Local Time 17:36 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GFXterm64 for 64-bit Linux
Posted: 01:57pm 22 Apr 2020
Well... I got 32-bit lazarus with FPC (2.6.4) onto an oldish system.
Starts and looks plausible (rather cluttered, though).
I guessed I needed to open project1.lpi - seemed happy.
Trying Compile got me errors about
GetTickCount64
Int64
Not unreasonable :)
What next?
Posted: 04:47pm 22 Apr 2020
hi John,
   between these two lines:
var  PAL:array [0..15] of TColor;
{ TForm1 }
add in the following piece of code:
// returns an int64 tick counter, based upon GetTickCount with rollover detection
function GetTickCount64:int64;
const epoch:int64=0;               // ticks over in a tad under 50 days
       DW1:DWORD=0;
var     DW2:DWORD;
begin
 DW2:=GetTickCount;
 if DW2<DW1 then inc(epoch, $100000000);
 DW1:=DW2;
 result:=epoch+DW2
end;
i'm surprised that 32-bit lazarus doesn't already have GetTickCount64 built in, as the 49-day rollover is a bit embarrassing!
is the complaint about int64 a warning or an error?
rob   :-)
Posted: 07:25pm 22 Apr 2020
So now it doesn't like GetTickCount
(see below)
The moan about Int64 has changed and looks like they might be OK (or not?).
unit1.pas(278,23) Error: Identifier not found "GetTickCount"
serial.inc(76,16) Hint: Local variable "tios" does not seem to be initialized
engine.inc(135,38) Hint: Local variable "n" does not seem to be initialized
unit1.pas(433,3) Hint: Converting the operands to "Int64" before doing the multiply could prevent overflow errors.
unit1.pas(435,3) Hint: Converting the operands to "Int64" before doing the multiply could prevent overflow errors.
unit1.pas(437,3) Hint: Converting the operands to "Int64" before doing the multiply could prevent overflow errors.
unit1.pas(439,3) Hint: Converting the operands to "Int64" before doing the multiply could prevent overflow errors.
unit1.pas(653,42) Hint: Local variable "buffer" does not seem to be initialized
unit1.pas(2106) Fatal: There were 1 errors compiling module, stopping
Posted: 02:39am 23 Apr 2020
that's odd!
try this version instead:
const multiplier=24*60*60*1000;
begin
 Result:=trunc(Now*multiplier)
end;
while simpler, using Now is less desirable as it returns a double-precision float, and so the whole function becomes far more cpu intensive. GetTickCount64 is used quite extensively, so this is not ideal. but it will do for the moment!
the other messages, all warnings, should be of no concern. i get similar ones here.
rob   :-)
vegipete
Posted: 06:05am 23 Apr 2020
This latest version of GFXTerm reminded me to give the program a try. I don't currently have a Linux box running so I'm using the Windows version. I created a little program to test things out - the Game of Life.
This runs frighteningly slowly on an Armite F4 so you'll need a lot of patience on a slower micromite. Search for a program named "Golly" for something that runs somewhat faster on various computer platforms.
GFXTerm should be run with a larger window size - at least 80x36.
This version implements a 40x40 cell world and starts with a simple stick man standing on the bottom of the screen. From there, life takes over. Perhaps the stick man represents John.
' A short test program to play the Game of Life, invented
' by John Conway. Unfortunately, Covid19 took John's life
' on April 11, 2020. His legacy lives on in the coutless
' people inspired by his invention of the cellular automaton
' called the Game of Life and his other works.
' Written by vegipete, April 22, 2020 for use with GFXTerm.
Option DEFAULT INTEGER
Dim INTEGER i,j,count
Dim INTEGER xs,ys
Dim INTEGER sw,sh
Dim string GFX$
Dim float w(41,41)
GFX$ = Chr$(16)
Print GFX$ "?"  ' request size of GFXTerm Window
Input sw,sh ' grab dimensions - width and height
Print Chr$(27)+"[2J";   ' esc sequence to erase the text screen
Print "Thank you John Conway. Rest in Peace."
