Local Time 13:32 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : What am I doing wrong
lew247
Posted: 02:02pm 26 Nov 2020
I have this to parse
I can see I have one "list" so it needs to be something like
 Dim As integer d(9000)
 DIM STRING q=Chr$(34) '" symbol
DIM d$,icon$
system "wget -q -O- "+q$+"https://api.weather.com/v2/pws/observations/current?stationId=IMANCH7&format=json&units=m&apiKey=8320530003ba490ba0530003bae90b4e"+q$,d()
precip1$=JSON$(d(),"list[1].pop")'precipitation forecast
There is one list which is why I used list[1]
It doesn't work
so I tried
icon$=JSON$(c%(),"list[1].weather[1].icon")
That should have worked because there is one list and I wanted the first icon which is part of weather[1] but it doesn't work
I'm stumped
I don't actually want the icon, only the pop but the icon should have parsed using that code
  Quote  {"cod":"200","message":0,"cnt":40,"list":[{"dt":1606402800,"main":{"temp":281.03,"feels_like":278.53,"temp_min":280.31,"temp_max":281.03,"pressure":1021,"sea_level":1021,"grnd_level":1007,"humidity":81,"temp_kf":0.72},
"weather":[{"id":803,"main":"Clouds","description":"broken clouds","icon":"04d"}],"clouds":{"all":81},"wind":{"speed":1.92,"deg":225},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-11-26 15:00:00"},{"dt":1606413600,"main":{"temp":279.84,"feels_like":277.54,"temp_min":279.32,"temp_max":279.84,"pressure":1021,"sea_level":1021,"grnd_level":1007,"humidity":84,"temp_kf":0.52},"weather":[{"id":803,"main":"Clouds","description":"broken clouds","icon":"04n"}],"clouds":{"all":84},"wind":{"speed":1.45,"deg":204},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-26 18:00:00"},{"dt":1606424400,"main":{"temp":278.34,"feels_like":276.07,"temp_min":278.11,"temp_max":278.34,"pressure":1022,"sea_level":1022,"grnd_level":1008,"humidity":89,"temp_kf":0.23},"weather":[{"id":802,"main":"Clouds","description":"scattered clouds","icon":"03n"}],"clouds":{"all":45},"wind":{"speed":1.23,"deg":204},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-26 21:00:00"},{"dt":1606435200,"main":{"temp":277.4,"feels_like":275.37,"temp_min":277.37,"temp_max":277.4,"pressure":1022,"sea_level":1022,"grnd_level":1008,"humidity":91,"temp_kf":0.03},"weather":[{"id":802,"main":"Clouds","description":"scattered
Edited 2020-11-27 00:03 by lew247
Posted: 02:18pm 26 Nov 2020
Do you have OPTION BASE 1 so that the first array item is list[1]?
Otherwise the first array item is list[0].
(If I have understood correctly.)
lew247
Posted: 03:23pm 26 Nov 2020
No I don't have any Option Base set
I've tried these one by one, commenting one line at a time till I've tried all 4 versions
Dim As integer d(1000)
DIM icon$,icon1$,icon2$,icon3$
'icon$=JSON$(d%(),"list[0].weather[0].icon")'precipitation forecast
'icon1$=JSON$(c%(),"list[0].weather[1].icon")
'icon2$=JSON$(c%(),"list[1].weather[0].icon")
icon3$=JSON$(c%(),"list[1].weather[1].icon")
print icon$
print icon1$
print icon2$
print icon3$
This is the result of each
Editing - I can see I made a mistake
going to try again
Edited 2020-11-27 01:24 by lew247
lew247
Posted: 03:32pm 26 Nov 2020
icon1$=JSON$(d%(),"list[0].weather[1].icon")
icon2$=JSON$(d%(),"list[1].weather[0].icon")
icon3$=JSON$(d%(),"list[1].weather[1].icon")
print icon$,",","Test1"
print icon1$,",","Test2"
print icon2$,",","Test3"
print icon3$,",","Test4"
I really don't get why it isn't working
I've left the API key in there in case anyone wants to see if it's working their end
Edited 2020-11-27 01:43 by lew247
Posted: 04:51pm 26 Nov 2020
What is actually returned by your wget? Which I'm guessing is put into the integer array d() (which I suppose is actually a LONGSTRING)? This is, if you do
LONGSTRING PRINT d%()
lew247
Posted: 05:33pm 26 Nov 2020
  lizby said  What is actually returned by your wget? Which I'm guessing is put into the integer array d() (which I suppose is actually a LONGSTRING)? This is, if you do
