Local Time 15:49 04 Nov 2026 Privacy Policy
Forum Index : Electronics : New Charge Controller/Logger
Posted: 12:52pm 07 Apr 2009
The RS232 standard is not adhered to in the micro world much these days. 5V logic seems pretty normal now. Some older stuff is still fussy with 12V levels, and there will always be problems with distance transmissions. I will be looking into these units instead of needing a PC for data logging, when they become available.
Gordon.
mattvenn
Posted: 12:31am 08 Apr 2009
they're available to buy right now!
Posted: 01:45am 08 Apr 2009
the gadget linked to above.
available soon.
Gordon.
Janne
Posted: 02:11am 08 Apr 2009
  GWatPE said   The RS232 standard is not adhered to in the micro world much these days. 5V logic seems pretty normal now. Some older stuff is still fussy with 12V levels, and there will always be problems with distance transmissions. I will be looking into these units instead of needing a PC for data logging, when they become available.
Gordon.
I agree, many devices claiming to be RS 232 standard accept 0V / 5V signal levels. But if a device really has 5V / 0V outbound signal capasity it shouldn't be advertised as a RS232 device, instead it just should be "5V serial interface"
I too will be interested to look at these devices more, when they became available. With the pic device on board, there is enough ram available to write the whole blocks on the mmc card. This is the worst problem with direct access from picaxe to mmc, not enough ram on board to write the full 512 bytes on a block.
If at first you don't succeed, try again.
My projects
Dinges
Posted: 05:34am 08 Apr 2009
[quote=Gordon]The RS232 standard is not adhered to in the micro world much these days. 5V logic seems pretty normal now. Some older stuff is still fussy with 12V levels, [...][/quote]
The RS232 standard does NOT require 12V signal levels. Anything between +/- 3...25V (RX) and +/- 5...15V (TX) should do. If older stuff is fussy about needing 12V signals then it is because this older stuff doesn't adhere to the RS232 standard, as it should be able to work down to +/- 3V levels (RX) and +/-5V (TX).
But if the board Vasi linked to outputs TTL signal levels (0...+5V) then it is by definition not RS232 (as Janne already said); not because the +5V would be 'too low' below 12V, but because the 0V should really be -3...-25V (RX) and -5...-15V (TX). RS232 requires symmetrical output signals (+/-), not asymmetric (0...+5V) as TTL.
Peter.
vasi
Posted: 09:45am 08 Apr 2009
Peter.
Ok, right. Then the "confusion" is some how on computer industry territory (the recent computers does not have required levels on serial ports).
I think producers of that gadget are refering to protocol communication and not to voltage levels (..., 1200 bps, 2400, 9600, etc... as speed and then about data transmission ). Some of microcontrollers include hardware serial communication, others only a software simulation...
Maybe is just a general reference to serial communications (something common, known by anyone: hey look, is rs232, that mean serial comm, isn't it?).
Elvish name: Mablung Miriel
Beyound Arduino Lang
RossW
Posted: 12:18pm 08 Apr 2009
<i>the "confusion" is some how on computer industry territory (the recent computers does not have required levels on serial ports).</i>
"Serial" is not "RS232".
<i>Maybe is just a general reference to serial communications</i>
Serial merely means one bit at a time, sequentially. The ubiquitous USB is serial. SATA hard disks are serial. RS232, RS423 and RS485 are all serial. Fibre optic systems are serial. Your SPIF etc (optical) links for your hifi are serial. Ethernet (10base2, 10BaseT, 100BaseT even gigabit ethernet) are all serial.
Within the "Serial" category you have a whole host of sub-categories (synchronous, asynchronous, NRZI and hundreds more).
At the physical interface level the voltage, current etc are relevant. Older systems that used to use 20ma current loop use exactly the same sense and timing as their RS232 counterparts. RS232 has reasonable noise immunity (thats basically why the -3v to +3v "deadband" is there), but there are other problems with RS232, especially at high speeds and long runs. 20ma loop (which is readily adapted to/from RS232 using little more than a couple of optoisolators) had much better noise immunity but suffered at high speeds.
