Local Time 10:13 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Colour Maximite 1 & 2 BASIC Programming Challenge 2021
     Page 2 of 8
Posted: 06:41am 12 Feb 2021
Hi Vegepete,
Dont forget to submit it to the official email address (listed in the rules)
mailto: cmmprogrammingchallenge@gmail.com
And NO!, I have no idea what it does until I run it.
PilotPirx
Posted: 09:11am 12 Feb 2021
Hi Vegipete,
  Quote  The title is "In Defense of the Green Hills of Earth"
wow, the first game i had on my Sinclair ZX80!! (only Assembler and B/W)
Very good and short programming. I love it.
I'll never be a good programmer, sigh!
Posted: 09:48am 12 Feb 2021
@vegipete
You've set an impressive bar, and I did guess correctly, from the name, not the code.
MauroXavier
Posted: 10:26am 12 Feb 2021
vegipete, I tested it and it's very impressive! Congratulations!
Edited 2021-02-12 20:26 by MauroXavier
Posted: 10:58am 12 Feb 2021
Edited 2021-02-15 03:40 by Volhout
vegipete
Posted: 08:24pm 15 Feb 2021
Here is a minor update to
In Defence of the Green Hills of Earth. No visible changes, just some slight internal adjustments.
Included is an expanded and heavily commented version, over 400 lines long, although more than 25% is 'educational' commenting at the beginning, explaining some of the theory behind my perverse programming.
Interestingly, the expanded version has shown me a few 'faults' in the code - unnecessary chunks that serve no purpose. However, it's all retained in its glory.
Edit: I see an omission in the comments around line 77:
"The result can only be 0 if both conditions are false. They cannot both be true."
Edited 2021-02-16 06:30 by vegipete
Turbo46
Posted: 04:49am 16 Feb 2021
Thanks for that vegiepete. Much appreciated.
MauroXavier
Posted: 02:29pm 16 Feb 2021
It was very curious reading the vegipete source today and see that I did some implementations in the same way, but always with a code less readable (sorry! I really need to educate myself about this).
Soon I will publish my source to the contest too... But compared to the vegipete, my code is a f* mess, using almost all 4800 characters heavily compressed, and it isn't because I wanted the things to be like this, but is because I needed to do this way to put all the effects.
At all times of the programming, I was tormented with thoughts like: - "But what if I put this effect here or there?". So when I tried to make the job I always got me not having more space on the screen, forcing me to challenge myself more and more until exhaustion (seriously!).
But unfortunately, the final result is a source code unintendedly obfuscated to fit it in the purpose of 4800 characters. For sure I will don't get one single point for Clarity in the contest, but I consider it a sacrifice too.
Posted: 02:34pm 16 Feb 2021
Whilst we don't object, and actively encoourage, entries being posted to TBS can I also please ask contestants to send their contribution to the official email address cmmprogrammingchallenge@gmail.com as only those will be considered official entries.