I'm an idiot I had the wrong page I was calling
But I tried it again with the correct api address and got this
ERROR: Invalid JSON data
When I do LONGSTRING PRINT d%() I get this - but with no linefeeds
I can't copy and past from Pi-Crommite
  Quote  {"cod":"200","message":0,"cnt":40,"list":[{"dt":1606413600,"main":{"temp":279.93,"feels_like":277.68,"temp_min":279.32,"temp_max":279.93,"pressure":1021,"sea_level":1021,"grnd_level":1007,"humidity":85,"temp_kf":0.61},"weather":[{"id":803,"main":"Clouds","description":"broken clouds","icon":"04n"}],"clouds":{"all":80},"wind":{"speed":1.45,"deg":204},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-26 18:00:00"},{"dt":1606424400,"main":{"temp":278.63,"feels_like":276.42,"temp_min":278.11,"temp_max":278.63,"pressure":1022,"sea_level":1022,"grnd_level":1008,"humidity":89,"temp_kf":0.52},"weather":[{"id":802,"main":"Clouds","description":"scattered clouds","icon":"03n"}],"clouds":{"all":50},"wind":{"speed":1.23,"deg":204},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-26 21:00:00"},{"dt":1606435200,"main":{"temp":277.57,"feels_like":275.57,"temp_min":277.37,"temp_max":277.57,"pressure":1022,"sea_level":1022,"grnd_level":1008,"humidity":91,"temp_kf":0.2},"weather":[{"id":802,"main":"Clouds","description":"scattered clouds","icon":"03n"}],"clouds":{"all":38},"wind":{"speed":0.73,"deg":252},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-27 00:00:00"},{"dt":1606446000,"main":{"temp":277.22,"feels_like":275.3,"temp_min":277.19,"temp_max":277.22,"pressure":1021,"sea_level":1021,"grnd_level":1008,"humidity":90,"temp_kf":0.03},"weather":[{"id":802,"main":"Clouds","description":"scattered clouds","icon":"03n"}],"clouds":{"all":49},"wind":{"speed":0.49,"deg":33},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-27 03:00:00"},{"dt":1606456800,"main":{"temp":276.55,"feels_like":274.19,"temp_min":276.55,"temp_max":276.55,"pressure":1021,"sea_level":1021,"grnd_level":1007,"humidity":88,"temp_kf":0},"weather":[{"id":802,"main":"Clouds","description":"scattered clouds","icon":"03n"}],"clouds":{"all":32},"wind":{"speed":0.89,"deg":82},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-27 06:00:00"},{"dt":1606467600,"main":{"temp":276.7,"feels_like":274.44,"temp_min":276.7,"temp_max":276.7,"pressure":1020,"sea_level":1020,"grnd_level":1007,"humidity":83,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01d"}],"clouds":{"all":5},"wind":{"speed":0.59,"deg":104},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-11-27 09:00:00"},{"dt":1606478400,"main":{"temp":279.3,"feels_like":277.06,"temp_min":279.3,"temp_max":279.3,"pressure":1019,"sea_level":1019,"grnd_level":1006,"humidity":70,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01d"}],"clouds":{"all":2},"wind":{"speed":0.6,"deg":244},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-11-27 12:00:00"},{"dt":1606489200,"main":{"temp":278.7,"feels_like":276.48,"temp_min":278.7,"temp_max":278.7,"pressure":1018,"sea_level":1018,"grnd_level":1004,"humidity":74,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01d"}],"clouds":{"all":5},"wind":{"speed":0.61,"deg":168},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-11-27 15:00:00"},{"dt":1606500000,"main":{"temp":277.17,"feels_like":274.62,"temp_min":277.17,"temp_max":277.17,"pressure":1018,"sea_level":1018,"grnd_level":1004,"humidity":81,"temp_kf":0},"weather":[{"id":802,"main":"Clouds","description":"scattered clouds","icon":"03n"}],"clouds":{"all":42},"wind":{"speed":1.03,"deg":102},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-27 18:00:00"},{"dt":1606510800,"main":{"temp":276.58,"feels_like":273.81,"temp_min":276.58,"temp_max":276.58,"pressure":1018,"sea_level":1018,"grnd_level":1004,"humidity":83,"temp_kf":0},"weather":[{"id":804,"main":"Clouds","description":"overcast