Local Time 18:02 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Monitors and Adaptors
panky
Posted: 12:03am 20 Jun 2020
Is there a test program to exercise all the modes?
Posted: 12:30am 20 Jun 2020
Try this one:
 ' test card for CMM2
 ' TassyJim May 2020
 OPTION EXPLICIT
 OPTION DEFAULT NONE
 DIM INTEGER wd, ht, wbox, sh, x, w, n, nn, m
 DIM FLOAT a
 DIM k$, imgtitle$, fname$
 DIM INTEGER c(8)
 c(0) = RGB(BLACK)
 c(1) = RGB(YELLOW)
 c(2) = RGB(CYAN)
 c(3) = RGB(GREEN)
 c(4) = RGB(MAGENTA)
 c(5) = RGB(RED)
 c(6) = RGB(BLUE)
 c(7) = RGB(WHITE)
 c(8) = RGB(64,64,64)
 cls
 DO
   SELECT CASE m
     case 0
       MODE 1, 8
     CASE 1
       MODE 1, 8
       nn = 10
       a = 1 ' aspect ratio used in the CIRCLE command.
       imgtitle$ =" MODE 1,8 Ratio "+str$(a,1,2)+" "
     CASE 2
       MODE 1, 12
       nn = 10
       imgtitle$ =" MODE 1,12 Ratio "+str$(a,1,2)+" "
     CASE 3
       MODE 1, 16
       nn = 10
       imgtitle$ =" MODE 1,16 Ratio "+str$(a,1,2)+" "
     CASE 4
       MODE 2,8
       nn = 8
       a = 1.08 ' aspect ratio used in the CIRCLE command.
       imgtitle$ =" MODE 2,8 Ratio "+str$(a,1,2)+" "
     CASE 5
       MODE 2,12
       nn = 8
       imgtitle$ =" MODE 2,12 Ratio "+str$(a,1,2)+" "
     CASE 6
       MODE 2,16
       nn = 8
       imgtitle$ =" MODE 2,16 Ratio "+str$(a,1,2)+" "
     CASE 7
       MODE 3,8
       nn = 4
       imgtitle$ =" MODE 3,8 Ratio "+str$(a,1,2)+" "
     CASE 8
       MODE 3,12
       nn = 4
       imgtitle$ =" MODE 3,12 Ratio "+str$(a,1,2)+" "
     CASE 9
       MODE 3,16
       nn = 4
       imgtitle$ =" MODE 3,16 Ratio "+str$(a,1,2)+" "
     CASE 10
       MODE 4,8
       nn = 4
       a = 0.833 ' aspect ratio used in the CIRCLE command.
       imgtitle$ =" MODE 4,8 Ratio "+str$(a,1,3)+" "
     CASE 11
       MODE 4,12
       nn = 4
       imgtitle$ =" MODE 4,12 Ratio "+str$(a,1,3)+" "
     CASE 12
       MODE 4,16
       nn = 4
       imgtitle$ =" MODE 4,16 Ratio "+str$(a,1,3)+" "
     CASE 13
       MODE 5,8
       nn = 4
       imgtitle$ =" MODE 5,8 Ratio "+str$(a,1,3)+" "
     CASE 14
       MODE 5,12
       nn = 4
       imgtitle$ =" MODE 5,12 Ratio "+str$(a,1,3)+" "
     CASE 15
       MODE 5,16
       nn = 4
       imgtitle$ =" MODE 5,16 Ratio "+str$(a,1,3)+" "
   END SELECT
   'PRINT imgtitle$ ' for debug
   if m = 0 then
     cls
     TEXT 400,100, "Video mode test",cm,5,1
     TEXT 400,180, "Ratio refers to the aspect ratio used in the circle command",cm,1,1
     TEXT 400,220, "Q to quit, P to save page as a BMP",cm,3,1
     text 400,260,"UP arrow to go back, any other key to advance",cm,3,1
   else
     wd = MM.HRES : ht = MM.VRES
     wbox = wd / 8
     FOR x = 0 TO 7
       BOX x*wbox,ht/4,wbox,ht/2,0,c(x), c(x)
     NEXT x