MauroXavier
Posted: 12:01am 18 Feb 2021
I already sent the e-mail to the contest as the instructions.
For the forum members, here is my code and submitted text:
Game name: HOPE ROBOT
DIM XP(2),YP(2),FX(4),FY(4),FA(4),FD(4),FS(4),PX(99),PY(99),CX(99),CY(99),PA(99),PM(99),PP(99):L=.1
SUB PR F,T,X,Y,C,O,A$,Z,S:PG 1:FONT #F,T:COLOR S:FOR ZA=-Z TO Z+1:FOR ZB=-Z TO Z:?@(X+ZA,Y+ZB,1) A$;
NEXT:NEXT:COLOR O:?@(X+1,Y,1) A$;:COLOR C:?@(X,Y,1) A$;:END SUB:OPTION ANGLE DEGREES:YW=10^8:R=7.8^8
SUB HR:IF TIMER MOD (((LF\50)+1)*290)<200 OR LF=0 THEN PLAY SOUND 4,B,Q,900,10 ELSE PLAY SOUND 4,B,O
END SUB:SUB MT C:SN C,"O",1:END SUB:SUB PG T:PAGE WRITE T:END SUB:XX=640:YY=400:TC=&HFF2800:W=10^8.4
SUB SN C,P$,F,V:EXECUTE "PLAY SOUND "+STR$(C)+",B,"+P$+","+STR$(F)+","+STR$(V):END SUB:MODE 2,8:DO
YD=7763456:V=V+1:Y=200:LF=Y-V*2:DN=300:U=4^11::GO=0:SETTICK 0,HR:PLAY STOP:X=0:IF SV=0 THEN SC=0:V=2
YB=50^4:DO WHILE KEYDOWN(1)<>32 AND SV=0:PG 1:CLS 99:T=COS(I)*1+1:PR 3,3,82,145,R,R,"HOPE ROBOT",T,R
PR 7,2,4,4,W,W,"HIGH SCORE:"+FORMAT$(HS,"%06.0f"),2:S=T*99:PR 7,2,238,DN,S,S,"PRESS SPACE",2:I=I+30
PR 1,1,230,385,W,W,"MAURO XAVIER - 2021",2:PAGE COPY 1 TO 0:SN 1,"T",T*75+1,25:LOOP:CLS TC:PG 2:SV=0
MS$="GAME OVER":DD=0:S=65:MATH SET 0,FA():MATH SET 0,PA():SETTICK 25,HR:AN=0:TIMER=0:UP=99:CLS TC
BOX 0,170,XX,60,0,,U:DO WHILE LF>=0:PG 2:UP=UP+RA:IF UP<20 THEN UP=20 ELSE IF UP>DN-80 THEN UP=DN-80
RA=RND*10-5:RB=RND*10-5:IF WL<1 THEN:CP=U:ENDIF:IF DN<UP+80 THEN DN=UP+80 ELSE IF DN>380 THEN DN=380
BOX XX-M,0,M,YY,0,,TC:BOX XX-M,UP,M,DN-UP,0,,CP:M=V+X\35:WL=WL-1:DG=G*H:DN=DN+RB:CP=YD:PG 1:SX=0:N=3
SY=0:FOR T=0 TO XX STEP 30:DG=DG+6:BLIT T,0,T,COS(DG)*8,30,YY,2,0:NEXT:IF TIMER>999 AND LF>0 THEN
PAGE SCROLL 2,-M,0,0:FOR T=1 TO 4:K=KEYDOWN(T):IF K=32 AND F=0 THEN:F=1:ENDIF:IF K=128 THEN:SY=-N
ELSEIF K=129 THEN:SY=N:ENDIF:IF K=130 THEN:SX=-N:ELSEIF K=131 THEN:SX=N:ENDIF:NEXT:GO=1:ELSE:EN=0
ENDIF:D=D+SY:EG$="N":TT=M-V:X=X+S/10:Y=Y+D/10:SN 1,EG$,(10-S\12)\3+TM,9:IF X<0 AND DD=0 THEN X=0:S=0
TX$="SAVED":IF S>0 THEN:S=S-1:ELSEIF S<0 THEN:S=S+1:ENDIF:IF D<-40 THEN D=-40 ELSE IF D>40 THEN D=40
B=255:SW=G MOD 2:IF X>610 THEN:SX=-4:ENDIF:IF SY=0 THEN IF D>0 THEN:D=D-1:ENDIF:IF D<0 THEN INC D
XP(1)=X+COS(D+120)*TM:S=S+SX:XP(0)=X+COS(D)*20:XP(2)=X+COS(D+240)*TM:YP(0)=Y+SIN(D)*20:CN=&HFF00BF
YP(1)=Y+SIN(D+120)*TM:YP(2)=Y+SIN(D+240)*TM:POLYGON 3,XP(),YP(),0,&HBBBB:SS=S:IF SS<-5 THEN SS=-5
XP(0)=X-COS(D)*(SS+M*7):YP(0)=Y-SIN(D*2)*20:PG 1:MT 2:IF SW THEN POLYGON 3,XP(),YP(),U,RGB(127,0,0)
ENDIF:SC=SC+IS::IS=M/50+SV*50:IF EN=0 THEN:IF RND<0.01 THEN:ER=0:YE=UP+20+RND*(DN-UP-20):XS=-RND*V
XE=649:YS=RND*6-3:EN=GO:ENDIF:ELSE:INC ER,15:EA=COS(ER)*4+15:INC XE,XS-M:IF XE<X THEN A=L ELSE A=-L
INC YE,YS:IF YE<Y THEN:C=L:ELSE:C=-L:ENDIF:INC XS,A:INC YS,C:Q=Q+YS:K=0:FOR T=Q TO 360+Q STEP 20
A=-COS(T)*EA:C=-SIN(T)*EA:LINE XE,YE,XE-A*1.4,YE-C*1.4,1,W:O=PIXEL(XE-A,YE-C): IF O=TC OR O=YD THEN