clouds","icon":"04n"}],"clouds":{"all":100},"wind":{"speed":1.3,"deg":99},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-27 21:00:00"},{"dt":1606521600,"main":{"temp":276.07,"feels_like":272.98,"temp_min":276.07,"temp_max":276.07,"pressure":1018,"sea_level":1018,"grnd_level":1004,"humidity":82,"temp_kf":0},"weather":[{"id":803,"main":"Clouds","description":"broken clouds","icon":"04n"}],"clouds":{"all":62},"wind":{"speed":1.61,"deg":90},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-28 00:00:00"},{"dt":1606532400,"main":{"temp":277.75,"feels_like":274.5,"temp_min":277.75,"temp_max":277.75,"pressure":1018,"sea_level":1018,"grnd_level":1004,"humidity":83,"temp_kf":0},"weather":[{"id":804,"main":"Clouds","description":"overcast clouds","icon":"04n"}],"clouds":{"all":93},"wind":{"speed":2.25,"deg":75},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-28 03:00:00"},{"dt":1606543200,"main":{"temp":277.09,"feels_like":274.17,"temp_min":277.09,"temp_max":277.09,"pressure":1018,"sea_level":1018,"grnd_level":1005,"humidity":92,"temp_kf":0},"weather":[{"id":803,"main":"Clouds","description":"broken clouds","icon":"04n"}],"clouds":{"all":70},"wind":{"speed":1.97,"deg":73},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-28 06:00:00"},{"dt":1606554000,"main":{"temp":278.18,"feels_like":275.43,"temp_min":278.18,"temp_max":278.18,"pressure":1020,"sea_level":1020,"grnd_level":1006,"humidity":91,"temp_kf":0},"weather":[{"id":803,"main":"Clouds","description":"broken clouds","icon":"04d"}],"clouds":{"all":55},"wind":{"speed":1.96,"deg":80},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-11-28 09:00:00"},{"dt":1606564800,"main":{"temp":280.67,"feels_like":278,"temp_min":280.67,"temp_max":280.67,"pressure":1020,"sea_level":1020,"grnd_level":1007,"humidity":86,"temp_kf":0},"weather":[{"id":803,"main":"Clouds","description":"broken clouds","icon":"04d"}],"clouds":{"all":72},"wind":{"speed":2.31,"deg":97},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-11-28 12:00:00"},{"dt":1606575600,"main":{"temp":280.76,"feels_like":278.33,"temp_min":280.76,"temp_max":280.76,"pressure":1020,"sea_level":1020,"grnd_level":1007,"humidity":87,"temp_kf":0},"weather":[{"id":804,"main":"Clouds","description":"overcast clouds","icon":"04d"}],"clouds":{"all":100},"wind":{"speed":2.03,"deg":82},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-11-28 15:00:00"},{"dt":1606586400,"main":{"temp":280.04,"feels_like":277.29,"temp_min":280.04,"temp_max":280.04,"pressure":1022,"sea_level":1022,"grnd_level":1008,"humidity":91,"temp_kf":0},"weather":[{"id":804,"main":"Clouds","description":"overcast clouds","icon":"04n"}],"clouds":{"all":90},"wind":{"speed":2.47,"deg":83},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-28 18:00:00"},{"dt":1606597200,"main":{"temp":279.79,"feels_like":277.48,"temp_min":279.79,"temp_max":279.79,"pressure":1023,"sea_level":1023,"grnd_level":1009,"humidity":93,"temp_kf":0},"weather":[{"id":802,"main":"Clouds","description":"scattered clouds","icon":"03n"}],"clouds":{"all":38},"wind":{"speed":1.86,"deg":85},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-28 21:00:00"},{"dt":1606608000,"main":{"temp":278.98,"feels_like":276.82,"temp_min":278.98,"temp_max":278.98,"pressure":1024,"sea_level":1024,"grnd_level":1010,"humidity":93,"temp_kf":0},"weather":[{"id":801,"main":"Clouds","description":"few clouds","icon":"02n"}],"clouds":{"all":23},"wind":{"speed":1.42,"deg":85},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-29 00:00:00"},{"dt":1606618800,"main":{"temp":278.59,"feels_like":276.43,"temp_min":278.59,"temp_max":278.59,"pressure":1024,"sea_level":1024,"grnd_level":1011,"humidity":90,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01n"}],"clouds":{"all":2},"wind":{"speed":1.18,"deg":77},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-29 