Local Time 00:37 12 Nov 2026 Privacy Policy
Forum Index : Solar : Cheap Off The Shelf Inverter
ryanm
Posted: 06:19am 23 Feb 2022
Thanks for the first hand knoledge Revlac.
Was going to buy one and they're back out of stock. Looks like I sat on the fence too long...
Ellen
Posted: 02:03am 09 Mar 2022
  Quote  Also doesn't seem like you can use the inverter and charger at the same time. At night I would like to run off the inverter with the grid keeping my batteries from being too deeply discharged.
You are wrong on both counts as I have one running in Lightning Ridge .
Revlac
Posted: 02:09am 09 Mar 2022
  Quote  You are wrong on both counts as I have one running in Lightning Ridge .
Same model or different model?
Some models are capable of it and some are not.
Cheers Aaron
Off The Grid
ryanm
Posted: 06:48am 09 Mar 2022
Would you mind sharing what model you are running Ellen? If one of the more expensive ones can do both I would be interested.
Revlac
Posted: 08:05am 11 Mar 2022
Hi ryanm,
You might find some answers on the EV forum, it is quite extensive, but found it helpful on occasions.
https://forums.aeva.asn.au/viewforum.php?f=64
It might be Easier to straight out ask them, there should be a few people that have or know the exact ones that do the job, and some may have some photos of the innards.
On your inverter, the direction of airflow from the fans, do they force the hot air out the bottom (most did) or out the top?
Most people have changed the fans so the hot air exits out the top.
Can see the little monster on the fan vent enjoying the heat, best not to let them get into the inverter.
Cheers Aaron
Off The Grid
noneyabussiness
Posted: 08:23am 11 Mar 2022
revlac, if those things were gone, most grubberment contracted Eleccys would be out of a job... they destroy thousands ( dare say way more) in electronic equipment every day... sooo many times we would lose a air con etc from a fried gekko or their poop..
I think it works !!
Revlac
Posted: 11:44am 11 Mar 2022
They have been responsible for burning a hole through someones inverter board (despite the conformal coating), they can fit through the power in/out hole on these units, I do my best to plug any holes, keep the buggers out.
Had a few of them whacked by the fan in the aircon......Damn things stink like hell...and some....for something so small.
Cheers Aaron
Off The Grid
Ellen
Posted: 08:40pm 11 Mar 2022
My model does not appear any more for purchase but these are the same thing.
There are at least 100 of these installed round Nimbin NSW.
Surface spray directly on them kills gekos.
Ebay item
Edited 2022-03-12 06:44 by Ellen
Revlac
Posted: 02:27am 12 Mar 2022
Be careful with different brand names.
https://www.mppsolar.com/v3/fake/
Some clones as well, some may work well or at times might offer slightly better options than genuine brands, however they can have lesser quality components, often no designators on the pcb, and often the firmware might not be upgraded, also little support if something goes wrong.
Cheers Aaron
Off The Grid
Davo99
Posted: 03:07am 12 Mar 2022
Good Info Aaron.
I have looked at the Mpp site several times and missed that.
Looks like some people have been suckered with these cheap knockoffs already.
What is the benefit of exhausting the heat out the top and reversing the fans?
Is that for convection?
I have  radiator fans on my GTI's blowing from the top to the bottom because it goes against convection and I think the resistance, as nothing as it may be will help pick up heat.
The fans are solar powered and direct connected to panels so as soon as there is any worthwhile power the fans are blowing. Even though these are essential sealed units with no internal venting, having the fans blowing over the whole casing as well as the heatsink at the back makes for a huge difference in inverter temp with and without the fans.
Revlac
Posted: 05:51am 12 Mar 2022
Mostly for convection, The top left side is the hot spot, has the choke and IGBT heat sink, at least for the older models, the newer version I expect it would be similar perhaps.
One old one in the shed the fans are very slow and I put a fan on the top outlets to help, the fans on the inverter that runs the house they rev up as the load increases and remains quite cool.
They keep the lights on and the fridge, freezer and general house stuff running,  The home built MAD Inverter (will build another one) does all the Heavy work, large power tools etc. Been happy running this way.
When the authority of some ilk turns up they will only see the commercial unit, not the other one.
Cheers Aaron
Off The Grid
