: 09:28am 13 Sep 2022
  Volhout said  About the LM567
DOH!! Using x2 never dawned on me.
So, if I use one set up for 1200Hz(1) and one for 2400Hz(0)  - with 10 cycles per "bit" with 10 cycles of "silence" between each 1 and 0   -- granted I've just made my own encode / decode protocol, but about as simple as it can be.
I could "detect" each on a separate pin or OR (NOR? as it goes low) them together....
Got to do the day job now (sigh).
N
Posted: 10:06am 13 Sep 2022
I think the silence in between is not needed. Just 1200 and 2400.
In advance of any tone there will be silence.
If you route both detectors to separate pins you can detect
"11" = silence
"01" = 1200Hz
"10" = 2400Hz
"00" is fault
Edited 2022-09-13 20:07 by Volhout
Nimue
Posted: 10:08am 13 Sep 2022
  Volhout said  I think the silence in between is not needed. Just 1200 and 2400.
"11" = silence
"01" = 1200Hz
"10" = 2400Hz
"00" is fault
Stop posting interesting things....
Trying to do paid work!!
Awesome -- sounds like a plan.
N
Frank N. Furter
Posted: 01:02pm 13 Sep 2022
@Volhout:
Thank you very much! Can you tell me where you got this "Bild 8"?
Frank
Posted: 01:31pm 13 Sep 2022
Funkamateur
Frank N. Furter
Posted: 06:19am 14 Sep 2022
@Volhout:
Frank
Posted: 07:11am 17 Sep 2022
  Nimue said  Hi Frank
Interesting question.
Currently I'm playing with variations on Manchester encoding to save bits / bytes as generated by Play Tone -- have figured out how to encode / save as audio tones.  Can generate individual characters a bit like morse code.
Reading / Decoding is another thing all together and still potching at that.
My use case is to save BASIC to cassette tape (as an educational demo)  -- discovered on Friday that out of a class of 25 13 year olds, not one of them had seen / handled a cassette tape and no one had any idea of the linear nature of the medium.   Amazing what we (50 yos) take as assumed knowledge.
N
A rainy day in paradise so:
Kansas City tape read/write
I stayed with Basic rather than PIO or CSUB to make it easier to follow what is going on.
It does mean that the sending side has to leave gaps between characters to allow for processing time.
' KCTS TassyJim Sep 2022
 OPTION EXPLICIT
 OPTION DEFAULT INTEGER
 DIM bits(10), message$
 DIM FLOAT rxd(200), bt!
 DIM starttime!, midtime!
 DIM n, done, k$, char$
 CONST bit_time = 3.1      ' should be 3.33 less processing time.
 CONST char_timeout = 37.0 ' one character takes ~36mS
 CONST char_time = 12.0    ' at 250k CPU it takes ~10 mS to process one character
 CONST bit_choice = 1.2    ' this is the time for two cycles half way between 1200 and 2400 Hz
 CONST dir_mode = 1        ' 1 = sending, 0 = receiving
 IF dir_mode THEN ' we are sending text
   message$ = "Hello world"
   sendtxt message$
     PAUSE 2000
   DO
     k$ = INKEY$
     IF k$ <> "" THEN
       sendtxt k$
     ENDIF
   LOOP
 ELSE       ' we are receiving text
   SETPIN gp15, INTH, startrec
   SETPIN gp14, DOUT ' used for timing on the CRO
   DO
     IF done = 1 THEN ' we have finished receiving a character
       done = 0
       PIN(gp14) = 1 ' used for timing measurements
       char$ = recchar$()
       PRINT char$;
       SETPIN gp15, INTH, startrec ' arm the interrupt ready for the next character
       PIN(gp14) = 0
     ENDIF
   LOOP
 ENDIF
' routines used for receiving and decoding KCTS
' parse the array of received timing and extract the 8 bit byte
FUNCTION recchar$()
 LOCAL b, char_asc
 bt! = bit_time/1.8 ' take the first sample shortly after half way throug it.
 b = 0
 FOR n = 1 TO 100
   IF rxd(n) = 0 THEN : EXIT FOR : ENDIF
'print str$(n,5);"  ";str$(rxd(n)*1000,6,1);"  ";str$((rxd(n)-rxd(n-1))*1000,6,1)
   IF rxd(n) > bt! THEN
     IF (rxd(n)-rxd(n-2)) < bit_choice THEN ' we average over two cycles
       bits(b) = 1
     ELSE
       bits(b) = 0
     ENDIF
' print bits(b), (rxd(n)-rxd(n-2)), b,  bt!
     bt! = bt! + bit_time
     INC b
   ENDIF
 NEXT n
 FOR n = 8 TO 1 STEP -1
   char_asc = (char_asc << 1) + bits(n) ' lsb received first
 NEXT n
 MATH set 0, rxd()   ' finished with it so clear the array
 recchar$ = CHR$(char_asc)
END FUNCTION
' arm the interrupt and timeout
' reset the data array pointer
SUB startrec
 done = 0
 n = 1
 TIMER = 0
 SETTICK char_timeout, stoprec,1
 SETPIN gp15, INTH, getdata_int
END SUB
' disable interupts and set the done flag
SUB stoprec
 SETPIN gp15, OFF
 SETTICK 0,0,1
 done = 1
END SUB
' get the time of the next cycle and advance the counter
SUB getdata_int
 rxd(n) = TIMER
 INC n
END SUB
' these two subs are all thats needed to send text
SUB sendtxt txt$
 LOCAL n
 IF LEN(txt$) > 0 THEN
   FOR n = 1 TO LEN(txt$)
     sendchar MID$(txt$,n,1)
     PAUSE char_time
   NEXT n
 ENDIF
END SUB
SUB sendchar ch$
 LOCAL n
 bits(0) = 0                      ' start bit
 FOR n = 1 TO 8
   bits(n) = (ASC(ch$) >>(n-1)) AND 1 ' bits sent lsb first
 NEXT n
 bits(9) = 1                      ' 2 stop bits
 bits(10) = 1
 FOR n = 0 TO 10
   PLAY TONE 1200*(bits(n)+1),1200*(bits(n)+1) ' 0 = 1200, 1 = 2400
   PAUSE bit_time
 NEXT n
 PLAY STOP
END SUB
You may have to adjust the pins used to suit your setups.
Tested with the picomites running at 250k
A bit_time of 3.0 for sending and 3.1 for receiving is reliable on my setup.
Set the CONST dir_mode to 1 for sending and 0 for receiving.
I used the simple audio filter so there was some 44kHz noise.
No effort has been made to streamline any of the functions.
The only additional IC is a LM324 op amp configured as a comparator with a bit of hysteresis. It runs happily on 3.3V, noise and all.