03:00:00"},{"dt":1606629600,"main":{"temp":278.38,"feels_like":275.95,"temp_min":278.38,"temp_max":278.38,"pressure":1025,"sea_level":1025,"grnd_level":1011,"humidity":87,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01n"}],"clouds":{"all":1},"wind":{"speed":1.39,"deg":79},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-29 06:00:00"},{"dt":1606640400,"main":{"temp":278.59,"feels_like":276.39,"temp_min":278.59,"temp_max":278.59,"pressure":1026,"sea_level":1026,"grnd_level":1012,"humidity":86,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01d"}],"clouds":{"all":0},"wind":{"speed":1.07,"deg":83},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-11-29 09:00:00"},{"dt":1606651200,"main":{"temp":281.48,"feels_like":279.83,"temp_min":281.48,"temp_max":281.48,"pressure":1026,"sea_level":1026,"grnd_level":1012,"humidity":74,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01d"}],"clouds":{"all":0},"wind":{"speed":0.47,"deg":118},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-11-29 12:00:00"},{"dt":1606662000,"main":{"temp":280.75,"feels_like":279.2,"temp_min":280.75,"temp_max":280.75,"pressure":1026,"sea_level":1026,"grnd_level":1012,"humidity":78,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01d"}],"clouds":{"all":0},"wind":{"speed":0.34,"deg":231},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-11-29 15:00:00"},{"dt":1606672800,"main":{"temp":279.32,"feels_like":277.31,"temp_min":279.32,"temp_max":279.32,"pressure":1027,"sea_level":1027,"grnd_level":1013,"humidity":82,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01n"}],"clouds":{"all":0},"wind":{"speed":0.81,"deg":155},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-29 18:00:00"},{"dt":1606683600,"main":{"temp":278.6,"feels_like":276.73,"temp_min":278.6,"temp_max":278.6,"pressure":1027,"sea_level":1027,"grnd_level":1014,"humidity":85,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01n"}],"clouds":{"all":5},"wind":{"speed":0.56,"deg":209},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-29 21:00:00"},{"dt":1606694400,"main":{"temp":278,"feels_like":276.04,"temp_min":278,"temp_max":278,"pressure":1028,"sea_level":1028,"grnd_level":1014,"humidity":88,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01n"}],"clouds":{"all":2},"wind":{"speed":0.67,"deg":212},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-30 00:00:00"},{"dt":1606705200,"main":{"temp":277.61,"feels_like":275.42,"temp_min":277.61,"temp_max":277.61,"pressure":1027,"sea_level":1027,"grnd_level":1014,"humidity":88,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01n"}],"clouds":{"all":1},"wind":{"speed":0.9,"deg":213},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-30 03:00:00"},{"dt":1606716000,"main":{"temp":277.36,"feels_like":275.23,"temp_min":277.36,"temp_max":277.36,"pressure":1028,"sea_level":1028,"grnd_level":1014,"humidity":89,"temp_kf":0},"weather":[{"id":801,"main":"Clouds","description":"few clouds","icon":"02n"}],"clouds":{"all":15},"wind":{"speed":0.79,"deg":232},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-30 06:00:00"},{"dt":1606726800,"main":{"temp":277.72,"feels_like":275.63,"temp_min":277.72,"temp_max":277.72,"pressure":1029,"sea_level":1029,"grnd_level":1015,"humidity":92,"temp_kf":0},"weather":[{"id":802,"main":"Clouds","description":"scattered clouds","icon":"03d"}],"clouds":{"all":48},"wind":{"speed":0.94,"deg":194},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-11-30 09:00:00"},{"dt":1606737600,"main":{"temp":279.71,"feels_like":277.9,"temp_min":279.71,"temp_max":279.71,"pressure":1029,"sea_level":1029,"grnd_level":1015,"humidity":89,"temp_kf":0},"weather":[{"id":803,"main":"Clouds","description":"broken clouds","icon":"04d"}],"clouds":{"all":71},"wind":{"speed":0.94,"deg":225},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-11-30 