Forum Index : Microcontroller and PC projects : CMM2: GetFileDialog Box
| epsilon Senior Member Joined: 30/07/2020 Location: BelgiumPosts: 255 |
I finally got a chance to try out the FileDialog box. I love it! What's preventing me from using it as-is in HexEdit for example, is that I can't create new files in the dialog. This is needed when opening a new file for instance, or when exporting/saving as. One possibility is that when the INS key is pressed, a prompt opens at the cursor position so the user can enter the new filename. Regarding MAR, I think what Michael's suggesting is that using this dialog, I can create a UI based version of MAR that includes both the archive extract and archive create functions. When the user selects a directory, that directory gets archived. When the user selects a .MAR archive, that archive gets extracted. To do that I need the option to select a directory. One way to go about is to use Enter for file/directory selection, and use cursor-right to enter into a directory. Finally, a UI based xDel would benefit from having the options to select multiple files and directories, e.g. the Enter key toggles file/directory highlighting, multiple files and dirs can be highlighted this way. Esc takes you out of the dialog. The dialog would then have to return an array of names instead of a single one. Ruben/Epsilon. Epsilon CMM2 projects |
I think that will be part of the 'spec' parameter. I'm still pondering... That's an interesting thought. Maybe [space bar] would toggle selections on and off. Font #1 includes an empty and check marked box... Well, I did create it as GetFileName dialog. But I will examine SaveFile, perhaps as a companion routine, maybe combined with more parameters. Visit Vegipete's *Mite Library for cool programs. |
Yes. That would work. Understood. Currently I'm expecting the user to choose a name for a new file they want to edit _before_ they start editing. Maybe it makes more sense to move that decision to the first save point. This would allow me to use GetFileName as-is and use a simple prompt based SaveFile, until a fancy SaveFile dialog comes along. ![]() Epsilon CMM2 projects |
Here is the latest version of GetFileName dialog. GetFile12.zip Changes: Now the spec$ parameter works: GetFileName(15,"<dir>") shows everything but only lets you select directories. GetFileName(15,"*") shows everything but only lets you select files GetFileName(15,"*.bas") shows directories and BAS files but only lets you select files Added: saved directory choices as you tunnel deeper into sub-directories, so that the selected directory is re-selected when you come back up. Starts from the current working directory, not the root directory. (This aspect can be confusing if you don't realize you are deeper in the hierarchy and need to press left arrow to rise up towards root.) Also, I made the demo program a bit silly, in the process of showing the features. ============ Features not implemented, but maybe possible: Multiple Selections: would that be files only, or files and directories? It won't span directory levels though. Save File: needs a slightly changed dialog box with a text box that allows entering a name. But what about file types? For now, file saving could be a two step process: 1) let the user select where to save - a directory 2) ask the user for the file name to save to. Visit Vegipete's *Mite Library for cool programs. |
Hi Pete, that's more than FANTASTIC!. Completely meets specifications. Thank you very much! This is a step forward in making better programs for the CMM2. Even your presentation is an innovation! Kind regards Michael |
Features not implemented, but maybe possible: Multiple Selections: would that be files only, or files and directories? It won't span directory levels though. For xDel it would be files and directories. But if it were files only, that would be a great starting point. From there I can probably tweak it myself to include directories as well. Save File: needs a slightly changed dialog box with a text box that allows entering a name. But what about file types? For now, file saving could be a two step process: 1) let the user select where to save - a directory 2) ask the user for the file name to save to. Exactly. I was thinking of doing step 2) as a small pop-up over the GetFileDiag box, using the same window style as GetFileDialog itself. I don't understand the question about file types. What are file types? Epsilon CMM2 projects |
According to my understanding: "*.*", "*.bas*, "*.BMP" etc Michael |
Pondering... In the windowed world, a [Save As...] dialog lets you choose the location in the directory structure and lets you enter a file name. But it can also let you choose the file type. For example, in paint.net, you can save as .pdn or .png or .jpg or whatever. But maybe a rudimentary SaveFileDialog could ignore that part. The program itself ought to know what type of file it is saving, or the user can override this by entering whatever he wants. So SaveFileDialog would return a string containing the full path of the target save file, that may or may not have the characters ".<type>" on the end. The program must decide what to do with this. The multiple file selection problem I'm having right now is how to return the results. It's easy to over-fill a single string. @epsilon: What does xDel use? An array of strings? Visit Vegipete's *Mite Library for cool programs. |
In the windowed world, a [Save As...] dialog lets you choose the location in the directory structure and lets you enter a file name. But it can also let you choose the file type. For example, in paint.net, you can save as .pdn or .png or .jpg or whatever. But maybe a rudimentary SaveFileDialog could ignore that part. The program itself ought to know what type of file it is saving, or the user can override this by entering whatever he wants. So SaveFileDialog would return a string containing the full path of the target save file, that may or may not have the characters ".<type>" on the end. The program must decide what to do with this. Yes, I agree. The multiple file selection problem I'm having right now is how to return the results. It's easy to over-fill a single string. @epsilon: What does xDel use? An array of strings? Right now, nothing. It just prompts the user for a single directory to remove. But in a UI version of xDel I would add the capability to select multiple files and/or dirs. The current GetFileDialog API is very easy to use. You call it, magic happens, and you get back a simple string. Adding multiple file section to GetFileDialog would make it more complicated to use, so I wouldn't do that. Instead, I think it makes more sense to create a GetMultiFileDialog variant. To handle the output, I would provide an empty SUB that gets called once for each file/dir in the selection. It's then up to the developer integrating GetMultiFileDialog to provide an implementation for this SUB. e.g. 'isFile%=1/0 if fileDirname$ is a file/directory. SUB selectedFileDir(fileDirName$, isFile%) 'Implementation here please. END SUB (In other languages this would be handled by passing in a hook/callback/function pointer, but I haven't figured out yet if/how this can be done in MMbasic. I experimented a bit with EVAL where the caller passes in a function to call back as a string, but it didn't work.) Epsilon CMM2 projects |