INC XS,A/5:INC YS,C/5:INC XE,A:INC YE,C:MT 3:ENDIF:NEXT:CIRCLE XE,YE,EA,1,1,0,CN:SN 3,"T",EA*15,20
ENDIF:IF XE<0 OR XE>649 THEN:EN=0:MT 3:ENDIF:FOR T=1 TO 4:A=X+COS(D)*35:IF KEYDOWN(T)=32 THEN K=2
IF FA(T)=1 THEN:INC FY(T),FD(T):INC FX(T),14-TT:INC FS(T),-1:IF FX(T)>XX OR FY(T)<0 OR FY(T)>YY THEN
FA(T)=0:ENDIF:PG 1:LINE FX(T)-30,FY(T)-FD(T)*2,FX(T),FY(T),1,YW:IF FS(T)>1 THEN SN 2,"W",FS(T)*50,25
FOR E=1 TO 9:O=PIXEL(FX(T)+E,FY(T)):IF FX(T)<XX AND (O=TC OR O=CN OR O=YD) THEN:PC=YB:A=3:FA(T)=30
IF O=TC THEN:PC=R:H=25:A=-8:ELSEIF O=CN THEN:IS=150:MT 3:A=25:EN=0:PC=7.3^8:ENDIF:LF=LF+A:EXIT FOR
ENDIF:NEXT E:ENDIF:IF FA(T)>1 THEN:PG 1:C=FA(T)*8+9:INC FX(T),-M:A=RGB(C,C,C):SN 3,"N",61-FA(T)*2,25
INC FA(T),-3:CIRCLE FX(T),FY(T),33-FA(T),1,1,YW,A:IF FA(T)<3 THEN:PG 2:CIRCLE FX(T),FY(T),32,1,1,U,U
MT 3:FA(T)=0:ENDIF:I=0:P=0:DO WHILE I<=39 AND P<10:IF PA(I)=0 THEN:PA(I)=1:PM(I)=0:CX(I)=RND*7-5
CY(I)=RND*8-4:INC P:PP(I)=PC:PX(I)=FX(T):PY(I)=FY(T)+(YY-FY(T))/99:ENDIF:INC I:LOOP:ENDIF:PG 2
IF FA(T)=0 AND F=1 THEN:F=2:FY(T)=Y+SIN(D)*50:FA(T)=1:FX(T)=A:FD(T)=D/2:FS(T)=10:EXIT FOR:ENDIF:NEXT
F=K:ENDIF:TM=COS(AN)*4+9:IF RND>0.99 AND GO THEN:WL=9:ENDIF:IF LF>350 THEN SV=1:LF=350:MS$=TX$+"!!"
H=H-L:FOR I=0 TO 39:IF PA(I)=1 THEN:INC PY(I),CY(I):INC PX(I),CX(I)-M:PG 2:IF PX(I)<0 THEN PA(I)=0
J=PP(I):O=PIXEL(PX(I),PY(I)):IF O=TC OR O=YD THEN:CX(I)=-CX(I)/4:INC PM(I):CY(I)=-CY(I)/4
IF PM(I)>5 THEN:PA(I)=0:CIRCLE PX(I),PY(I),4,1,1,J,J:ENDIF:ENDIF:PG 1:CIRCLE PX(I),PY(I),4,1,1,J,J
ENDIF:ENDIF:NEXT I:FONT #3,3::FOR T=0 TO 360 STEP 45:A=-COS(T)*15-5:C=-SIN(T)*TM:I=PIXEL(X-A,Y-C)
IF I=TC OR I=CN OR I=YD THEN:S=S+A:D=D+C:EG$="W":LF=LF-1:ENDIF:NEXT:IF LF<1 OR SV=1 THEN:EN=0:D=0
LF=SV*300:IF DD=0 THEN:PLAY STOP:TIMER=0:ENDIF:PR 3,3+SV,95,145,YW,B,MS$,3,B*SW:IF TIMER>4^6 THEN
LF=-1:ENDIF:S=0:DD=1:ELSE:PR 1,1,11,16,W,B,"LIFE",1:BOX 50,18,LF,9,1,0,B:LF=LF-L:BOX 50,18,350,9,1,W
ENDIF:PR 1,1+DD*2,11,4,W,B,"SCORE:"+FORMAT$(SC,"%06.0f")+"  "+TX$+":"+STR$(V-2),1+DD:G=1+G MOD 360
INC AN,M*3:T=14-LF\10:IF H<=T THEN:H=T:ENDIF:PAGE COPY 1 TO 0,I:LOOP:IF SC>HS THEN:HS=SC:ENDIF:LOOP
DESCRIPTION
You are a testing prototype nanomachine called "HOPE ROBOT", which is the last hope of humanity to extinguish virus plague that spread to all the world.
Navigate inside human bodies and save patients in this nano adventure for your Colour Maximite 2.
INSTRUCTIONS
Press SPACE to fire and directional keys to move your robot, but be careful, your nanomachine is moving inside a body and you should not shot in the human tissues, you must exterminate all viruses and unblock all passages to relieve the blood circulation.
You start at a middle scenario inside a patient, and as eliminating the blocked passages and viruses the life will be restored and you hear the heartbeat stabilising. If you delay doing anything, life decreases with time and if you shot in human tissues you will hurt the patient, decreasing the life and disestablishing the heartbeat. The game is over if the life bar reaches the end.