12:00:00"},{"dt":1606748400,"main":{"temp":279.91,"feels_like":278.03,"temp_min":279.91,"temp_max":279.91,"pressure":1028,"sea_level":1028,"grnd_level":1014,"humidity":91,"temp_kf":0},"weather":[{"id":804,"main":"Clouds","description":"overcast clouds","icon":"04d"}],"clouds":{"all":93},"wind":{"speed":1.19,"deg":234},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-11-30 15:00:00"},{"dt":1606759200,"main":{"temp":279.59,"feels_like":277.68,"temp_min":279.59,"temp_max":279.59,"pressure":1028,"sea_level":1028,"grnd_level":1015,"humidity":93,"temp_kf":0},"weather":[{"id":804,"main":"Clouds","description":"overcast clouds","icon":"04n"}],"clouds":{"all":94},"wind":{"speed":1.23,"deg":271},"visibility":6135,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-30 18:00:00"},{"dt":1606770000,"main":{"temp":278.98,"feels_like":277.04,"temp_min":278.98,"temp_max":278.98,"pressure":1028,"sea_level":1028,"grnd_level":1015,"humidity":93,"temp_kf":0},"weather":[{"id":804,"main":"Clouds","description":"overcast clouds","icon":"04n"}],"clouds":{"all":99},"wind":{"speed":1.1,"deg":235},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-11-30 21:00:00"},{"dt":1606780800,"main":{"temp":278.63,"feels_like":276.4,"temp_min":278.63,"temp_max":278.63,"pressure":1028,"sea_level":1028,"grnd_level":1014,"humidity":93,"temp_kf":0},"weather":[{"id":804,"main":"Clouds","description":"overcast clouds","icon":"04n"}],"clouds":{"all":97},"wind":{"speed":1.42,"deg":235},"visibility":6816,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-12-01 00:00:00"},{"dt":1606791600,"main":{"temp":279.16,"feels_like":277.04,"temp_min":279.16,"temp_max":279.16,"pressure":1027,"sea_level":1027,"grnd_level":1014,"humidity":93,"temp_kf":0},"weather":[{"id":804,"main":"Clouds","description":"overcast clouds","icon":"04n"}],"clouds":{"all":99},"wind":{"speed":1.41,"deg":226},"visibility":6748,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-12-01 03:00:00"},{"dt":1606802400,"main":{"temp":278.75,"feels_like":276.44,"temp_min":278.75,"temp_max":278.75,"pressure":1027,"sea_level":1027,"grnd_level":1013,"humidity":92,"temp_kf":0},"weather":[{"id":804,"main":"Clouds","description":"overcast clouds","icon":"04n"}],"clouds":{"all":100},"wind":{"speed":1.52,"deg":225},"visibility":10000,"pop":0,"sys":{"pod":"n"},"dt_txt":"2020-12-01 06:00:00"},{"dt":1606813200,"main":{"temp":278.41,"feels_like":275.9,"temp_min":278.41,"temp_max":278.41,"pressure":1026,"sea_level":1026,"grnd_level":1013,"humidity":89,"temp_kf":0},"weather":[{"id":804,"main":"Clouds","description":"overcast clouds","icon":"04d"}],"clouds":{"all":91},"wind":{"speed":1.6,"deg":187},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-12-01 09:00:00"},{"dt":1606824000,"main":{"temp":280.37,"feels_like":277.64,"temp_min":280.37,"temp_max":280.37,"pressure":1026,"sea_level":1026,"grnd_level":1012,"humidity":81,"temp_kf":0},"weather":[{"id":803,"main":"Clouds","description":"broken clouds","icon":"04d"}],"clouds":{"all":71},"wind":{"speed":2.07,"deg":208},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-12-01 12:00:00"},{"dt":1606834800,"main":{"temp":280,"feels_like":277.63,"temp_min":280,"temp_max":280,"pressure":1025,"sea_level":1025,"grnd_level":1011,"humidity":85,"temp_kf":0},"weather":[{"id":803,"main":"Clouds","description":"broken clouds","icon":"04d"}],"clouds":{"all":64},"wind":{"speed":1.64,"deg":201},"visibility":10000,"pop":0,"sys":{"pod":"d"},"dt_txt":"2020-12-01 15:00:00"}],"city":{"id":6691255,"name":"Haughton Green","coord":{"lat":53.4412,"lon":-2.0983},"country":"GB","population":9000,"timezone":0,"sunrise":1606377237,"sunset":1606406283}}
lew247
Posted: 08:48pm 26 Nov 2020
I've wiped the SD card and started again with an older version of Stretch that I know works and Pi-Cromite 5.4.25 that I know works with this version of Stretch.
