Forum Index : Microcontroller and PC projects : CMM2: V5.06.00RC1
Did you set OPTION SD TIMING FAST? If so try it with NORMAL instead of FAST. If it's already NORMAL, try it with FAST. |
Please download V5.06.00RC5 http://geoffg.net/Downloads/Maximite/CMM2_Beta.zip This should be very close to the final version. Changes are limited to bringing CSUB functionality up to current spec. The zip includes an updated version (V1.4) of ARMCFunction.h. It also includes what should be a final version of the V5.06.00 release notes. NOTE: compared to V5.05.05 there is a lot of new functionality but breaking changes are minimal: BREAKING CHANGES FROM V5.05.05: IMAGE ROTATE direction reversed to match IMAGE ROTATE_FAST, positive angles are clockwise MM.INFO(AUTORUN) replaced with MM.INFO(OPTION AUTORUN) Programs that peek and/or poke or use CSUBs to access video memory pages other than page 0 ( 8 and 16 bit colour) and pages 0 and 1 (12-bit colour) in modes 3,5,6,7,12 and 13 will not work as expected and may crash GETSCANLINE now reports the first visible line as 0 rather than the first line after VSYNC CSUBs may need re-compiling Edited 2020-12-09 20:09 by matherp |
| William Leue Guru Joined: 03/07/2020 Location: United StatesPosts: 415 |
Great! I am really looking forward to a "stable" release so I can update the firmware on my CMM2. I have so far resisted going past 5.05.06RC15 because the updates have been coming so fast due to Peter's amazing work. -Bill |
I don't see the 5.06.00 release notes in the ZIP, just the 5.05.06 notes. Are they the ones? |
Yes - now corrected |
| jirsoft Guru Joined: 18/09/2020 Location: Czech RepublicPosts: 533 |
Hi Peter, I'm still on 5.06.00RC3, so maybe the bug is not in later FW, but this: OPTION DEFAULT NONE OPTION EXPLICIT OPTION BASE 0 DIM INTEGER a(5), b(5), c(5,10), d(5,10), i, j FOR i = 0 TO 5 a(i) = 0 b(i) = 0 FOR j = 0 TO 10 c(i, j) = 0 d(i, j) = 0 NEXT j NEXT i FOR i = 0 TO 5 FOR j = 0 TO 10 a(i) = a(i) + 1 INC b(i) c(i, j) = c(i, j) + 1 INC d(i,j) NEXT j NEXT i FOR i = 0 TO 5 ? a(i)","b(i), NEXT i ? ? FOR i = 0 TO 5 FOR j = 0 TO 10 ? c(i, j)","d(i, j), NEXT j ? NEXT i gives: ![]() Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), Â CMM2.fun |
The Windows version of MMBASIC gives all ones. Edited 2020-12-11 05:10 by toml_12953 |
Just to be sure you are expecting 11, 11 11, 11 11, 11 11, 11 11, 11 11, 11 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 1, 1 ? |
Yes. I tried to simulate the difference between INC x and x = x + 1, which should be the same. I found this in SimplEd, but I don't know exactly where (I replaced it immediately with no-INC version) Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), Â CMM2.fun |
Wasn't there a previous post about an INC bug? Or was that only when the increment value was greater than 1? |
The bug is because the value to be incremented is a 2D array element - will post a fix tomorrow. For the avoidance of doubt, no other version of MMBasic has the inc command |
Thanks Peter, it was hard to find bug for me, because I put blame on SimplEd... Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), Â CMM2.fun |
Hi Peter, it looks like I found another bug . When I use LOAD FONT, it (sometimes) "eats" first member of string array:DIM INTEGER i DIM STRING txt(2) = ("a", "b", "c") FOR i = 0 TO BOUND(txt()):? txt(i):NEXT i LOAD FONT "AtariST.FNT" FOR i = 0 TO BOUND(txt()):? txt(i):NEXT i Result is: 1 2 3 2 3 The txt(0) still exists, but is zero length string now... Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), Â CMM2.fun |
Please post the font file so I have something to test with |
Here is it: AtariST.FNT.zip Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), Â CMM2.fun |
Thanks - that found the bug. Your font uses exactly 3584 bytes. 3584 is 256*14. The original code asked for 3584 bytes of heap memory and heap is always allocated in chunks of 256 - no problem. BUT I forgot the 4 bytes for the header so should have asked for 3584+4. For fonts where the size wasn't a multiple of 256 there was no issue so I couldn't replicate as there was always spare memory but as always the special case kills you ![]() Please test the attached for this fix + the com3 issues and report back then assuming all OK I'll release it CMM2V1.5.zip Edited 2020-12-12 18:14 by matherp |
| RetroJoe Senior Member Joined: 06/08/2020 Location: CanadaPosts: 290 |
Wow, that’s the mother of edge cases! There’s a very common “Off By 1” defect pattern in software (e.g. starting your array index at 0 instead of 1, or ending a loop one iteration too early). In the same vein, this bug falls into the “Perfect Multiple” class of defects, or maybe it’s just a variation on the common page boundary pattern. In any case, great detective work! Edited 2020-12-12 20:40 by RetroJoe Enjoy Every Sandwich / Joe P. |
Peter is it the intention that this should work? > Dim a$(2, 2) > Cat a$(1, 1), "foo" Expected a string Best regards, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Thanks Peter, it's working (at least the font case) now. I'm specialist for edge cases... Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), Â CMM2.fun |
| frnno967 Senior Member Joined: 02/10/2020 Location: United StatesPosts: 105 |
The COM3 interrupt issue is fixed but Xmodem still presents an error "Serial Console Disabled" when trying to operate over COM3 when in OPTION CONSOLE SCREEN mode. Jay Crutti: Ham Radio Operator, K5JCJ. Computer Enthusiast. Musician. Engineer. |
