Forum Index : Microcontroller and PC projects : CMM2: V5.07.01b1
Am I doing something wrong or is there something fishy with the CALL function ? > 480MHz Colour Maximite 2 G2 MMBasic Version 5.07.00 Copyright 2011-2021 Geoff Graham Copyright 2016-2021 Peter Mather > list "call_bug.bas" Option Base 0 Option Default None Option Explicit On Print one%(), two%(), three%() Print Call("one%"), Print Call("two%"), Print Call("three%") Print Call("one%"), Call("two%"), Call("three%") Function one%() one% = 1 End Function Function two%() two% = 2 End Function Function three%() three% = 3 End Function > run "call_bug.bas" 1 2 3 0 0 0 Error in line 9: Argument list Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
V5.07.01b5 http://geoffg.net/Downloads/Maximite/CMM2_Beta.zip Fixes two bugs in the CALL function Improves Mode 12 when used as default with a mouse. Edited 2021-08-10 18:42 by matherp |
Thanks Peter, that seems to have done the trick. Best wishes, Tom Edited 2021-08-10 21:56 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
You may not care for this one ... and I may have brought it up before, in which case I apologise, it's because I have bad memory not because I'm trying to be difficult: > new > list "cmdline.bas" Print Mm.CmdLine$ > run "cmdline", --foo --foo > *cmdline --foo --foo > run , --foo , XXfoo > list Print Mm.CmdLine$ The X's appear as line-drawing characters on the CMM2. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
And another one in a similar vein: > list "cmdline.bas" Print Mm.CmdLine$ > list "run_test.bas" RUN "cmdline", foo > list "execute_test.bas" EXECUTE "RUN " + Chr$(34) + "cmdline" + Chr$(34) + ", foo" > run "run_test" FOO > run "execute_test" foo IMO the output should be lower-case "foo" in both cases. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
V5.07.01b6 http://geoffg.net/Downloads/Maximite/CMM2_Beta.zip Enhancements to run command Tom: this should be near release candidate status. Please could you run your full regression tests on this version - thanks |
OK, will do, though referring to them as "full regression tests" is rather overstating their coverage .Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Arno Newbie Joined: 19/09/2020 Location: GermanyPosts: 15 |
Thank you for improving mode 12 Peter, I really like this mode. One small thing which would be nice when you can look at it is the list command. When I list a program for the second time, which consists more than one page, I see some garbage always on the last line when I scroll through the pages. The editor is working very good and does not show anything like this when I scroll through the code. My settings are: > option list CURRENT Default mode 12 960x540 CURRENT VGA mode 960x540 RGB332 CURRENT DISPLAY 50,100 OPTION USBKEYBOARD DE OPTION MOUSE 0,0 Edited 2021-08-13 01:31 by Arno |
Arno Does your monitor support mode 14? Same resolution but much more efficient than mode 12 if the monitor likes it |
Peter The Monitor is a BENQ GW2270H, 22 inch (16:9) and mode 14 is supported but looks not very good. Mode 16 is good when I edit something but not for my program layout. Please don't bother with that too much, mode 12 is running for me now and I really appreciate to work with it. |
Peter, If you really want to squash them all I've found one more issue in b6 with RUN and command-line arguments. Here is a full transcript: A:/SPTOOLS/FIRMWARE-TESTS/MANUAL-TESTS 21:14 12-08-2021 19 cmdline.bas 21:18 12-08-2021 62 execute_test.bas 21:17 12-08-2021 22 run_test.bas 0 directories, 3 files > list "cmdline.bas" Print Mm.CmdLine$ > list "execute_test.bas" Execute "Run " + Chr$(34) + "cmdline" + Chr$(34) + ", --foo" > list "run_test.bas" Run "cmdline", --foo > run "cmdline", --foo --foo > *cmdline --foo --foo > run , --foo --foo > run "execute_test" --foo > run "run_test" XXfoo The problem is with the 5th test where again we have line-drawing characters which in b5 we had with the 3rd test. I should have got a job in our Q/A department I'm as devious and pedantic as those guys & gals. Best wishes, Tom Edited 2021-08-13 06:31 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
You should be brilliant at hunting Pokemon... ;) Mick Zilog Inside! nascom.info for Nascom & Gemini |
With a BENQ GL2580H mode 14 image quality is very good and much faster. Thank you very much Peter. |