nothing I do works - it's driving me potty
system "wget -q -O- "+q$+"https://api.openweathermap.org/data/2.5/forecast?q=Haughton%20Green,%20GB&appid=0e661c0eb78b1f4b28419346ab6159db"+q$,d()
'icon$=JSON$(d(),"list[0].weather[0].icon")
'icon1$=JSON$(d(),"list[0].weather[1].icon")
'icon2$=JSON$(d(),"list[1].weather[0].icon")
'icon3$=JSON$(d(),"list[1].weather[1].icon")
icon$=JSON$(d%(),"list[1].main.temp")'test to try
lew247
Posted: 09:55am 27 Nov 2020
I got nowhere with the above so I tried something new again
Can anyone tell me why is returns an INTEGER and not a STRING? AND if the result what it's showing is correct
You can see where I tried it as a STRING and the result is below
'prec$ = "9"
'print prec$
prec = 8
print prec
system "wget -q -O- "+q$+"https://api.openweathermap.org/data/2.5/onecall?lat=53.43&lon=-2.10&units=metric&exclude=current,hourly,daily&appid=0e661c0eb78b1f4b28419346ab6159db"+q$,d()
'prec$=val(JSON$(d(),"list[1].minutely[1].precipitation"))
prec=val(JSON$(d(),"list[1].minutely[1].precipitation"))
'longstring print d()
'if prec$ = "0" then icond$ = "null"
'print prec$
print prec
I need to know why it's doing it so I can have some hope of getting the other one to parse
This is longstring print d()
  Quote  {"lat":53.43,"lon":-2.1,"timezone":"Europe/London","timezone_offset":0,"minutely":[{"dt":1606469220,"precipitation":0},{"dt":1606469280,"precipitation":0},{"dt":1606469340,"precipitation":0},{"dt":1606469400,"precipitation":0},{"dt":1606469460,"precipitation":0},{"dt":1606469520,"precipitation":0},{"dt":1606469580,"precipitation":0},{"dt":1606469640,"precipitation":0},{"dt":1606469700,"precipitation":0},{"dt":1606469760,"precipitation":0},{"dt":1606469820,"precipitation":0},{"dt":1606469880,"precipitation":0},{"dt":1606469940,"precipitation":0},{"dt":1606470000,"precipitation":0},{"dt":1606470060,"precipitation":0},{"dt":1606470120,"precipitation":0},{"dt":1606470180,"precipitation":0},{"dt":1606470240,"precipitation":0},{"dt":1606470300,"precipitation":0},{"dt":1606470360,"precipitation":0},{"dt":1606470420,"precipitation":0},{"dt":1606470480,"precipitation":0},{"dt":1606470540,"precipitation":0},{"dt":1606470600,"precipitation":0},{"dt":1606470660,"precipitation":0},{"dt":1606470720,"precipitation":0},{"dt":1606470780,"precipitation":0},{"dt":1606470840,"precipitation":0},{"dt":1606470900,"precipitation":0},{"dt":1606470960,"precipitation":0},{"dt":1606471020,"precipitation":0},{"dt":1606471080,"precipitation":0},{"dt":1606471140,"precipitation":0},{"dt":1606471200,"precipitation":0},{"dt":1606471260,"precipitation":0},{"dt":1606471320,"precipitation":0},{"dt":1606471380,"precipitation":0},{"dt":1606471440,"precipitation":0},{"dt":1606471500,"precipitation":0},{"dt":1606471560,"precipitation":0},{"dt":1606471620,"precipitation":0},{"dt":1606471680,"precipitation":0},{"dt":1606471740,"precipitation":0},{"dt":1606471800,"precipitation":0},{"dt":1606471860,"precipitation":0},{"dt":1606471920,"precipitation":0},{"dt":1606471980,"precipitation":0},{"dt":1606472040,"precipitation":0},{"dt":1606472100,"precipitation":0},{"dt":1606472160,"precipitation":0},{"dt":1606472220,"precipitation":0},{"dt":1606472280,"precipitation":0},{"dt":1606472340,"precipitation":0},{"dt":1606472400,"precipitation":0},{"dt":1606472460,"precipitation":0},{"dt":1606472520,"precipitation":0},{"dt":1606472580,"precipitation":0},{"dt":1606472640,"precipitation":0},{"dt":1606472700,"precipitation":0},{"dt":1606472760,"precipitation":0},{"dt":1606472820,"precipitation":0}],"alerts":[{"sender_name":"Go to UK Met Office","event":"Yellow Fog Warning","start":1606420800,"end":1606478400,"description":"ches may lead to some travel disruption. Slower journey times with delays to bus and train services possible. There is a chance of delays or cancellations to flights"}]}
EDIT:
I also tried  prec=val(JSON$(d(),"minutely[1].precipitation")) and
prec$=val(JSON$(d(),"minutely[1].precipitation"))
Edited 2020-11-27 20:01 by lew247
Posted: 10:34am 27 Nov 2020
Instead of using VAL() what happens if you
PRINT JSON$(d(),"list[1].minutely[1].precipitation")
It may be (*) it's not a string, in which case VAL() would give the error it does.
