Local Time 15:18 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: How to extend the BASIC library?
MauroXavier
Posted: 12:55pm 18 Sep 2020
  lizby said  Ok, now we're talking crazy. What would a MMBasic CSUB 8080/Z80+8086 emulator look like on the CMM2?
Now I'll just crawl back under my rock.
CP/M running on the CMM2 would be awesome.
Posted: 12:58pm 18 Sep 2020
Quite cool I think.  (If rather pointless & weird.)
With a "BIOS" (for BDOS/etc) as well?
IIRC, CP/M (aka CP/M-80) only used the 8080 instruction set, which is quite small...
Edited 2020-09-18 23:00 by JohnS
Posted: 02:10pm 18 Sep 2020
Z80+CP/M emulator with C source.
Womble
Posted: 02:21pm 18 Sep 2020
  jpusztai said  Feels like a DOSBOX kinda weekend coming up :)
In case anybody is having difficulty setting this up, here is a quick tutorial for Windows10x64, and some helpful links
1. Install DOSBox
2. Make a folder somewhere for your virtual HDD.  eg. C:\DOSAPPS  Within DOSBox this will become your C: drive
3. Edit your C:\Users\Womble\AppData\Local\DOSBox\dosbox-0.74-3.conf file located in the hidden AppData folder in your user profile (obviously change Womble to your UserName).  I usually create a shortcut on the desktop to open this file in notepad, its plain ascii text.
4. Add the following at the end of the file.  Should be fairly explanitory.
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
MOUNT C C:\DOSAPPS
PATH=Z:\;C:\;C:\DOSUTIL;
# Examples for mounting CD ISO's for games
# IMGMOUNT G C:\GAMES\PCDOS.iso -t iso
IMGMOUNT g: "C:\DATA\Digital Games\Warcraft2\warcraft2_roy.cue" -t iso
CALL SETTINGS.BAT
This mounts your virtual HDD folder, any cdrom images (in the example, I am loading a .bin .cue image of my Warcraft2 cd rom) you may need for software, sets up the DOS path and finally calls a batch file SETTINGS.BAT to finish configuring the DOS environment.
Note DOSBox always has a Z: drive, where the built in default utilities like MOUNT are located.  Also the # symbol in dosbox-0.74-3.conf comments out lines.
5. Create SETTINGS.BAT in the root of the virtual HDD folder, here is mine:
set path=z:\;c:\;c:\dosutil;c:\dosutil\dgedit\;
set editor=c:\dosutil\dgedit\
set list=c:\dosutil
c:
If your application install disks modify AUTOEXEC.BAT to setup the environment, this is where you copy those DOS commands.
6. Create any directories you may need for software, remember Dos 8.3 format names.  I usually have a folder called DOSUTIL in which I place QBASIC.EXE QBASIC.HLP and QBASIC.INI along with Vernon Buerg's excellent LIST utility and any editors, etc.
7. You can copy files to the virtual HDD folder from windows, or run the installation files from within DOSBox.  This article explains how to mount floppy disk images in case you do not have a real FDD
The DOSBox documentation is here and the WiKi
Another guide can be found here it is for Windows7, but the method is the same.
Modem support and IPX networking is available for old games, refer to the WiKi.  DOSBox also supports SoundBlaster and MIDI, it was after all designed for running games
Oh, and ALT-TAB toggles the DOSBox window to Full Screen.
Have fun.
Womble
Sasquatch
Posted: 04:47pm 18 Sep 2020
So here is a wild and crazy Idea:
MMBasic on the CMM2 is out of tokens for Commands and Functions.
Just about everything in a MMBasic program could be represented by a 16-bit (2Byte) token.
The first 4 bits (1..16) would encode the token type something like this:
1 Command
2 Function
3 Int literal
4 Int constant
5 Int variable
6 Float literal
7 Float constant
8 Float variable
9 String literal
10 String constant
11 String variable
12 User Subroutine
13 User Function
14-16 ...
The remaining 12 bits (1..4096) would be an index into the table for the token(s) of that type.
This leaves tons of room for future features.
This would take a bit of time for the tokenizer when the program is first run.  After that execution should be super fast.
This would be a major overhaul to the core of MMBasic.  But with the way Commands and Functions are tokenized now, MMBasic is already half way there?
Edited 2020-09-19 02:49 by Sasquatch
-Carl
Posted: 05:04pm 18 Sep 2020
  Quote  This would be a major overhaul to the core of MMBasic.