     FOR x = 0 TO wd-1
       sh = 255*x/wd
       LINE x,0,x,ht/12,1,RGB(sh,0,0)
       LINE x,ht/12,x,ht/6,1,RGB(0,sh,0)
       LINE x,ht/6,x,ht/4,1,RGB(0,0,sh)
       LINE x,ht*9/12,x,ht*10/12,1,RGB(0,sh,sh)
       LINE x,ht*10/12,x,ht*11/12,1,RGB(sh,0,sh)
       LINE x,ht*11/12,x,ht,1,RGB(sh,sh,0)
       LINE x,ht/2,x,ht*3/4,1,RGB(sh,sh,sh)
     NEXT x
     CIRCLE wd/2,ht/2, ht*15/32,3,a,c(7)
     sh = 0
     x = wd/2 - 55*nn/2
     FOR w = 10 TO 1 STEP -1
       FOR n = 1 TO nn
         sh = 255 - sh
         LINE x,ht*3/8,x,ht*5/8,w,RGB(sh,sh,sh)
         x = x + w
       NEXT n
     NEXT w
     BOX 0,0,wd,ht,3,c(7)
     BOX 1,1,wd-2,ht-2,1,c(5)
     TEXT wd/2,ht/2, imgtitle$,cm,1,1
   endif
   DO
     k$ = INKEY$
   LOOP UNTIL k$<>""
   IF k$ = "P" OR k$ = "p" THEN
     fname$ = MID$(imgtitle$,2)+".bmp"
     SAVE IMAGE fname$
     TEXT wd/2,ht/2, "Saved as "+fname$,cm,1,1
     DO
       k$ = INKEY$
     LOOP UNTIL k$<>""
   ENDIF
   IF k$ = "Q" OR k$ = "q" THEN EXIT DO
   'PRINT ASC(k$)
   IF ASC(k$) = 128 THEN
     m = m - 1
     IF m < 1 THEN m = 15
   ELSE
     m = m + 1
     IF m > 15 THEN m = 1
   ENDIF
 LOOP
 MODE 1,8 ' restore before ending program
 CLS
panky
Posted: 01:34am 20 Jun 2020
Thanks Jim, excellent. I have my CMM2 connected to an LG monitor, Flatron L1710S and at 1.08 ration, all modes are perfect.
Cheers,
Doug.
abraxas
Posted: 02:15am 22 Jun 2020
I’m having a mixed bit of luck with the CMM2 and a VGA-HDMI converter. While text is very sharp and clear everything on the screen is shifted exactly 7 pixels so that I have a small border from the right hand side and the corresponding 7 pixels cut off from the 100th character. Seems to occur in 800x600 resolution as well as 640x400 but not with 320x200
Does Maximite 2 offer any way to adjust the VGA timings? My adapter does not have any way to tweak its output and neither does my HDMI monitor beside aspect ratio toggle. The problem exists regardless of the aspect ratio I choose.
Here is the adapter I purchased: https://www.amazon.ca/QGeeM-Converter-adaptador-Computer-Projector/dp/B083K83NNX
And here is a screenshot of the problem
KeepIS
Posted: 03:50am 22 Jun 2020
Could be the adaptor, but the CMM2 is so new that very few people have used different adaptors with it. Obviously there's only one sure way to know, and that's to try a different monitor, not easy if you only have one. Some LCDs, especially the older units, have  horizontal and vertical position adjustments, my old unit also has clock and phase adjustments. Sorry can't be of more help, hopefully someone will know a bit more about that adaptor.
GregZone
Posted: 04:14am 22 Jun 2020
@abraxas  I'm not sure if it helps, but I'm using a Samsung 16:9 LCD Monitor with the analog VGA input.