* i.e. almost certainly
lew247
Posted: 08:55pm 28 Nov 2020
It was something really stupid
I had to change one of the returned values from Integer to Float
This one (Hopefully) should be a lot easier
I need to get the first PROB value
I could use MID$ but I'm not certain that the length of the report will stay the same every day
It would be better if I could use FIELD$ or something similar but there are no commas
Is it possible to use spaces instead of commas using field$?
{"results":1,"data":["TAF AMD EGCC 282001Z 2820/2924 05003KT 8000 SCT010 TEMPO 2820/2918 3000 BR BKN008 PROB30 TEMPO 2903/2910 0300 FG BKN001 PROB30 TEMPO 2918/2924 0300 FG BKN001"]}
Edited 2020-11-29 06:56 by lew247
Posted: 09:45pm 28 Nov 2020
  Quote  Is it possible to use spaces instead of commas using field$?
Yes
  Quote  FIELD$( string1, nbr, string2 [, string3] )
Description:
Returns a particular field in a string with the fields separated by delimiters.
'nbr' is the field to return (the first is nbr 1). 'string1' is the string to search and 'string2' is a string holding the delimiters (more than one can be used).
I am not sure about on the RPi but I assume it's the same.
lew247
Posted: 08:26am 29 Nov 2020
lew247
Posted: 04:54pm 29 Nov 2020
After that stupid one that I actually saw when I read the manual (twice) but it never registered
This final one has me really stumped
it should be dead simple
This is the json output
{"results":1,"data":[{"wind":{"degrees":0,"speed_kts":3,"speed_mph":3,"speed_mps":2,"speed_kph":6},"temperature":{"celsius":8,"fahrenheit":46},"dewpoint":{"celsius":8,"fahrenheit":46},"humidity":{"percent":100},"barometer":{"hg":30.3,"hpa":1026,"kpa":102.59,"mb":1025.92},"visibility":{"miles":"2 2.11","miles_float":2.11,"meters":"3,000","meters_float":3000},"ceiling":{"code":"OVC","text":"Overcast","feet":300,"meters":91,"base_feet_agl":300,"base_meters_agl":91},"elevation":{"feet":256,"meters":78},"location":{"coordinates":[-2.27495,53.353699],"type":"Point"},"icao":"EGCC","station":{"name":"Manchester Airport"},"raw_text":"EGCC 291620Z AUTO VRB03KT 3400 BR OVC003 08/08 Q1026","observed":"2020-11-29T16:20:00.000Z","flight_category":"LIFR","clouds":[{"code":"OVC","text":"Overcast","feet":300,"meters":91,"base_feet_agl":300,"base_meters_agl":91}],"conditions":[{"code":"BR","text":"Mist"}]}]}
Put in an easier to read format it's
  Quote  {"results":1,
"data":[{
"wind":{"degrees":0,"speed_kts":2,"speed_mph":2,"speed_mps":1,"speed_kph":4},
"visibility":{"miles":"2 2.67","miles_float":2.67,"meters":"4,000","meters_float":4000},
"raw_text":"EGCC 291550Z AUTO VRB02KT 4300 BR OVC003 08/08 Q1026","observed":"2020-11-29T15:50:00.000Z","flight_category":"LIFR","clouds":[{"code":"OVC","text":"Overcast","feet":300,"meters":91,"base_feet_agl":300,"base_meters_agl":91}],"conditions":[{"code":"BR","text":"Mist"}]}]}
I ONLY need the BAROMETER.MB field
ONE of these should have worked but they throw a fit and give this result
mb$=JSON$(c(),"data.barometer.mb")
mb$=JSON$(c(),"data[1]barometer.mb")
mb$=JSON$(c(),"data.barometer[1]mb")
mb$=JSON$(c(),"data[1]barometer[1]mb")
print mb$
Edited 2020-11-30 02:56 by lew247
lew247
