Local Time 05:01 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.01.00 release candidates
     Page 19 of 19
Posted: 06:10pm 02 Dec 2025
@Peter,
With guidance of Jim I tried to find a clue on the problems with AUTOSAVE N.
Platform RP2040 VGA V6.01.00rc21
I can change the timing (delay per line) from 2 to 4 to 10 to 100, in all cases the same problem. Programs are transferred with errors, pieces missing, and on the terminal (and VGA screen) part of the listing is visible. There should be no listing with autosave N.
I tried a new (fresh from the blister) pico, and the exact same thing happened.
I tried without programming any options (normally I use option reset VGA design 2)
exact same happens.
But..
If I take a RP2040 Game Mite, load it with it's matching non-vga rc21, and transfer a program with MMEdit/MMCC it works fine.
I also imaged the pico from the VGA board with the non-vga image, set option reset gamemite, and connected an LCD. That works fine.
So it is not the pico/RP2040. It is something in the image of the RP2040 VGA.
I also tried rc15 (that is what I had available) and it has the same issue. So apparently it has been there for few weeks, but was not spotted before. I can only confirm it is not in b20, but b20 does not have support for AUTOSAVE N (that came in rc7).
Observation: once in my tests with VGA, with a high line delay in MMCC, I have seen that AUTOSAVE N showed a full listing scrolling on the VGA screen, as if AUTOSAVE did not have the N. But could not duplicate that.
I hope you can shed your light on this.
Posted: 06:32pm 02 Dec 2025
You still haven't told us what OS you are running and how you are running MMEdit on it. RC22 on RP2040 with OPTION RESET VGA DESIGN 2 works perfectly loading badapple on W11 from Teraterm with AUTOSAVE N. Have you tried replacing the cable?
' Bad Apple Demo para PicoMite HDMI/USB
' Autor: Marcos LM (2025)
'   - Version HQ: decodificador CSUB en C (320x240 @ 22 FPS)
'   - Version LQ: decodificador MMBasic   (160x120 @ 6 FPS)
' Requisitos:
'   - Firmware PicoMite HDMI/USB >= 6.00.03
'   - Archivos: ba.vid, balq.vid, ba.aud, ba.jpg en la SD
' Controles:
'   - Cursores arriba/abajo: seleccionar opcion
'   - ENTER                : aceptar
'   - ESC                  : parar reproduccion / salir
Option EXPLICIT
Option console serial
' Configuracion de video
Dim INTEGER vidWidth, vidHeight, vDelay,l
Dim FLOAT fps, totalFrames,total,high
Dim STRING vidFile, audFile,s
Drive "b:"
' Configuracion extra
Const HQ_DECODE = 0, LQ_DECODE = 1
Const T_ESC=27, T_ENTER=13, T_UP=128, T_DOWN=129
Const F_HANDLER    = 1   ' canal para la apertura del archivo
Const C_WHITE      = RGB(255,255,255)
Const C_GRAY       = RGB(128,128,128)
Const C_BLACK      = RGB(0,0,0)
Const SHOW_FPS     = 0   ' Muestra FPS actuales
Const SHOW_FPS_MIN = 0   ' Muestra el FPS mas bajo
Const LIMIT_FPS    = 1   ' Activa el limite a FPS objetivo
' Variables generales
Dim FLOAT frameIndex
Dim INTEGER x, y
Dim INTEGER runLen
Dim INTEGER bytesInChunk
Dim FLOAT targetTime
Dim FLOAT frameDuration
Dim FLOAT fpsCurrent
Dim FLOAT frameStartTime
Dim FLOAT fpsMin = 1000
Dim INTEGER selection   ' Menu
Dim integer x1(1299),x2(1299),y1(1299),f(500)
Dim integer cadd=Peek(varaddr f())+8 'point to the data in the longstring
Dim integer csadd=cadd
'get the address of the dimension size of y1
Dim integer y1add=Peek(varheader y1())+36
' Comprobacisn inicial