xs = 100: ys = 20
' clear the world to start
For i = 0 To 41
 For j = 0 To 41
   w(i,j) = 0
 Next j
Next i
' seed the world
w(19,31) = 3 : w(20,31) = 3 : w(21,31) = 3
w(19,32) = 3 : w(21,32) = 3
w(19,33) = 3 : w(21,33) = 3
w(20,34) = 3
w(17,35) = 3 : w(19,35) = 3 : w(20,35) = 3: w(21,35) = 3
w(18,36) = 3 : w(20,36) = 3 : w(22,36) = 3
w(20,37) = 3 : w(23,37) = 3
w(19,38) = 3 : w(21,38) = 3
w(19,39) = 3 : w(21,39) = 3
showWorld
Pause 2000
For i = 0 To 1000
 ConwayLife
 showWorld
Next i
End
' Calculate a new generation of life, using the classic rules
Sub ConwayLife
 Local integer i,j,count
 ' wrap the corners
 w(0,0) = w(40,40) : w(41,41) = w(1,1)
 w(0,41) = w(40,1) : w(41,0) = w(1,40)
 ' wrap the edges
 For i = 1 To 40
   w(0,i) = w(40,i) ' left
   w(41,i) = w(1,i) ' right
   w(i,0) = w(i,40) ' top
   w(i,41) = w(i,1) ' bottom
 Next i
 ' move most recent generation to previous and clear new geneartion
 For i = 1 To 40
   For j = 1 To 40
     w(i,j) = w(i,j) << 1
   Next j
 Next i
 ' calculate new generation
 For i = 1 To 40
   For j = 1 To 40
     count = Neighbours(i,j)
     If (w(i,j) And 2) Then  ' was cell alive last generation?
       ' yes so test if it stays alive
       If (count = 2) Or (count = 3) Then
         w(i,j) = w(i,j) + 1 ' cell remains alive for new generation
       EndIf
     Else
       ' no so test if it gets born
       If count = 3 Then
         w(i,j) = w(i,j) + 1 ' cell becomes alive for new generation
       EndIf
     EndIf
   Next j
 Next i
' return number of neighbours around given point
Function Neighbours(x,y)
 Local count
 count = 0
 If (w(x-1,y-1) And 2) Then count = count + 1
 If (w(x+0,y-1) And 2) Then count = count + 1
 If (w(x+1,y-1) And 2) Then count = count + 1
 If (w(x-1,y+0) And 2) Then count = count + 1
 If (w(x+1,y+0) And 2) Then count = count + 1
 If (w(x-1,y+1) And 2) Then count = count + 1
 If (w(x+0,y+1) And 2) Then count = count + 1
 If (w(x+1,y+1) And 2) Then count = count + 1
 Neighbours = count
End Function
' display the current world
Sub showWorld
 Local integer i,j
 xstart = 50
 Print gfx$ "C" 0,0,sw,sh
 Print gfx$ "I" 0,0,255,4
 For i = 1 To 40
   For j = 1 To 40
     If w(i,j) And 1 Then
       Print gfx$ "A" xs+10*i,ys+10*j,xs+6+10*i,ys+6+10*j,0,0
     EndIf
   Next j
 Next i
End
vegipete
Posted: 06:11am 23 Apr 2020
Oops, there's a glitch at the edge of the world in the Game of Life version I just posted above. I'll fix it tomorrow...
Posted: 06:29am 23 Apr 2020
GetTickCount64 no seems happy :)
Next problem (below) - sorry.
Also, I've upset lazarus-ide: all the windows went grey but I don't know what I did.  Seems to run, though.
edit: quit & reloading fixed the grey.  Odd.
Hint: Start of reading config file /etc/fpc.cfg
Hint: End of reading config file /etc/fpc.cfg
Free Pascal Compiler version 2.6.4 [2016/06/27] for i386
Copyright (c) 1993-2014 by Florian Klaempfl and others
Target OS: Linux for i386
Compiling project1.lpr
Compiling unit1.pas
serial.inc(29,5) Note: Local variable "tios" is assigned but never used
engine.inc(435,12) Note: Local variable "x" not used
unit1.pas(428,3) Hint: Converting the operands to "Int64" before doing the multiply could prevent overflow errors.
unit1.pas(430,3) Hint: Converting the operands to "Int64" before doing the multiply could prevent overflow errors.
unit1.pas(432,3) Hint: Converting the operands to "Int64" before doing the multiply could prevent overflow errors.
unit1.pas(434,3) Hint: Converting the operands to "Int64" before doing the multiply could prevent overflow errors.
