Local Time 14:54 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBASIC compiler - opnions wanted
Posted: 12:51pm 20 Apr 2019
  tomxp411 said  I actually tried to compile MMBASIC on Windows 10, and there were a lot of issues, mostly the use of older APIs that aren't really supported on Windows 10 and Visual Studio 2019.
In December I found it trivially easy to compile mmbasic for DOS to add Peter Mather's longstring functions (for which he provided the source)--but that was on a Win7 laptop. I haven't tried it on a Win10 machine. I don't know much of anything about what kind of differences would make this work for win7 but not win10, but it surprises me that it would be difficult.
Posted: 02:07pm 20 Apr 2019
I just downloaded the recommended openWatcom C compiler and ran the compilation for DOS for mmbasic source downloaded on April 2 on my 64-bit Win10 laptop. The BuildAll.bat file ran to completion in 16 seconds, and the mmbasic.exe executable works, at least as far as PRINT "Hello, World" goes.
But perhaps the problem you have with it as far as your project goes is that openWatcom C is not your preferred tool--a 32-bit compiler that is no longer in active development (as far as I can tell--I think the version I just installed is from 2014). (I didn't want the impression to be left that MMBasic DOS could not be compiled on Win10 (which, of course, is not what you said)).
Edited by lizby 2019-04-22
tomxp411
Posted: 05:02pm 22 Apr 2019
  Quote  But perhaps the problem you have with it as far as your project goes is that openWatcom C is not your preferred tool--a 32-bit compiler that is no longer in active development (as far as I can tell--I think the version I just installed is from 2014). (I didn't want the impression to be left that MMBasic DOS could not be compiled on Win10 (which, of course, is not what you said)).
Correct. My target is the Windows 10 SDK, and the MMBASIC code isn't suitable for the Windows 10 SDK in its current state.
That's not a dig on Geoff's work. He's done a great job, but it would require a lot of time to port his code forward to C++ and the Windows 10 SDK.
And setting all that aside, I'd really like to make this open source. That's simply not an option with a work derived from Geoff's code.
Edited by tomxp411 2019-04-24
tomxp411
Posted: 05:06pm 22 Apr 2019
The Windows SDK has changed from the last one that was shipped for Windows 7. Among other things, certain functions are deprecated for security reasons. sprintf, for example, is obsolete and dangerous to use. Instead, string handling should be done with the STL string class.
And there's still the biggest issue: creating a derivative work based on Geoff's code means that I can't open source or sell it.
