Local Time 00:38 12 Nov 2026 Privacy Policy
Forum Index : Solar : $8000 rebate means Tested
babbablacksheep
Posted: 06:02pm 24 Aug 2008
in the uk we get £2500 max..we only get £400 towards solar water heating we have to use special companys that charge £5000 TO £7000..they charge around £12000 for a 2kw wind turbine which you will recieve the full £2500 grant
you can get a 2kw wind turbine for around £3000 from a company but they will not be recomended by the government
so avoid the government grants and have £9500 in your pocket stupid or what..?????
mward
Posted: 06:34am 19 Jan 2009
$8 rebate will be scrapped and replaced by new scheme, the new scheme is expected to start on 1st Jul'09.
Essentially the new scheme will work as such >
- a Solar Power system is currently eligible for approx 25 ish Renewable Certificates (REC's)
- as of the 1st July Solar Power systems will still be eligible for REC's however they will be valued at 5 times the current 25 Rec value (eg. 100)
- if the value of REc's is approx $52 which is what they have been trading at recently this will equate to a rebate in the order of $5200
Whilst this is not quite the $8k everyone has been enjoying up till now - the means testing will be removed and businesses will also become eligible
michelle ward
Trev
Posted: 10:28am 24 Jan 2009
A partition has been written for a uniform gross feed in tarif for all renewable electricity.
http://www.feedintariff.com.au/
Read it and sign the partition if you agree
Trev @ drivebynature.com