I had a similar (same?) issue that you are describing, with the last digit of the year chopped off.
Fortunately my monitor had a horizontal position adjustment, which required me to move the picture (I believe) 8 pixels to the left, in order to get all the CMM2 screen displayed.
Of course, the LCD monitor's VGA input will be effectively replicating the function of your external VGA -> HDMI (Analog -> Digital video) adapter.
My first reaction was to wonder if the front porch timing was perhaps not adhering to a VESA 800x600/60Hz spec?  But, if this was the case, you'd assume this image alignment would be a more widespread problem?
abraxas
Posted: 05:42am 22 Jun 2020
  GregZone said  @abraxas  I'm not sure if it helps, but I'm using a Samsung 16:9 LCD Monitor with the analog VGA input.
Well I wonder if it just might be... I noticed today that Geoff in his CMM2 user manual a screenshot also has the last character chopped off... take a close look at the screenshot on page 17
Edited 2020-06-22 15:44 by abraxas
GregZone
Posted: 06:01am 22 Jun 2020
  abraxas said  Well I wonder if it just might be... I noticed today that Geoff in his CMM2 user manual a screenshot also has the last character chopped off... take a close look at the screenshot on page 17
Nice observation. Checking the User Manual, I can see that both full screen screenshots show the same missing last character (Pages 16 & 17), conmsistent with what we are both experiencing.
I wonder if it is a more widespread issue, but not everyone notices?
Here is a good summary of the VESA DMT 800x600/60Hz timing standard:
http://www.tinyvga.com/vga-timing/800x600@60Hz
Full spec (Page 26), can be found here also:
https://glenwing.github.io/docs/VESA-DMT-1.13.pdf
Could probably scope it, but I guess Peter can comment on the timing implementation?
KeepIS
Posted: 06:08am 22 Jun 2020
I know mine shifts slightly with different modes and I remember that at the default monitor settings, the status bar was screen edge to screen edge, I was able to bring in the width and then centre it, this is with an LCD monitor with a VGA input, I just put the shift down to my 22 year old 19" LCD monitor.
I'll have to have a look at it on a HDMI monitor that has no adjustments when I get a chance.
Edited 2020-06-22 16:09 by KeepIS
KeepIS
Posted: 06:13am 22 Jun 2020
If you look at this post on the previous page, this is exactly how my status bar looks: Screen Shot
Posted: 07:19am 22 Jun 2020
The timing for 800x600 looks correct to me.
This is with displaying a white box
BOX 0,0,mm.hres,mm,vres,1,rgb(white),rgb(white)
Other modes look correct either filling the viewable window fully or slightly under.
Both front and back porch are correct or slightly longer for some modes. At no stage are they shorter than the specs.
Overall line frequency looks good. It's as close as my 20 year old CRO can determine.
This should mean that all modes should fit your display with maybe a slight visible shrinking with some modes.
My timing measurements do suggest that the full display should be visible in all modes.
I don't have a HDMI monitor in 4:3 format to test and all screens I have do have some adjustment available.
Andrew_G
Posted: 05:20am 28 Jun 2020
At least 10 years ago I needed to run two PCs but didn't have the desk space for two monitors, two mice, two keyboards and two sets of speakers (sound familiar so far?).
I bought a "Belkin Flip". It takes a USB Keyboard, USB Mouse, VGA and audio from two PCs and via a Y connector and, at the touch of a button, it shows the relevant information on the one monitor, uses the one keyboard and the one mouse (and audio) for either PC. The monitor auto adjusts the resolution.
It can be a bit temperamental but it is currently letting me use one monitor and I can switch between my PC and CMM2 (I have the mouse only connected to the PC).
BUT the keyboard will not play fair so I have two on my desk - much confusion!
Are there any more recent devices that would enable us to have just the one keyboard and monitor?
Cheers,
Andrew
