Local Time 11:19 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : E100 LCD Port Tester Thing.....
Chopperp
Posted: 11:16am 28 Apr 2018
@Grogster
QUOTE [DIM PACK%(8)=(00,15,14,03,07,25,02,23,06) 'Micromite Backpack pins]
The SC Micromite+ Explore 64 uses different pins for the ILI9341. Easy enough to change the software though to suit.
ChopperP
Azure
Posted: 04:55pm 28 Apr 2018
Here are the changes to add support for the SC Micromite Plus Backpack LCD Pins
'Insert after DIM PACK%(8)=...
DIM PACKP%(8)=(00,03,47,05,01,04,02,23,29) 'Micromite Plus Backpack pins
' Insert after Print "[4> ...
Print "[5> - Test Micromite Plus BACKPACK connections"
'Insert after Case "4"
Case "5"
For X=1 to 8
Setpin(PACKP%(X)),dout 'Set the Backpack Plus LCD pins as outputs
Next
For X=1 to 8 'Step through each pin, lighting an LED as we go
Pin(PACKP%(X))=1
Pause D
Pin(PACKP%(X))=0
Pause D
Next
Loop until Inkey$<>""
Goto BEGIN
Hope that helps.