Just to follow up on my own comment re callbacks. I was scanning through the user guide and came across the EXECUTE command, and that one works just fine for executing callbacks: CONST QUOTE$=CHR$(34) SUB printTheArg(arg$) print arg$ END SUB SUB dontCallMeIllCallYou callback$ PRINT "Hello "; EXECUTE callback$ + " " + QUOTE$ + "world" + QUOTE$ END SUB dontCallMeIllCallYou "printTheArg" Cheers, Ruben/Epsilon. Epsilon CMM2 projects |
vegipete, For my editors I need the option to specify a new file in the GetFileName dialog. I also need a SaveFileName Dialog. I added those two features as modifications to GetFile12. I butchered the demo program in the process. My apologies. I leave it up to you to integrate what I'm proposing into a new proper revision, if you agree with my approach that is. There's also a lot of room for code refactoring due to commonality between GetFileDialog and SaveFileDialog. I didn't go there because it's hard to make those changes in other people's code with respect for their design/implementation/style choices. The extended GetFileName has an 'N' key to specify a new file. When pressed, a line opens up a the cursor to allow the use to enter the file name. A check is added for duplicate file names. The SaveFileName dialog looks very much like GetFileName, but here Enter is used to open a line at the cursor for the new file name. Cheers, Ruben/Epsilon GetSaveFile13.zip Epsilon CMM2 projects |
Hi Ruben, are you sure you uploaded the correct file? I couldn't figure out how it works. *Regards Michael PS I would think that an additional dialog window should be appended for SAVEFILE. Just my2c *This is just a message for information, not a complaint! Edited 2020-10-31 23:19 by twofingers |
Hi Michael, If that's the case, then this is probably not the right approach. When you start the program you first see the GetFile Dialog (Select File... in the window header). It works as before, but you may (or may not) notice there's now an 'N(ew)' option in addition to the usual controls (also see window header). So, in addition to selecting an existing file, you can specify a new file. After making your selection, a 2nd Dialog shows up. That's the SaveFile Dialog. It looks the same as the other one, but the window header says 'Save File...'. You navigate to where you want, press enter and then enter the name of the file to save. I would think that an additional dialog window should be appended for SAVEFILE. Do you mean that after navigating to the proper directory and pressing enter, another pop-up should appear that prompts you to enter the filename? Edited 2020-10-31 23:35 by epsilon Epsilon CMM2 projects |
I get an input line but it is too far away from the main window and is not deleted after input. Aaaggrhh! It only works when I type in a new filename first. Okay ... Do you mean that after navigating to the proper directory and pressing enter, another pop-up should appear that prompts you to enter the filename? Michael |
Well, whichever way I'm going to take this, I'll have to figure out why it's misbehaving so badly for you. That'll teach me, messing with other people's code. If it's not too much to ask, would you mind giving the attached version a spin, to see if it's any better? It's explicitly setting options, so it's less dependent on the user environment. I also fixed a bug for the 'file exists' case. GetSaveFile14.zip Epsilon CMM2 projects |
Hi Ruben, first of all I have to say that I respect you very much. I hope there is no doubt about that. I know how difficult it is. Sorry, I did not find a difference. I even compared both files because I believed I got the wrong version. It's not better now. I'd leave it to Pete. But that's up to you, obviously! But I still get this if I did'nt use the New File option first. I hope I haven't disheartened you too much. If you do, please ignore me. Michael |
I'm working on this... I've been expanding GetFile to include more functions. The resulting package may get named "UltraBox." Possible features: (some are done, some still pondering) FileDialog (for selecting and saving) YesNoDialog (or Accept/Cancel? Maybe program selects) InputStringDialog MessageBox (timed or 'Press a key to continue...' Is 255 characters enough?) ActivityBar ( Horizontal 0 to 100%, difficult because it needs call back by program.) I'm also looking at mouse awareness of these routines. The FileDialog routine has the following input at the moment: Sub FileDialog(result$() [,spec$][,x_position][,y_position][,height][,width]) ' Input: result$(): array to hold results, dim(1) for single result, more for multi ' spec$: optional - wildcard matching, plus following ' standard functions: ' "*" show all files, allow any file to be selected - default ' "*.BAS" show only request file types, standard MMBasic wildcard matching ' "<DIR>" show all files, allow only selection of directories ' multi-select functions: ' "<M>*" show and multi-select all file types ' "<M>*.BAS" show and multi-select specified file types ' "<MDIR>" show all, multi-select only directories ' "<MALL>" show all, multi-select files and directories ' save file function: ' "<SAVE>["starting value"]" show all, returns path of displayed directory + string ' from text box, which is initialized with the optional string. ' x_position: optional, default = centered dialog ' y_position: optional, default = centered dialog ' height: optional, height in characters of directory/file list, default 15 ' width: optional, width in characters of directory/file list, default 32 Visit Vegipete's *Mite Library for cool programs. |
Hi Pete, That's good news! I think Ruben will appreciate that too. Many thanks. Regards Michael |
I certainly do. Thanks Pete! I'm glad I got a way out of the mess that I appeared to have started here ![]() Epsilon CMM2 projects |
| elk1984 Senior Member Joined: 11/07/2020 Location: United KingdomPosts: 232 |
I've been expanding GetFile to include more functions. The resulting package may get named "UltraBox." "UltraBox"? It means nothing to me... Edited 2020-11-01 07:14 by elk1984 |