No: This would be a re-write to something that isn't MMBasic, wouldn't be adopted by Geoff or me, and would destroy the stability of the core language and piss off all the users (now into the thousands) who want to use the software rather than keep changing it.
William33
Posted: 07:29pm 18 Sep 2020
  jpusztai said
  William33 said  Sorry, but would it useful without a mouse?
Those old TUIs were designed to work without a mouse.
You either tabbed or arrowed around until you reached the target widget, or you used a shortcut key - note in the first screenshot every screen item has a unique letter in red or yellow, which is the keystroke associated with it.
Typical Windows BIOS configuration screens are an artifact of this keyboard-only UI method.
Yes, they can work without a mouse. As far as I remember using the Turbo Pascal Editor with a mouse was way more comfortable. This was called "Turbo Vision" and still works with Free Pascal. The windows are draggable which isn't possible with just the keyboard.
gevik
Posted: 08:10pm 18 Sep 2020
Unfortunately we won't be getting mouse support on the machine, But I think it would be possible to come up with a key combination that enables moving windows around.
Sasquatch
Posted: 08:47pm 18 Sep 2020
1.  I prefaced the post by saying it was a Wild and Crazy idea.
2.  I didn't suggest it would be simple, quick or easy.
3.  Never say Never!  Now that development on the CMM2 is winding down, "Someone" might undertake something like this, and if "Someone" could demonstrate that it works, it might be worth pursuing by the community.
4.  And just to be clear: Nobody should release any code, source, or executable based in any part on MMBasic Source Code without full participation and consent of the original authors!
Edited 2020-09-19 08:22 by Sasquatch
-Carl
RetroJoe
Posted: 11:26pm 18 Sep 2020
  Womble said   Oh, and ALT-TAB toggles the DOSBox window to Full Screen.
It's actually ALT-ENTER.
The week-end is upon us!
It's hard to believe all the stone-age UI crap we had to live through to arrive at modern GUIs. Anyone who whines about "Mac versus Windows" should be forced to use this thing for a couple of hours !!
I say that with the utmost respect for all the innovators who got us here. Once upon a time, these TUIs were the pinnacle of user interface design!
Edited 2020-09-19 09:29 by jpusztai
Enjoy Every Sandwich / Joe P.
Posted: 08:41am 21 Sep 2020
Problems running DOS programs. in Win10 - try using Win95 compatibility mode.
It works for many but not all.
William33
Posted: 08:52am 21 Sep 2020
  phil99 said  Problems running DOS programs. in Win10 - try using Win95 compatibility mode.
Better use DOSBox  - it works like a charm.
Nimue
Posted: 10:08am 21 Sep 2020
Next:  "Will it run Crysis".......
Posted: 10:11am 21 Sep 2020
  Nimue said  Next:  "Will it run Crysis".......
Of course it will, but typing it in and debugging it will cripple you for life.
JoOngle
Posted: 02:39pm 21 Sep 2020
Agree completely with Peter on this one...
...However, that said - what Wouldn't piss users off , would be an entirely NEW CMM2 language (on an entirely separate BIOS that doesn't run alongside CMM2, but you have to choose between the two) - would be an entirely new OS, or Basic or C or ASM or both if you have skills, however - don't expect Peter to code it for you :)
I've been dabbling in those thoughts myself, because I am very "games" oriented, so Blitz basic from Amiga is very close to my heart, and as it is now - Blitz basic's nature isn't close to MMBasics philosophy. I see MMBasic as a bit of a "jack-of-all-trades" that can essentially do it all, but limited in many ways when it comes to game specific features.
I've even had thoughts about a new ARM processor that is of the same type used in mobile phones that has the MALI 400-450 3D processor on it, it's Open GL compliant and would extend the gaming capabilities tremendously on a CMM version.
Imagine hardware sprites (that essentially are 3D polygons) where you can even map entire screens (think text or graphics terminals) onto the polygons itself.
A language where you can tell the sprites to go-from go-to a position just by move sprite 1, x,y,z to x1,y1,z1, size, mode, loop    etc.
Same with backgrounds
bitmap 1, x,y,z to x1,y1,z1, size, mode, loop etc.
bitmap 2, ....   (with layer priorities), essentially these are just polygons with memory mapped textures.
These chips are dirt cheap today, and it's very tempting to go that route. But oh the time, clock has only 24 hours in a day, wish we had 200 per day :D
But one can dream, no one is stopping anyone from making their own "whateverbasic" on the CMM2.
