Forum Index : Microcontroller and PC projects : Armmite L4: V5.05.02 - 64 pin support
I can live with the single precision EPOCH. I probably won't live to see 2038 anyway. But for normal maths, is the L4 single precision floats? It seems to be. Also A bug with FOR NEXT On the H7 the output is as expected: 5000000001 5000000002 5000000003 5000000004 5000000005 5000000006 5000000007 5000000008 5000000009 5000000010 5000000001 5000000002 5000000003 5000000004 5000000005 5000000006 5000000007 5000000008 5000000009 5000000010 On the L4, n does not get added to k% unless you assign n to an integer first. 5000000000 5000000000 5000000000 5000000000 5000000000 5000000000 5000000000 5000000000 5000000000 5000000000 5000000001 5000000002 5000000003 5000000004 5000000005 5000000006 5000000007 5000000008 5000000009 5000000010 I promise I will spend the rest of the day in the garden chasing a different kind of bug. Jim VK7JH MMedit |
L4 is single precision and behaves exactly the same in your example as an MM2 n+5000000000 is calculated as floats and therefore n disappears below the floating point precision. The fact you then assign to an integer is too late. H7 is double precision so no problem. I could make L4 double precision and have tested this but it is slower as it then doesn't use the FP hardware DP version attached for you to play with - interested in views 2018-12-10_191135_ArmmiteL4.zip |
SUPER! This is very useful for astronomical calculations! THANKS!!! Frank |
I've checked the double precision implementation using cdeagle's Solar Eclipse routines and it gives an exactly identical answer. Interestingly, the MM+ software double precision routines have some slight differences. |
Most of the time double precision isn't needed. Most of the time, speed is not really a major problem either. The problems occur when you try a write code to run on multiple devices and the differences leap up and bite you. Jim VK7JH MMedit |
New functionality 2018-12-12_052634_ArmmiteL4.zip ![]() This allows you to create any arbitrary waveform using the L4's inbuilt DACs The syntax is: DAC START frequency, DAC1array%() [,DAC2array%()] DAC1array%() and optional DAC2array%() should contain numbers in the range 0-4095 to suit the 12-bit DACs. The software automatically and separately uses the number of items in each of the arrays to drive the DACs. The frequency is the rate at which the DACs change value. So in the example code above there are 100 items in the array a%() which are displayed at a frequency of 100,000 Hz giving a sawtooth with a frequency of 100,000/100 = 1000Hz. There are 50 items in the array b%() which are displayed at a frequency of 100,000 Hz giving a reverse sawtooth with a frequency of 100,000/500 = 2000Hz. The output runs in the background and is stopped using the command DAC CLOSE NB: for the moment I have settled on double precision floating point |
Arbitrary waveforms will be very useful. Thanks for the continued work. Jim VK7JH MMedit |
sagt3k![]() Guru Joined: 01/02/2015 Location: ItalyPosts: 313 |
Hi matherp I'm trying "CPU SLEEP seconds [, abortpin] " on a some pins with Nucleo L4-32. But without effect, is this functionality implemented? Is there a dedicated wakeup pin? Can You confirm A0 on 48/64 pins? Edited: Sorry !! I see now pin definition A0 on 32pin.. thanks Thanks Antonio |
Hi matherp Apart from the possibility to dialogue with an external memory, the possibility of being able to access an SD/SPI remained or not on STM32L4xx? Thanks Antonio |
No, uses too much flash and anyway you can't have both flash drive and SD |
I got the L4 NUCLEO-L452RE-P board--512MB ($15.96 from Digikey). I connected as a usb drive and pasted in the bin file--I think the latest one, dated 2019-01-28. Connected with puTTY at 38400, hit enter, and got a ">" prompt. So far so good. I started to type and it froze. I once got as far as PRINT MM.VER and a response of 5.05.06. Reconnecting repeatedly always quickly produced freezes. Pressing the reset button gave me this: ![]() Am I doing something wrong or is this board not (yet) compatible? PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Certainly not compatible. The code reads the CHIP ID and uses it to configure RAM and FLASH usage. I don't know what the chip ID of the 452 is and haven't configured for it. Send me a PM with your email address and I'll send you a version of the code with a diagnostic to read the CHIP ID, then I can (hopefully) do some level of auto-configure. This of course assumes the H/W is basically identical - pinout , clock configuration, memory layout etc. |
| vincenthimpe Regular Member Joined: 14/10/2018 Location: United StatesPosts: 86 |
any chance of enabling the other two i2c controllers ? i frequently run out of addresses :) i'm working on a board layout for the 64 pin versions that can piggyback in a standard breadboard |
Why no definition for pin 28 (PB2) ? |
I'd been using it as a test output - will enable in next release Sorry not enough flash memory to support a duplicate I2C implementation |