' Comprobar velocidad de CPU (debe ser 315000 KHz para sincronizar A/V)
Dim FLOAT cpuhz
cpuhz = Val(MM.Info(CPUSPEED$))
If cpuhz <> 315000000 Then
Print "Bad Apple demo expects CPUSPEED = 315000 (315 MHz)"
B  Print "Current: "; MM.Info(CPUSPEED$); " Hz"
Print
Print "Adjust with: OPTION RESOLUTION 640x480,315000"
End
EndIf
If totalframes Then Print total/totalframes
' Menu de Seleccion
' E inicializacion
selection = MenuSel()
' Ajustamos configuracion
   ' Demo con decoder BASIC
   vidWidth    = 319
   vidHeight   = 239
   fps         = 15
   vidFile     = "ba.vid"
   audFile     = "ba.aud"
   totalFrames = 4754
   targetTime  = 1000000/fps   ' ms por frame objetivo
   vDelay      = 0
' Salir
' Configuracion de pantalla y framebuffers
MODE 2 : Font 8
Color C_WHITE, C_BLACK
CLS
' Creamos un framebuffer donde dibujaremos y despues copiaremos al visible
' para evitar parpadeo (double buffering)
FRAMEBUFFER CREATE
FRAMEBUFFER WRITE N : CLS
FRAMEBUFFER WRITE F : CLS
' Abrir archivo de video
Open vidFile For INPUT As F_HANDLER
loadchunk 'prime the chunk buffer
' Lanzar audio
Play WAV audFile
Pause vDelay  ' ajuste de tiempo para cuadrar audio con video
SYNC targettime
' Bucle de reproduccion
Timer        = 0
fpsCurrent   = 0
frameIndex   = 0
' Dibujamos en F
FRAMEBUFFER WRITE F
Do While frameIndex < totalFrames
 CLS
 l=0
 loadchunk
 ' Carga de 'chunk' y decodificar frame completo
 For y = 0 To vidHeight
   ' Inicializar linea para nuevo frame
   x = 0
   Inc x,Peek(bp cadd)
   If x>vidWidth Then Continue For
   runlen=Peek(bp cadd)
   If runLen > 0 Then
     x1(l)=x
     x2(l)=x+runLen-1
     y1(l)=y
     Inc l
     Inc x,runlen
   EndIf
   Inc x,Peek(bp cadd)
   If runLen > 0 Then
     x1(l)=x
     x2(l)=x+runLen-1
     y1(l)=y
     Inc l
     Inc x,runlen
   EndIf
   Inc x,Peek(bp cadd)
   If runLen > 0 Then
     x1(l)=x
     x2(l)=x+runLen-1
     y1(l)=y
     Inc l
     Inc x,runlen
   EndIf
   Inc x,Peek(bp cadd)
   If runLen > 0 Then
     x1(l)=x
     x2(l)=x+runLen-1
     y1(l)=y
     Inc l
     Inc x,runlen
   EndIf
   Inc x,Peek(bp cadd)
   If runLen > 0 Then
     x1(l)=x
     x2(l)=x+runLen-1
     y1(l)=y
     Inc l
     Inc x,runlen
   EndIf
   Inc x,Peek(bp cadd)
   If runLen > 0 Then
     x1(l)=x
     x2(l)=x+runLen-1
     y1(l)=y
     Inc l
     Inc x,runlen
   EndIf
     Inc x,Peek(bp cadd)
     If x>vidWidth Then Exit
     If runLen > 0 Then
       x1(l)=x
       x2(l)=x+runLen-1
       y1(l)=y
       Inc l
       Inc x,runlen
     EndIf
     Inc x,Peek(bp cadd)
     If runLen > 0 Then
       x1(l)=x
       x2(l)=x+runLen-1
       y1(l)=y
       Inc l
       Inc x,runlen
     EndIf
 Next
'set the array size to the number of lines
 Poke word y1add,l-1
 If l Then Line x1(),y1(),x2(),y1()
 Poke word y1add,1299
 Inc total, Timer
 SYNC
 Timer =0
 FRAMEBUFFER COPY F, N
 Inc frameIndex
 If Asc(Inkey$) = T_ESC Then Play STOP : Exit Do
Close F_HANDLER
Do While MM.Info(SOUND)="WAV"
 Pause 20
Play STOP
FRAMEBUFFER CLOSE
' SUBs y Funciones
' Menu de seleccion
Function MenuSel() As INTEGER
Const NOPC = 2
Local STRING opciones(NOPC-1) = (" Bad Apple Demo    ", " Exit              ")
Local STRING ayudas(NOPC-1) = ("Lanzar version optimizada in Basic","Salir de la demo                 ")
Local INTEGER estado=0, tecla, i
Local INTEGER x=20, y=110
MODE 2 : CLS
Load JPG "ba.jpg"
 ' Pintar opciones
 Font 7
 For i = 0 To NOPC-1
   If i = estado Then
