Local Time 11:47 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 - scientific format
Posted: 03:48pm 25 Feb 2021
  Nimue said  Inadvertently I figured the i%=i%+1 needed to be inside the for loop.
Understandable. I didn't run the suggested code earlier because I couldn't see what the addition was supposed to show. (And maybe you're right.)
Edited 2021-02-26 01:52 by lizby
Nimue
Posted: 04:02pm 25 Feb 2021
I "obviously" (erm honestly)  figured that unless the for loop was actually doing something then any difference between int and float would be negligible.
N
zeitfest
Posted: 08:29pm 25 Feb 2021
  Nimue said  The "issue" with mine was:
your code....
timer=0
for n%=1 to 1000000:next
i% = i% + 1
?timer
my code:
timer=0
for n%=1 to 1000000
  i% = i% + 1
next
?timer
Thanks !
(Cough, ahem, cough) yes you are both right       I was tired m'lud etc etc.
The point was, I don't think the empty loop is a good general test of floating point
Edited 2021-02-26 06:33 by zeitfest