If you fill the life bar then you saved the patient and will restart inside another human body to save it again, but with each patient saved, the difficulty will be increased.
You will gain a little score while keeping the patient alive, but the main score is focused on killing viruses and saving patients.
Good luck, you are our HOPE ROBOT!
OBSERVATIONS ABOUT DEVELOPMENT
This game was developed totally focused to keep the rules of this contest but unfortunately was impossible to keep a minimum of clarity of the code or a single comment. All algorithm is propositionally out of order and is heavily unorganized, but was not my intention obfuscate it, but to gain every single extra character to fulfil my target: give the best experience I can give to the users at 48x100 characters limitation.
Edited 2021-02-18 10:23 by MauroXavier
vegipete
Posted: 05:40pm 18 Feb 2021
Wow Mauro, that is a seriously awesome effort!
A couple of observations:
Line 43 start with two ENDIFs - I think you only need one.
You could change your high score test at the end (IF SC>HS THEN:HS=SC:ENDIF) to HS=MAX(HS,SC) to save some space.
Beautiful program! I really like the spray of exploding circles. So much for me to study. Your amazing work shows just how much the CMM2 can do.
MauroXavier
Posted: 06:28pm 18 Feb 2021
vegipete, thanks for your recommendations! This saved space can help me to put a thing again.
I never used the MAX command, and this shows that I must read the manual to learn about some commands that I not used before.
There were so many things that I removed... Maybe with a little more tricks, I can put it in place again.
After I consider the code as the final version for the contest, then I will organize, put comments, and release an enhanced version of "HOPE ROBOT+" with all the implementations that I would like to have done.
vegipete
Posted: 10:35pm 18 Feb 2021
I may have some more savings for you. I wanna see even more tricks!
(The line numbers for the ideas below refer to your listing above.)
I'm not sure of this one but it could give you a bit (It might not handle multiple key presses correctly):
lines 16 and 17, compressed:
expanded, with possible alterations:
   FOR T=1 TO 4
     K=KEYDOWN(T)
     IF K=128 THEN
       SY=-N                 ' end of line 16
     ELSEIF K=129 THEN
       SY=N
     ENDIF
     'SY=SY+(K=129)-(K=128)   ' ####### replaces previous 5 lines
     IF K=130 THEN
       SX=-N
     ELSEIF K=131 THEN
       SX=N
     ENDIF
     'SX=SX+(K=131)-(K=130)   ' ####### replaces previous 5 lines
   NEXT
   SX=40*SGN(SX)   ' ####### add this statement
   SY=40*SGN(SY)   ' ####### add this statement
   GO=1:ELSE:EN=0
In line 19, change
to
S=S-SGN(S)
In line 20, change
to
D=D-(D>0):D=D+(D<0)
In line 26, change
to
C=L*(2*(YE<Y)-1)
End of line 40, change (test this one carefully)
to
PA(I)=(PX(I)>=0)
MauroXavier
Posted: 11:35pm 18 Feb 2021
You have very impressive logical reasoning. I learned a lot from your tips, I'll apply them and take a closer look to see if I apply some more (In variable D it was possible to apply SGN too).
For sure you will see other things implemented thanks to you.
MauroXavier
Posted: 11:45pm 18 Feb 2021
This part doesn't work well:
SX=40*SGN(SX)
SY=40*SGN(SY)
But using your trick, I changed the keyboard controller part to:
SX=SX+((K=131)-(K=130))*N:SY=SY+((K=129)-(K=128))*N
And worked very well!
vegipete
Posted: 12:10am 19 Feb 2021
  MauroXavier said  This part doesn't work well:
SX=40*SGN(SX)
SY=40*SGN(SY)
I'm not sure why I put '40' there - should have been 'N'.
  Quote  But using your trick, I changed the keyboard controller part to:
You are right. Opposite arrow keys will cancel each other. I had that to begin with but confused myself and changed it and added the "40*SGN" bit.
I'm looking forward to more awesomeness with Hope Robot!
vegipete
Posted: 12:17am 19 Feb 2021
I looked at D a bit, didn't immediately see anything. Now I did spot something:
Change (end of line 19)
to
D=MAX(-40,MIN(40,D))
Posted: 11:56am 01 Mar 2021
Hi folks,
With only one month to go there has been exactly ...
... ONE entry sent to the official email address cmmprogrammingchallenge@gmail.com - and the crowd goes wild with excitement .
Posted: 12:12pm 01 Mar 2021
I hope it isn't disqualified LOL
Posted: 12:22pm 01 Mar 2021
  vegipete said  I looked at D a bit, didn't immediately see anything. Now I did spot something:
to
@Vegipete
Wauw, that is clever coding. Tried it in DOS MMBasic, and it really works.
I take my hat off.
     Page 2 of 8
