Forum Index : Microcontroller and PC projects : PicoMite V5.07.01b16: Breaking changes and CSUBs
Updated PicoCFunctions.h USER is is OK at #25. Thanks USERLCDPANEL is now 25 to match latest firmware. #define USERLCDPANEL 25 PicoCFunctions.zip Regards Gerry F4 H7FotSF4xGT |
@ Mixtel90 In the TINAM there are multiple SDCard and SD Card with a space. Not a problem except when searching. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Thanks. I'll have a look. It probably depended on context when I wrote it. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
PicoMiteV5.07.01b19.zip Matching the newly available full PicoMite manual. Note that unlike any other current version of MMBasic the PicoMite will be open source subject to some standard licence conditions. The source will be made available on Github after the first full release. Edited 2021-09-18 22:32 by matherp |
FYI Core Electronics Aust showing off their new Pick & Place Machine about to populate expansion boards for the Pi Pico on their Facebook page here Brian ChopperP |
Now the official PicoMite manual is being sorted out (see its own thread) TINAM is no more. However, some of you won't have had anything to do with the PicoMite so I've decided to produce a little introductory leaflet. It's aimed at those who have used MMBasic but are unfamiliar with the PicoMite platform. These little things are great fun - and cheap. Here in the UK it typically costs 3.60 UKP for a PicoMite and a further 3.00 UKP for postage! As it's the same postage for a few more it's tempting to stock up. :) PicoMite 101.zip Ooh Arr! It be International Talk Like A Pirate Day too, me hearties. That be one more thing to lift thee spirits! Edited 2021-09-19 22:12 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
What's a pirate's favorite letter of the alphabet? Ye might think it's "Rrrr", but a pirate's first love is the "C". PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
PicoMiteV5.05.00b20.zip Fixes minor bug in BLIT LOAD BLIT WRITE no longer needs w and h to be specified as the dimensions of the blit bufffer are now stored with the data BLIT WRITE [#]b, x, y[, w],[ h] MM.INFO(ID) returns the unique ID of the Pico Board. Tidy up of some error messages Edited 2021-09-20 19:15 by matherp |
PicoMiteV5.07.00b21.zip Fixes bug in re-enabling heartbeat Minor change to improve compatibility with Linux terminal emulators like minicom Fixes cut and paste bug in PWM3B, PWM4B, and PWM5B Edited 2021-09-23 01:51 by matherp |
I know it is very late in the game, but I do want to issue a feature request for the picomite. Can we please store the programs in flash in ASCII format. One of the features of the pico is that we have these 10 flash slots. People (like me) wire up a SD card in some cases, but in other cases use the flash as a mini flash file system. But, like now with update b21 (comming from b19), the tokenized version stored into flash (I have 7 programs in there) needs complete rework (I already found the "=" is replaced by a ">"). We are still in beta, so this is understandable, and a lot of work, but this should not happen when the release is made (and also not between releases) since there will be complaints in the format "!@#$%..." Regards, Volhout PicomiteVGA PETSCII ROBOTS |
I suspect they are tokenized because they are merely copied from RAM into flash. If you wanted them in ASCII they would have to be copied from the editor, not from a runnable program (which would necessitate expanding the tokens). Of course, ASCII in flash would also take up more space. Breaking the contents of the flash slots because of firmware updates probably won't be for long now. It's a pain, I know, but updates are always manually carried out. Before I got round to using the SDcard I used xmodem to copy each slot. At least you get a backup copy on the PC that way, even if it's a bit slow. Of course, if you save the slots, erase them, update and reload them you don't have to edit any of the contents. Edited 2021-09-23 18:29 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
Hi Mixtel90, If you work from MMEdit, the problem also does not exist (it uses Xmodem). It is just that when I am on travel I use my linux (chromebook) laptop and plug in a pico. Linux does not support MMEdit, so I use the pico editor, and when Xmodem works on GFXterm it may be a solution. And in this case I was thrown off by Peters comment that there where only minor bugfixes between b19 and b21. No new commands. That is why I did not expect the tokenizing to be different. But it is. In the end, it was my own fault. I did not make backup copies before updating the firmware. But it feels a bit like "!@#$%....". Volhout PicomiteVGA PETSCII ROBOTS |
Yeah... I did the editing thing a couple of times then vowed never to to an update unless I had a backup of the flash slots first! It does indeed feel like "!@#$%....". lol Mick Zilog Inside! nascom.info for Nascom & Gemini |
Put the old version back on then you can backup the flash. If I store ASCII in flash then you lose flash chain, so no |
I'm working on V5, give me a few more weeks... The new version of MMEdit may not have the file manager in the first beta but I do intend to cater for the FLASH storage on the pico. I assume that you can run Wine on chromebooks. If so MMEdit runs OK under Wine now. Also, you don't need XMODEM to get you files off the pico. FLASH LIST should give you a listing of all flash slots in one easy go. ( us ea SD so haven't tried that yet) You will have to manually split them into their respective files. Getting code onto the pico is easy with AUTOLOAD and that is the way I prefer. You can do all that with GFXterm. Jim VK7JH MMedit |
Can anyone tell me why this does not work ? input "set time HH:MM:SS ";Time$ Just curious... It is not a show stopper since below works... Input "set time HH:MM:SS ";t$ Time$ = t$ This was my fix until my DS3231 came in. Thats why I ask. PicomiteVGA PETSCII ROBOTS |
I suppose that Time$ isn't really a string, it's a function. Input only accepts variables. Mick Zilog Inside! nascom.info for Nascom & Gemini |
| led-bloon Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 210 |
Peter With PIO pinctrl helper function: PIO (PINCTRL num_side_set_pins[,num_set_pins] [,num_out_pins][,IN base][,side_set_base] [,set_base],?????) I wish to output from an OSR register to a GPIO pin, using the "OUT" instruction. However, the helper function does not seem to have the "out_base" parameter needed for configuration. Can you confirm, or, is the manual incorrect? led Miss you George |
Manual needs updating correct syntax is: PIO (PINCTRL num_side_set_pins[,num_set_pins] [,num_out_pins] [,IN base] [,side_set_base] [,set_base] [,out_base]) Code should be correct Edited 2021-09-28 17:34 by matherp |
Thanks Peter, thought as much. Back to the "drawing board". Miss you George |
