Local Time 17:36 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Digital potentiometer?
goc30
Posted: 01:54am 11 Apr 2020
  hitsware2 said  I have only used the 28 pin
and remember no problems .
in my prog, I have some times, bad value. Not big error, but bad (like 0.1 to 0.2v error) and after it give good value. It is an random small error.
to morrow I give you all my results on test prog
hitsware2
Posted: 03:52am 11 Apr 2020
There is bound to be some small error in the resistance.
As with any resistance ( temperature as one factor )
Look Here
Edited 2020-04-11 13:57 by hitsware2
my site
goc30
Posted: 08:22am 11 Apr 2020
hi
my values on test with mx170 28 pins
pot is between 3.3v and gnd
pot=1 give 3.v
const pincs=26  'Chip Select
const pinrel=16  'I have led on this pin
const pinvl=6  'analog pin in
dim i as integer
dim valpot as integer
dim valin as float
setpin pinrel,DOUT
SetPin pincs,dout
setpin pinvl, ain
Pin(pincs)=1
Pin(pinrel)=1
valpot=&h1  'value to output
SetTick 500, task1,1    ' task toggle led each 500ms
do
Pin(pincs)=0  'active cs
SPI open 10000000,0,16  'spi mode 0 in 16b
spi write 1,valpot   'adresse 0 + value
Pin(pincs)=1
SPI close
valpot=valpot+1
if valpot=>256 then valpot=1
pause(50)
  valin=pin(pinvl)
 print "pot=";str$(valpot);"   lue:";str$(valin)
loop
sub task1()
pin(pinrel)=(pin(pinrel) xor 1)
end sub
result
pot=3   read:3.2371
pot=4   read:3.11505
pot=5   read:3.1828
pot=6   read:3.21344
pot=7   read:3.27366  <--- error
pot=8   read:3.11129
pot=9   read:3.18064  <--- error
pot=10   read:3.13441
pot=11   read:3.1543  <--- error
pot=12   read:3.04892
pot=13   read:2.93226
pot=14   read:2.82151
pot=15   read:2.9914   <--- error
pot=16   read:2.82796
pot=17   read:2.87204  <--- error
pot=18   read:2.73763
pot=19   read:2.91398   <--- error
pot=20   read:2.88118  <--- error
pot=21   read:2.73387
pot=22   read:2.7172
pot=23   read:2.82527  <--- error
pot=24   read:2.67634
same prog in explorer64
RUN
pot=2   lue:3.251612856
pot=3   lue:3.224731136
pot=4   lue:3.199999954
pot=5   lue:3.174193503
pot=6   lue:3.148387051
pot=7   lue:3.1225806
pot=8   lue:3.096774149
pot=9   lue:3.070967698
pot=10   lue:3.045161246
pot=11   lue:3.019354795
pot=12   lue:2.995161247
pot=13   lue:2.968279527
pot=14   lue:2.941935441
pot=15   lue:2.918817162
pot=16   lue:2.893548345
pot=17   lue:2.867741894
pot=18   lue:2.841935443
pot=19   lue:2.816666626
pot=20   lue:2.793010712
pot=21   lue:2.767741895
pot=22   lue:2.741935444
pot=23   lue:2.716128993
pot=24   lue:2.692473079
pot=25   lue:2.664516091
pot=26   lue:2.640860177
pot=27   lue:2.616128994
Edited 2020-04-11 18:40 by goc30
goc30
Posted: 09:21am 23 Apr 2020
  Tinine said  @goc30
Is there a known problem with the SPI on the 28 pinner? It's this device that I am intending to use.
Craig
I found the origin of my value imprecision problem with digital pot.
this comes from the fact that I had not wired the 8Mghz quartz (with 2x22pf), so everything was more or less unstable. With quartz it became correct
goc30
Posted: 06:43am 24 Apr 2020
after doing a reverse test, it seems that the problem would not come from the presence or not of quartz, but perhaps from an instability of my power supply.
I will continue to test other configurations to find out where the problem comes from
Matherp
chip select on 26 or on 22 take same result
Edited 2020-04-24 16:45 by goc30
goc30
Posted: 01:41pm 25 Apr 2020
I confirm that after several tests, the problem concerning the imprecision of the output values, came from the poor quality of power converter
So be careful to choose this kind of circuit
for information: circuit to avoid
Posted: 08:28pm 25 Apr 2020
SM PSUs of all types can be noisy. I replaced a mains 9V PSU in a Rugby MSF clock for my mother with one of these type of modules and it couldn't lock onto the time source at all. Took it out and built up one using a transformer, bridge and a 7809 regulator... good as gold, locked on right away.
I suspect PSU in most cases where weird stuff is happening - not always on the money but a good portion of the time.
Definitely still room for a good old-fashioned linear PSU.
Edited 2020-04-26 06:29 by CaptainBoing
