Local Time 09:57 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: 270.000 lines of code per second, question
capsikin
Posted: 05:03am 21 Jul 2020
  berighteous said  Does the CMM2 processor have hardware math?  The horrible soul crushing experience with AppleSoft basic is that 6502 had no math above addition and subtraction, so doing something like this plot
takes several HOURS to draw.
Here's the applesoft code for this:
10 GOTO 40
20 XE = - X * S1 + Y * C1 : YE = -X * C1 * C2 - Y* S1 * C2 + Z * S2 : ZE = - X * S2 * C1 - Y *S2 * S1 + Z * C2 + RHO
30 SX = D * XE / Z E + CX : SY = CY - D * YE / Z E :RETURN
40 RHO = 30 : D = 350 : THETA = .1 : PHI = 1 : CX =140 : CY = 96 : S1 = SIN (THETA) : S2 = SIN(PHI) : C1 = COS (THETA) : C2 = COS (PHI)
50 DEF FN Z(X) = COS (.1 * (X * X + Y * Y))
60 HGR2 : HCOLOR= 3
70 FOR X = -20 TO 20 STEP .3
80 FL = 0
90 FOR Y = - 20 TO 20 STEP .07
100 Z = FN Z(X): GOSUB 20
110 IF SX < 0 OR SX > 279 OR SY < 0 OR SY > 191 THEN FL = 0 : GOTO 140
120 IF FL = 0 THEN FL = 1 : HPLOT SX,SY
130 HCOLOR=3:HPLOT SX,SY:HCOLOR=0:HPLOT SX,SY+1 TO SX,191
140 NEXT Y,X
150 PRINT CHR$(7):GET Q$:TEXT
Even in AppleWin on full speed (like 100x apple native) it took a few minutes to do.
I modified it to run on the CMM2 and it took about 15 seconds.
starttime=timer
10 GOTO 40
30 SX = D * XE / ZE + CX : SY = CY - D * YE / ZE :RETURN
' 50 DEF FN Z(X) = COS (.1 * (X * X + Y * Y))
FUNCTION FNZ(X)
 FNZ = COS (.1 * (X * X + Y * Y))
END FUNCTION
'60 HGR2 : HCOLOR= 3
80 FL = 0
100 Z = FNZ(X): GOSUB 20
120 IF FL = 0 THEN FL = 1 : PIXEL SX,SY
'130 HCOLOR=3:HPLOT SX,SY:HCOLOR=0:HPLOT SX,SY+1 TO SX,191
PIXEL SX,SY : LINE SX,SY+1, SX,191,,255 ' Colour 255 is blue, so I can see where it's drawing.
140 NEXT Y,X
'150 PRINT CHR$(7):GET Q$:TEXT
print @(0,200) "Time: ";timer-starttime
berighteous
Posted: 08:53am 21 Jul 2020
SWEET!  Thanks.
yeah, I had it plotting a dot in white and then drawing a black line down to the bottom of the screen to clear out anything under it to clean up the plot. The program came originally from "Microcomputer Graphics: by Roy E. Meyers 1982
I ordered my CMM2 on 7/2 from RicTech but it hasn't shipped yet.  I paid for the shipping upgrade to EMS so it should move faster and be trackable when it starts moving though!
mkopack73
Posted: 12:24pm 21 Jul 2020
  abraxas said  CMM2 definitely has hardware for floating point calculations. Whether the implementation of trig functions in MMBasic is speedy I don't know. Just port and test it. However, with the amount of RAM that CMM2 gives you it's trivial to optimize this by precalculating and storing SIN/COS outputs for a quarter of the circle to the accuracy that is required and then the cost of trig functions will be that of a lookup in an array. You can make this run on a CMM2 in seconds. Maybe faster.
Actually I just ran a little test - generated sin+cos using the MMBAsic functions for all
Integer angles from 0 to 90. Then regenerated then and put them into a 2D array (one column for sin one for cos). Then timed how long it would take to lookup the sin and cos for all 0-90 from the table.
Math functions took 2.212 ms
Look up table took 2.742 ms
So I’d say use the math functions!
berighteous
Posted: 04:47pm 21 Jul 2020
the remembered to convert degrees to radians before you calculated sines and cosines, right?
mkopack73
Posted: 06:08pm 21 Jul 2020
  berighteous said  the remembered to convert degrees to radians before you calculated sines and cosines, right?
Yes.
With the math functions version I do that conversion on the fly (in the loop)
With the table lookup I do it when populating the table not when performing the lookup. Which just shows how much slower the lookup is in that it’s not even having to perform the conversion to radians first.
Posted: 02:20pm 26 Jul 2020
New record with 5.05.04RC12. berighteous' code now takes 10.78 seconds
Edited 2020-07-27 00:25 by matherp
diabolus
Posted: 02:18am 12 Jun 2021
Necro thread bump, using the latest firmware posted in the last few days. Running a Circuit Gizmos Color Maximite 2 at 504Mhz.
Averages ~505,000
Edited 2021-06-12 12:19 by diabolus