Posted: 05:17pm 29 Nov 2020
I really have been trying to understand why this won't work
I've even gone back to the manual in the hope it might help
  Quote  FIELD$( str$, field)or
FIELD$( str$, field, delim$)or
FIELD$( str$, field, delim$, quote$
PRINT FIELD$("aaa,bbb,ccc", 2, ",")Will print the string: bbb
PRINT FIELD$("text1, 'quoted, text', text3", 2, ",", "'")will print the string: 'quoted, text'
I really don't understand why they would print those strings from the examples given
Could anyone explain it to me in a simpler way that might help me figure out if I can use field$ to get the field I need?
json should have worked I really don't know why it isnt.
  Quote  JSON$(a%(), “name”)
JSON$(a%(), “coord.lat”)
JSON$(a%(), “weather[0].description”)
JSON$(a%(),”list[4].weather[0].description
IF I understand it right then mb$=JSON$(c%(),"list[1].barometer[0].mb") "SHOULD" work?
Edited 2020-11-30 03:25 by lew247
lew247
Posted: 06:21pm 29 Nov 2020
This should even have worked
m=LINSTR(c(),q$+"barometer"+q$+":")+3
W1$=LGETSTR$(c(),m,255)
press$ = FIELD$(W1$,4)
print "press$"
barometer is the section it starts at
adds 4 fields starting with 0
FIELD$(Q1$,4) is the mb section?
lew247
Posted: 09:09pm 30 Nov 2020
Does ANYONE know if there is a way to do this?
The code below works perfectly getting the high and low temperatures for today
I'd like to be able to get the next 10 days by using the "day_start_local" FIELD
Is there a way to do this or not?
It won't work with my code because it only stores the first 255 and I cannot get it do work the way I'd like to
Dim As integer c(15000)
system "wget -q -O- "+q$+"https://swd.weatherflow.com/swd/rest/better_forecast?api_key=API-KEY&station_id=35102&lat=53.439&lon=-2.106"+q$,e()
 n=LINSTR(e(),q$+"daily"+q$+":[")+8  'ie skip over "daily":["
 forecastdeg$=LGETSTR$(e(),n,255)
 t1$ = FIELD$(forecastdeg$, 8)
 t2$ = FIELD$(forecastdeg$, 9)
 tl1$ = MID$(t2$, 16) 'Temp high Today
 th1$ = MID$(t1$, 17) 'Temp High Today
If you want to see what the full API call returns just click HERE
Posted: 09:28pm 30 Nov 2020
Why are you using e() when c() is defined? And why are you using FIELD which only allows for 255-character string input instead of JSON, which takes longstring?
lew247
Posted: 09:50pm 30 Nov 2020
Sorry I copied the relevent bits out of the full program so it wouldn't fill this page with rubbish
I do have Dim As integer e(15000)
I had to use FIELD because I couldn't get JSON working no matter how much I tried
disco4now
Posted: 10:17pm 30 Nov 2020
Hi Lewis,
The LINSTR command allows a third parameter, the start position of the search.
So you can start your search where you want.
So look for string "day_start_local" instead of "daily", do this repeatedly in a loop, but each time start the search a bit further on so you don't find the same one again.
lastn=1
n=LINSTR(e(),"day_start_local",lastn)+8  '
lastn=n+10    'just add enough to get past this one so you dont find it again.
Just loop around the last two commands  10 times to get the next ten day.
You need to adjust the offset as its no longer 8, more like 17 or something now.
regards
Gerry
F4 H7FotSF4xGT
