Local Time 07:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite MMBasic V5.07.02 betas
fred777
Posted: 07:54pm 19 Dec 2021
Hello,
I've just hooked up the picomite's COM1 Port and get strange results.
This simple programme
' Print to COM1
SetPin GP0,GP1,COM1
Open "com1:9600" As #5
Bla:
Print #5,"Howdy ";
GoTo Bla
Produces this strange output:
ydydwoH y ydwoHoH ydwdwoH y ydwoH H ydwdwoH ydydwoH H ydwowoH ydydwoH H ydwoHoH ydwdwoH y ydwoHoH ydwdwoH y ydwoH H ydwowoH ydydwoH H ydwowoH ydwdwoH y ydwoHoH ydwdwoH y ydwoHoH ydwdwoH ydydwoH H ydwowoH ydydwoH H ydwoHoH ydwdwoH y ydwoHoH ydwdwoH y ydwoH H ydwowoH
and so on...
Other baudrates give strange results also, here is the output at 38400
HoHowdydy HoHowdydy HoHowdwdy H Howdwdy H Howdwdy H Howdwdy y Howowdy y Howowdy y Howowdy y HoHowdydy HoHowdydy HoHowdydy HoHowdydy H Howdwdy H Howdwdy H Howdwdy H Howowdy y Howowdy y Howowdydy
Tested with the Pico connected to a CP210x USB to UART Bridge+TeraTerm and MAX232+ Terminal
Hmmm, am I using the COM port wrong or is this a bug?
Using COM2 (SetPin GP4,GP5,COM2) seems to work fine
Cheers,
Fred
Edited 2021-12-20 06:08 by fred777
Posted: 10:41pm 19 Dec 2021
  Quote  is it possible to switch the console from USB to a COM port so that a serial connection with a specified baudrate could be used as console?
Manual page 73
The other issue I'll test tomorrow
panky
Posted: 10:48pm 19 Dec 2021
@fred777
In your loop
bla:
 print #5,"Howdy"
goto bla
you will be executing at around 20uSec per loop so you will be overflowing the Tx buffer many times. Unsure as to why it is different for COM1 versus COM2.
If you put a pause (just for testing) of, say 1 second (pause 1000) on a line after the  print statement, you should then see correct output.
Doug.
panky
Posted: 01:36am 20 Dec 2021
@matherp
Peter,
In the section of Picomite source serial.c shown below (around line 310), should the highlighted line refer to com2Tx_buf ?
void SerialClose(int comnbr) {
if(comnbr == 1 && com1) {
uart_deinit(uart0);
com1 = false;
com1_interrupt = NULL;
if(UART0RXpin!=99)ExtCfg(UART0RXpin, EXT_NOT_CONFIG, 0);
if(UART0TXpin!=99)ExtCfg(UART0TXpin, EXT_NOT_CONFIG, 0);
if(com1Rx_buf!=NULL){FreeMemory(com1Rx_buf); com1Rx_buf=NULL;}
if(com1Tx_buf!=NULL){FreeMemory(com1Tx_buf); com1Tx_buf=NULL;}
else if(comnbr == 2 && com2) {
uart_deinit(uart1);
com2 = false;
com2_interrupt = NULL;
if(UART1RXpin!=99)ExtCfg(UART1RXpin, EXT_NOT_CONFIG, 0);
if(UART1TXpin!=99)ExtCfg(UART1TXpin, EXT_NOT_CONFIG, 0);
if(com2Rx_buf!=NULL){FreeMemory(com2Rx_buf); com2Rx_buf=NULL;}
***>>>> if(com1Tx_buf!=NULL){FreeMemory(com2Tx_buf); com2Tx_buf=NULL;}
Doug
Posted: 08:00am 20 Dec 2021
Panky
Thanks - will fix
fredd777
As per the manual page 127 the print statement is supposed to block if the output buffer is full. There is a bug in the code for com1 which I will fix in the next beta. Thanks for the report.
HOWEVER: letting the output block is very bad as this will hold off any interrupts so as per the manual use LOF to check before issuing the PRINT command if the application demands it
Edited 2021-12-20 18:11 by matherp
fred777
Posted: 09:39am 20 Dec 2021
  matherp said  Manual page 73
Sorry was using the V5.07.00 Manual, thanks!
But how does one set the Baudrate for the serial console?
I hope I haven't overlooked something in the manual again...
Edited 2021-12-20 19:49 by fred777
Posted: 10:23am 20 Dec 2021
  Quote  But how does one set the Baudrate for the serial console?
At the moment it is fixed 115200. I'll make it changeable with OPTION BAUDRATE in the next beta
fred777
Posted: 10:26am 20 Dec 2021
  matherp said  I'll make it changeable
You are the best!
wolfme
Posted: 07:17pm 20 Dec 2021
Hi,
is it possible to add include "file" from sd card (as in c) to PicoMite basic?
Wolfgang
TrevorC
Posted: 04:58pm 22 Dec 2021
Hi,
  I am having problem with I2C reads on the System bus. When reading a I2C sensor such as a SHT21 or DS1624 the picomite resets with the following message
Error: Invalid address - resetting
Sometimes I get an error message about the array I am storing the read data in.
There is not a problem if I run the program on I2C2 with the appropriate changes made to write and read on I2C2.
I came up with a short program to read from a DS3231 RTC which shows my problem.
' *** DS3231 RTC ***
Dim As Integer buffer(6)
'I2C Open 100,1000
RTC Gettime
old_time$ = "12:34:56"
SetPin GP25,off
Do While key$ = ""
  key$ = Inkey$
  tm$ = Time$
  If tm$ <> old_time$ Then
    ds3231
    old_time$ = Time$
  EndIf
SetPin GP25, heartbeat
End
Sub ds3231
I2C Write &h68,1,1,0
I2C Read &H68,0,7,buffer()
Print Hex$(buffer(2),2);":";
Print Hex$(buffer(1),2);":";
Print Hex$(buffer(0),2)
Is anyone else having the same problem.
Thanks, Trevor
Posted: 07:05pm 22 Dec 2021
Thanks for the report, definitely a bug and does happen on I2C2 as well. Can't find it at the moment but will keep looking. Remove the call the RTC GETTIME and it doesn't happen
TrevorC
Posted: 07:39pm 22 Dec 2021
Hi,
   Thanks for the reply. I have not found a problem with I2C2. I did not think to try removing the call to RTC GETTIME
   I came across this a few weeks ago when displaying I2C sensor data on LCDs and with OPTION AUTO RUN ON  the displays cleared at random times as the picomite reset itself and the program ran again.
   Will try reading the sensors with RTC GETTIME removed.
           Trevor
Posted: 07:57pm 22 Dec 2021
Found it
RTC GETTIME was leaving a pointer initialised that I2C READ assumed was set to NULL. Will be fixed in next beta
TrevorC
Posted: 08:27pm 22 Dec 2021
Thanks for sorting that out.