It is a pity that many people, especially those in technical and marketing roles, are either unaware of the difference between "Serial" and "RS232", or choose not to acknowledge the difference. It does indeed cause confusion and in some cases, damage of expensive equipment (you'll destroy the microcontroller if you stick RS232 up their serial input pin!)
vasi
Posted: 08:30pm 09 Apr 2009
http://surducan.netfirms.com/RS232.html
domwild
Posted: 06:37am 10 Apr 2009
Brian,
Good idea to use a PIC as an upgrade to the Picaxe. A PIC means more I/O ports, more variables, floating-point arithmetic and assembler or C.
Those of us new to electronics probably prefer a Picaxe with an associated loss of the advantages a PIC brings.
Winston Churchill
vasi
Posted: 10:41pm 11 Apr 2009
Another (possible) useful gadget:
K107 - Serial LCD Controller - a very good .pdf documentation file
You need to "spend" only one pin for comm. with this LCD. It comes as a kit for 9600 bps (PIC general use) or 2400 bps for PICAXE/8pin PIC's usage.
Is useful for testing/debuging in development process or for final product (e.g., as LCD display for picaxe08M logger!!!).
If you use it with Glenn's Windmill Controller/Charger (PICAXE28X), you can free 5 pins for other inputs!
K107 web page address
More info:
The project for PICAXE, with detailed info and examples of how to write Basic programs for PICAXE for displaying on LCD.
The project for PIC's with detailed info.
Edited by vasi 2009-04-13
vasi
Posted: 02:17am 22 Apr 2009
Another interesting resource:
A weather station which use a Nokia 3310 display. Very nice - worth browsing entire site.
And here another example of using the Nokia 3310 display (you can find it at a GSM center)
Posted: 07:06am 22 Apr 2009
The picaxe people already have an LCD interface ...033. I have one of these. Quite cheap as well. 1 output needed as well. The picaxe 08M only just has enough memory to display 4 readings on the LCD with useful tags. Decimal numbers, and changing sig digits can screw up the look as well. I have successfully displayed RPM, volts, Amps, W, on a 2 line x 16char LCD.
This was useful for spot checking. The code has to be bypassed or rewritten for PC use.
Gordon.
vasi
Posted: 05:46pm 22 Apr 2009
Thank you Gordon, I just read the datasheet of AXE033. This is good. So, both PIC and PICAXE have 1 wire LCD interface.
These LCD interfaces are built with microcontrollers and if you can't aquire one (any reason), then you must build one.
I found here a 2 wire interface. Does not need a microcontroller. Only the HD44780 LCD, one 74LS164 8-stage serial to parallel converter, one resistor, one diode and one pot. And in this page is also the software for PICAXE which can be adapted to PIC software.
vasi
Posted: 12:20pm 21 May 2009
Hi Bryan,
I'm not yet ready to start but I'm acquiring components (also for a serial LCD - one or two wires, or both variants -, to have as much inputs as possible).
Personally, I will try to contribute with JAL language and C if is possible (I think is ok if we can provide as many languages as possible?).
We can borrow all what we can from Glenn's logger design but if you can come with a design is ok. I want to have all what Gill suggested.
Didn't found PIC16F887
Vasi Edited by vasi 2009-05-22
vasi
Posted: 02:19pm 21 May 2009
I found a very interesting storage solution for PICAXE/PIC. Up to 2GB!
http://www.picaxeforum.co.uk/showthread.php?t=12448
http://www.4dsystems.com.au/prod.php?id=22
http://www.instructables.com/id/Simple-mass-storage-for-your -microcontroller-proje/
  Quote  The uDrive works from 3 to 5V so can interface to a wide range of controllers[/quote]
Edited by vasi 2009-05-23
Posted: 11:12pm 21 May 2009
commercial rs232 data logger
This is a link to a logger that was on one of the Google popups.
There is obviously more to it than just a pic chip and some EEprom, going by the cost.
Gordon.Edited by GWatPE 2009-05-23