unit1.pas(648,42) Hint: Local variable "buffer" does not seem to be initialized
unit1.pas(130,27) Hint: Parameter "Sender" not used
unit1.pas(131,27) Hint: Parameter "Sender" not used
unit1.pas(132,27) Hint: Parameter "Sender" not used
unit1.pas(133,27) Hint: Parameter "Sender" not used
unit1.pas(99,28) Hint: Parameter "Sender" not used
unit1.pas(98,27) Hint: Parameter "Sender" not used
unit1.pas(100,25) Hint: Parameter "Sender" not used
unit1.pas(102,48) Hint: Parameter "Shift" not used
unit1.pas(107,30) Hint: Parameter "Sender" not used
unit1.pas(108,28) Hint: Parameter "MousePos" not used
unit1.pas(112,31) Hint: Parameter "Sender" not used
unit1.pas(114,31) Hint: Parameter "Sender" not used
unit1.pas(115,31) Hint: Parameter "Sender" not used
unit1.pas(116,31) Hint: Parameter "Sender" not used
unit1.pas(117,30) Hint: Parameter "Sender" not used
unit1.pas(120,31) Hint: Parameter "Sender" not used
unit1.pas(121,30) Hint: Parameter "Sender" not used
unit1.pas(128,31) Hint: Parameter "Sender" not used
unit1.pas(93,26) Hint: Parameter "Sender" not used
unit1.pas(94,27) Hint: Parameter "Sender" not used
unit1.pas(89,46) Hint: Parameter "Sender" not used
unit1.pas(90,48) Hint: Parameter "Sender" not used
unit1.pas(147,7) Hint: Local const "SoftwareKey" is not used
unit1.pas(237,7) Note: Local variable "CPC" not used
project1.lpr(17,15) Error: identifier idents no member "Scaled"
project1.lpr(23) Fatal: There were 1 errors compiling module, stopping
Edited 2020-04-23 16:31 by JohnS
Posted: 07:58am 23 Apr 2020
you need to comment out (with "//")the line Application.Scaled:=True; in the file project1.lpr as per below:
program project1;
{$mode objfpc}{$H+}
uses
 {$IFDEF UNIX}{$IFDEF UseCThreads}
 cthreads,
 {$ENDIF}{$ENDIF}
 Interfaces, // this includes the LCL widgetset
 Forms, Unit1
 { you can add units after this };
{$R *.res}
begin
 RequireDerivedFormResource:=True;
//Application.Scaled:=True;            ( <--- this line should be commented out )
 Application.Initialize;
 Application.CreateForm(TForm1, Form1);
 Application.Run;
end.
i'm not quite sure why the ide even puts it in there, the option has been set false in the main form anyway. must be something new between the version you are running and the one i have here.
btw, all those hints about "Sender" are spurious. every procedure called by an event (which is most) has a pointer to the calling procedure passed in, but this pointer is very rarely used. there is no way to prevent the pointer being passed, as it is a part of the mechanics that ties the whole 'visual engine' of the application together.
rob   :-)
Edited 2020-04-23 17:58 by robert.rozee
Posted: 11:58am 23 Apr 2020
It looks like it probably works... bearing in mind I'm not sure how I'd be sure!
I had to take
DoubleBuffered = False
out of unit1.lfm
(I didn't take any other uses of DoubleBuffered out.)
I don't understand why it seemed OK before, but no matter.
Using Run | Compile it was happy and so was Run | Build.
Run | Run gave me a Graphical VT window with a flashing red block cursor, which I'm guessing is right.
I don't have anything by way of a 'mite connected, though :)
Similarly, if I run the (3.6MB) project1 I also get the VT window with red cursor.
file project1 shows it as
./project1: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked, interpreter /lib, stripped
which to me is plausible.
Anyone want it?
Posted: 01:37pm 23 Apr 2020
i'm pretty sure that doublebuffered doesn't do much under linux. within GFXterm it can be turned on/off using the 'undocumented' key combinations ctrl-1 and ctrl-2. with the version of lazarus you are using, i'm picking it can not be set at design time, there are a few differences like that between lazarus and delphi.
i'd be keen to play and see how it works - i'm led to believe that modern 64-bit linux distros come with support to run 32-bit executables bundled. feel free to zip it up and upload it here, i much appreciate the effort you've gone to
rob   :-)
Edited 2020-04-23 23:39 by robert.rozee
Posted: 01:54pm 23 Apr 2020
It wasn't much work & you're welcome!
Attached.
gfxterm32.zip
Posted: 02:23pm 23 Apr 2020
wow - it works! well, i had to install some extra 32-bit modules, and if run from the console it spits out heaps of warnings while graphics commands are processed. but on-the-whole, pretty much a success.
i may need to get a 32-bit VM running at some point to tidy up the loose ends, but my confidence is very much bolstered.
rob   :-)
Posted: 06:02pm 23 Apr 2020
Good to hear!
Basically your code was in good shape.
Posted: 12:04pm 24 Apr 2020
well, this is embarrassing, there was a bug - quite a serious one in terms of usability.
if you typed in an incorrect port name when connecting, you'd thereafter be unable to connect to anything until you restarted GFXterm64. and when you restarted it, the incorrect port name would come up as the default.
this version fixes that, and includes the fixed serial.inc (where the problem was) in case you want to recompile the source code in the earlier post.
GFXterm64 (24-april-2020).zip
vegipete: really neat demo, look forward to you fixing the edge issue. hint: rather than counting up the neighbours for each cell (requiring approx 40 x 40 x 8 checks), you may find it quicker to have a second array called Count that is 40 x 40. before each iteration, clear this array (with ERASE Count and re-DIM it, then:
1. scan through w, and for just the cells that are occupied, increment the values in the 8 neighbouring cells of Count.
2. use the values now in Count instead of the function Neighbours(x,y).
for a spasely filled 'world' this will be much quicker.
rob   :-)
Edited 2020-04-24 22:06 by robert.rozee
