Local Time 08:35 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LINUX: Filesystem oddness....
Posted: 09:31am 20 Sep 2021
OK, I have moved some stuff off sdc1, Linux now says there is 139.8GB free - but Windoze still says there is zero space, and SO DOES pMount AND sudo df -h
PartView gives me the 139.8GB free information.
Mint reports 86GB free on sdc1 now vs 18.6GB in the image above.
VERY strange.
I will continue to remove data from this drive till it is empty, then I will see if Windows etc are STILL reporting zero available.  At that point, I will then reformat the drive and copy SOME stuff back to it, and see if Windoze etc is then reporting a more believable figure.  I will keep the copy I make of sdc1, in case this drive is failing or something.
I've never seen this before.  Normally, the Linux volumes just report correctly, so this is a totally new head-scratcher moment for me.
Posted: 10:33am 20 Sep 2021
A web search for
linux file system reserved space
shows 5% is reserved by default for root.
(Whether yours is 5% I don't know.)
You can release it using tune2fs apparently.
Or show its setting using
tune2fs -l /dev/sdc1
(you'll need sudo  in front  of that if you're not root)
Edited 2021-09-20 20:34 by JohnS
