Local Time 12:42 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM2: Problems with MPRLS0015PA0000SA SPI pressure sensor
Frank N. Furter
Posted: 01:47pm 13 Jan 2021
Hi,
I finally found some time to take care of my sensor problem.
I have now connected my logicanalyzer and can now see what I am really sending and how my sensor is reacting.
Mode 0 is the correct mode - only here I get a pulse on the EOC line (end-of-conversion indicator) when I send the correct start sequence!
Unfortunately, I still get "house numbers" as a response from the sensor!
But I have found that sending ONLY works with "SPI write"!?
With this code
 SPI write 1, &HAA
 SPI write 1, 0
 SPI write 1, 0
I can see this response on my analyzer:
MOSI: 0xAA  MISO: 0x40
MOSI: 0x00  MISO: 0xD9
MOSI: 0x00  MISO: 0x40
But with this code,
 Data %(1)=SPI(&HAA)
 Data %(2)=SPI(0)
 Data %(3)=SPI(0)
I'm actually sending this:
MOSI: 0xF0  MISO: 0x40
MOSI: 0x00  MISO: 0x43
...and my sensor doesn't response!
So I send hF0 instead of hAA with this command!!!
Maybe an error in "variable = SPI(data)" anyway?
Or what am I doing wrong?
Frank
