Local Time 09:15 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How to talk to a MAX6675 with a MM2....
Posted: 05:32am 25 Jul 2021
I should have thought about that, really.  The datasheet says as much on page 5:
So, the chip will take a reading when I pull CS low, and that data is saved in the chip data register, and is clocked out via the SPI command.
BUT as I never released CS(returned it high), next time I read the chip, it just clocks out the same data still in the internal registers as I had not released the CS line, so it never took another reading.
Silly me.....
@ JIM: We really ARE thinking the same things at the same time with this one!!!!
Edited 2021-07-25 15:33 by Grogster
Posted: 05:37am 25 Jul 2021
I haven't got much else to do today (Well I have but too b....dy cold)
I did clean the coffee machine so the day isn't totally wasted.
Posted: 06:20am 25 Jul 2021
If reading the thermocouple is only done intermittently, move the Pin(x) = 1 to the top to ensure a fresh reading.
Pin(x) = 1
Pause 1000
Pin(x) = 0
BYTE = SPI(0)
Print BIN$(BYTE, 16), BIN$((BYTE >> 3),16), BYTE>>5
loop
Posted: 12:48am 26 Jul 2021
Good point, thanks phil99.
Posted: 02:25am 26 Jul 2021
You need to allow at least 220mS after raising CS for the conversion to complete.
So don't read in a tight loop.
Posted: 05:31am 26 Jul 2021
Gotcha.
