Forum Index : Microcontroller and PC projects : Quick One for TassyJim.
That would be good. Thanks Jim Another question: With Find/Replace, more times than not, I wish to go back to where I started the search. Is there anyway of Find/Replace just looping instead of stopping at the end of the search, or having an option to do this when "Not Found" comes up. Just askin' ChopperP ChopperP |
To get color and line number printout I open my .bas files with Geany. |
That works Thanks ChopperP ChopperP |
I have made a small change. You can now return to the line that you were at when you opened the "Find" dialog. Use the "return from SUB" button ![]() Extract the TKN file from the ZIP and replace the one in the MMEdit program folder. It includes the other changes to the Find functions a few weeks ago and the option to print to RTF with line numbers. 2018-02-25_151133_MMedit.zip I still haven't added the V5.4 syntax files. The number of different platforms being supported has risen to 7 or 8 so I have to do a major rethink of the syntax file system. I am still thinking... Jim VK7JH MMedit |
Works well Thanks Jim. Much appreciated ChopperP ChopperP |
@Jim, Anyone Another MMEdit Question. I may be missing something but is there a way of retaining the Bookmarks after a file save? Mine keep disappearing. ChopperP ChopperP |
You must have struck me in a good mood, this update will retain the bookmarks during a 'save' provided you are not using INCLUDE files. 2018-02-25_164707_MMedit.zip It was the 'include' process that cleared the bookmarks so I now skip that step if I don't detect any INCLUDE directives in your file. It shouldn't cause any other grief. Jim VK7JH MMedit |
Thanks Jim, Good to catch you in a good mood. I do have a couple more questions for you but they can wait for another day ChopperP ChopperP |