   Else
     Color C_BLACK, C_WHITE
   EndIf
   Text x, y + i * 10, opciones(i)
 Next i
 ' Texto de ayuda
 Font 8
 Color C_GRAY, C_WHITE
 Text 20, 230, ayudas(estado)
 ' Esperar tecla
   tecla = Asc(Inkey$)
 Loop While tecla = 0
 If tecla = T_ENTER Then Exit Do
 Play TONE 500, 550, 20
 Select Case tecla
   Case T_ESC
     estado = -1
     Exit Do
   Case T_UP
     If estado > 0 Then estado = estado-1
   Case T_DOWN
     If estado < NOPC-1 Then estado = estado+1
 End Select
Play TONE 1000,1000,20  ' Beep de confirmacion
Do While MM.Info(SOUND)="TONE"
 Pause 5
MenuSel=estado
End Function
' Lee un nuevo bloque del video comprimido (RLE)
Sub LoadChunk
 LongString right f(),f(),LLen(f())-(cadd-csadd)
 cadd=csadd
 Do While LLen(f())<3000
   s=Input$(250,1)
   If Len(s)=0 Then Exit
   LongString append f(),s
 bytesinchunk=LLen(f())
 If bytesInChunk = 0 Then
   FRAMEBUFFER CLOSE : Play STOP : Close F_HANDLER
   Print "EOF inesperado en frame"; frameIndex
   End ' Abortamos
 EndIf
Edited 2025-12-03 04:33 by matherp
Posted: 07:40pm 02 Dec 2025
@Volhout
In MMCC,inf line 48,
LineDelay = 120
try increasing it to 200
MMCC first tries 'AUTOSAVE N' and waits 3* linedelay for an error message. If an error is found, it tries 'AUTOSAVE' instead.
Also, can you try the same hardware and firmware with a Windows computer. I can't make it fail with any combination.
Posted: 08:28pm 02 Dec 2025
Hi Jim,
No, I can't anymore. My employer has taken admin rights from my work W11 laptop. Can't install MMEdit anymore. But...
I have a clue. On the linux PC I have tried to install Flatcam. Flatcam uses some QT libraries, and needed to update these. Maybe these involve communication drivers for the USB port.
I took a virgin Ubuntu 24.04 PC, Put MMEdit on it, QT5, and there it works correct.
Now I have to look for a way to revert these QT changes.
Sorry to have caused so much trouble.
P.S. still strange the non-VGA pico works fine. I will try your suggestion anyway.
Edited 2025-12-03 06:29 by Volhout
Posted: 08:40pm 02 Dec 2025
Jim,
I got it !!!
In MMCC in SETUP, change line endings to CRLF. Then you see what I am observing all the time. That makes the whole difference.
When set to LF, it works correct. No problems anymore,
Posted: 09:24pm 02 Dec 2025
It looks like you can have either LF or CR but not both.
I will probably change MMCC to use LF only for AUTOSAVE
Posted: 10:39pm 02 Dec 2025
For reference the file I tested with in W11 Teraterm is line terminated crlf and works fine
Posted: 05:04am 03 Dec 2025
The problem was with the test to see if the device could use 'AUTOSAVE N'. The double end-of-line had MMCC confused.
I need to test the fix on a few other devices before posting the fix.
Posted: 06:39am 03 Dec 2025
Peter, Jim,
Confusing was that MMCC stores its preferences in a global hidden file.
I have several folders each with a different version of MMEdit/MMCC, but they initialize from a file that is not local to that folder. So whatever earlier version I started, they all reverted to CRLF line ending for TX. (I changed that for a test once, and forgot to switch back).
There may be timing involved, since the non-VGA version of rc21 does handle the CRLF fine. But the VGA version chokes.
Thanks for looking at a fix. It could have happened to anyone. Why me again ?
Posted: 07:10am 03 Dec 2025
  Volhout said  Confusing was that MMCC stores its preferences in a global hidden file.
