Local Time 18:14 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Shocking insight into fake chips
rogerdw
Posted: 01:18pm 30 Dec 2020
Thanks CaptainBoing, though I didn't really understand too much of it.
The flash chips I fit are used to hold the firmware for various boards which are designed to be updated to new versions if necessary  ...  so I just load them with a version I've copied from a known good one and fit that.
When I return the boards they can reload whatever they require.
Cheers,  Roger
Haxby
Posted: 09:03am 13 Jan 2021
Well my "hcpl3120" optocoupler chips came in. This was my first ever order of any sort of chips from non-reputable sources, and was really an experiment to see what would rock up to my doorstep, if anything. These were from AliExpress. I ordered 60 of them.
I don't know if I should laugh or cry.
There was no static dissipative packaging. Just foam. As you can see it's a mish-mash of different versions of chips from who-knows-where. Some are visibly recycled from equipment. All have questionable markings. No manufacturer logos. Just the UL (RU) logo which is laughable.
I'll test a few to see if they work. Not holding my breath
It's amazing that this industry of dodgy components and recycled components even exists. Are there enough hobbyists and dodgy manufacturers around the world to fuel this line of work?
It must be on a pretty large scale to make a few dollars, but that implies that there is enough demand for the product. It just doesn't seem to make any sense to me.
BenandAmber
Posted: 10:43am 13 Jan 2021
The hy4008 is one of the 100 I ordered a few years ago
the 80 volt 360 amp 1.5 m ohm hy5608 is on the left in every picture
It is one of the 40 I ordered 3 weeks or so ago I ordered all they had in stock they now have more
They were a little bit more expensive than $1 us dollar 4008 but they were still really cheap
When I bought them the ad said it was going to take them months to get here
I don't think it even took a month but I can go back and look if it's important to somebody
I can also test them in any way someone would like me to they would just have to walk me through this test procedure
I do have a scope battery bank solar a crazy amount of components along with lots of test equipment set up in my back shed
Both came from the same store on aliexpress
The store is the one recommended by you guys Aztac or something
I never get it right I can look it up if someone doesn't no the one I am talking about
The hy4008 is just a touch shinier but the lighting is exaggerating it way more than it actually is in the one photo
I have no clue it's either one of these are fake or real
I do know that the hy4008 has gave me no problem
I have gave a few hy4008 to friends that would know and they have not complained about them
If anyone has any questions feel free to ask I should be on here a lot more often I have been the last few months
As always thank you for your time and especially thank you for your patience with me
