Local Time 09:57 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : New Version: Micromite MMBasic Ver 5.05.04
Chopperp
Posted: 08:56am 15 Jun 2021
  KeepIS said  What version? I can read every PDF and read Every Hex file.
19.00(x64) but I see that you are now having fun with the zip file
ChopperP
twofingers
Posted: 09:01am 15 Jun 2021
@Volhout
Correction: Archive is corrupt!
Tried with Winrar 3.9 and 5.05.
Some of the PDFs are readable.
Michael
KeepIS
Yes, running 7zFM directly in its own GUI and seeing the actual errors, what happened between downloads is beyond me?
Posted: 09:46am 15 Jun 2021
Some of the files in the archive for the Full version are corrupt. I'd only checked a couple of the newer ones previously. The zip downloaded ok (twice, just to check - identical file sizes 8,381,938 bytes).
Edit:
Curiouser and Curiouser...
I've just downloaded again using Pale Moon and got a zip size of 8,200,763 bytes
This one has unpacked with no errors. :)
Edited 2021-06-15 19:58 by Mixtel90
Posted: 09:57am 15 Jun 2021
Sorry everyone, the zip somehow got corrupted.
I have corrected the problem so please download again (you might have to clear your browser cache first).  Even if you managed to extract something from the old zip it would be worth downloading again to make sure that all the files are OK.
BTW Thanks for the kind words.  Rob, I will have a look at your comments tomorrow.
Posted: 09:59am 15 Jun 2021
That would explain things. :)
Thanks again.
Posted: 10:11am 15 Jun 2021
Perfect.
Thank you.
Phil
Chopperp
Posted: 10:39am 15 Jun 2021
All good.
Thanks Geoff
ChopperP
athlon1900
Posted: 06:20pm 16 Jun 2021
Thank you Geoff.
Perfect
