Local Time 06:48 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Scrolling Graph on ILI9341 to slow on armmite, picomite and upython
ztoti
Posted: 04:48am 08 Jan 2022
Hi Vampire05,
I like you video, could you please share the code. Thank you
Vampire05
Posted: 05:41pm 09 Jan 2022
Sorry for the late response! Here is the code:
CLS
Dim integer dat
Dim integer dat2
Dim integer buf(320)
Dim integer buf2(320)
SetPin 31, ain
SetPin 32, ain
SetPin 34, ain
SetPin gp0, dout
SetPin gp1, dout
SetPin gp2, din
SetPin gp18, din, pulldown
Text 100, 5, "Universal Plotter", lt
Line 30,50,30,222,2,RGB(yellow)
Line 30,220,320,220,2,RGB(yellow)
Text 27,225, "0"
Text 70,225, "50"
Text 120,225, "100"
Text 170,225, "150"
Text 220,225, "200"
Text 270,225, "250"
Text 30,215, "0" ,rm
Text 30,165, "50",rm
Text 30,115, "100",rm
Text 30,65, "150",rm
Line 32, 165, 320, 165, 1, RGB(grey)
Line 32, 115, 320, 115, 1, RGB(grey)
Line 32, 65, 320, 65, 1, RGB(grey)
temp1
If Pin(gp18) = 1 Then
 shift_draw_buf
Else
 clear_aquire_buf
EndIf
p= Cint((Pin(32)*10000)/9)-370
If p <0  Then p=0
Pause p
Sub temp1()
 Pin(gp1) = 1
 Pause 200
 Pin(gp1) = 0
 Pin(gp0)=1: Pin(gp0)=0
 temp_raw = 0
 For i=12 To 1 Step -1
   Pin(gp0)=1
   b=1
   For j=2 To i
     b = b*2
   Next j
   so=Pin(gp2)
   temp_raw = temp_raw + (b*so)
   Pin(gp0)=0
 Next i
 Print " TEMP: ", temp_raw, temp_raw*0.25
 Pin(gp0) = 1
 Print Pin(gp2)
 Pin(gp0) = 0
 Pin(gp1)=1
Sub clear_aquire_buf
 For i=32 To 320
   Pixel i, buf(i), RGB(black)
   Pixel i,buf2(i), RGB(black)
   buf(i) = 230 - Cint(Pin(31)*50)
   buf2(i) =230 - Cint(Pin(34)*50)
   Pixel i, buf(i), RGB(green)
   Pixel i, buf2(i), RGB(magenta)
 Next i
Sub shift_draw_buf
 dat = 230 - Cint(Pin(31)*50)
 dat2 = 230 -Cint(Pin(34)*50)
 For i=32 To 320
  Pixel i, buf(i-1), RGB(black)
  Pixel i, buf2(i-1),RGB(black)
  buf(i-1) = buf(i)
  buf2(i-1)= buf2(i)
  Pixel i, buf(i),RGB(green)
  Pixel i, buf2(i),RGB(magenta)
 Next i
   buf(320)=dat
   buf2(320)=dat2
It is very dirty at the moment! I have now added a second channel and support for type-k themperature sensors (max6675). the next thing i want to add is the current sensor ina219 and support for uart. Then i am able to plot / visualize different Data like voltage, current, power, temperature and UART Data. All on two channels! After that i will add printer support for cheap chinese Thermal printer to print the plots :-)
Tinine
Posted: 06:49pm 09 Jan 2022
@Vampire05
Just curious; have you made any other speed comparisons between upython and MMBasic?
Vampire05
Posted: 07:10pm 09 Jan 2022
no, I have not done that. I prefer mmbasic even if I have to do a lot with python professionally. When it didn't work in basic, I had the hope that micropython/circuitpython is faster. Since it was not faster there right away, I switched back to mmbasic.
Another option would have been a compiler language (bascom).
ztoti
Posted: 06:34pm 10 Jan 2022
@Vampire05,
Thank you very much.
Vampire05
Posted: 09:11pm 10 Jan 2022
You are welcome ;-)