Not true.
In Windows the inf file is stored in 'appdata' for installed versions so will be common to all installed versions.
For the portable version, the inf files are always in a data folder that is in the program folder.
Likewise, for Linux, the inf files are always in a data folder that is in the program folder.
The files are NOT hidden but are only created on first use.
Posted: 11:05am 03 Dec 2025
  TassyJim said
Not true.
OK, that was an assumption from my side. Excuses.
It was what I convinced my self was happening, since I could not explain that earlier versions behaved the exact same (the ones that have autosave n).
Again, apologies for misleading information.
Posted: 08:26pm 04 Dec 2025
  matherp said  For reference the file I tested with in W11 Teraterm is line terminated crlf and works fine
With TeraTerm set to CRLF,
the line
Enter ctrl-Z, F1, or F2 to exit
is printed immediately after the AUTOSAVE N and before any code is pasted.
But with TeraTerm set to LF,
the line doesn't appear until the code starts being sent.
Either way, the code is successfully sent to the picomite with my limited testing.
I will change MMCC to only send LF after AUTOSAVE N. That seems to resolve my problem.
JanVolk
Posted: 08:32pm 04 Dec 2025
Peter,
Here are some tests with my mice.
Only Mouse Type: Standard 8-bit X/Y bits: 8/8 works with the editor.
PicoMiteHDMI MMBasic USB RP2350A Edition V6.01.00RC22
Copyright 2011-2025 Geoff Graham
Copyright 2016-2025 Peter Mather
> option list
OPTION SERIAL CONSOLE COM1,GP0,GP1
OPTION SYSTEM I2C GP20,GP21
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION HEARTBEAT OFF
OPTION PICO OFF
OPTION RESOLUTION 640x480 @ 252000KHz
OPTION HDMI PINS  1, 3, 7, 5
OPTION SDCARD GP22, GP6, GP7, GP4
OPTION RTC AUTO ENABLE
OPTION PLATFORM OLIMEX USB
> memory
Program:
  0K ( 0%) Program (0 lines)
176K (100%) Free
Saved Variables:
 16K (100%) Free
RAM:
  0K ( 0%) 0 Variables
  0K ( 0%) General
192K (100%) Free
 mx = DEVICE(MOUSE 2, x)
 my = DEVICE(MOUSE 2, y)
 mw = DEVICE(MOUSE 2, w)
 If mx <> tx Or my <> ty Or mw <> tw Then Print mx, my, mw
 tx = mx : ty = my : tw = mw
MINI KEYBOARD + MOUSEPAD AliExpress
> US USB Keyboard Connected on channel 1
 X/Y bits: 8/8
 Buttons: 2
 Report length: 9 bytes
 Has wheel: Yes (byte 1)   ' No wheel only a pad
 Has pan: No
USB Mouse Connected on channel 2
> run
44      36      0
43      36      0
42      35      0
41      34      0
> USB Keyboard Disconnected
> USB Mouse Disconnected
SilverCrest STMS 2219A1-M MOUSE and SilverCrest STMS 2219A1-K KEYBOARD
 X/Y bits: 8/8
 Buttons: 8
 Report length: 15 bytes
 Has pan: No
> run
96      39      23
94      41      23
94      43      22
90      43      22
hama 24182635 MOUSE and KEYBOARD Action 9,95 euro
> Mouse Type: Gaming 16-bit
 X/Y bits: 16/16
 Buttons: 5
 Report length: 10 bytes
 Has wheel: Yes (byte 5)
 Has pan: No
> run
28      15      21
28      14      21
28      13      21
28      12      21
Logitech M150 M/N:M-R007 MOUSE  K220 M/N::Y-R0035 KEYBOARD
> Mouse Type: High-res 12-bit
 X/Y bits: 12/12
 Buttons: 16
 Report length: 6 bytes
 Has pan: No
> run
639     479    -152
639     479    -153
639     479    -154
639     95     -155
639     95     -156
ville56
Posted: 04:06pm 05 Dec 2025
Peter,
wireless mice are behaving curious with RC22 ....
trying to use my old Logitech MK-320 wireless desktop which worked well on all MMbasic RCs before ...
> GR USB Keyboard Connected on channel 1
 X/Y bits: 12/12
 Buttons: 16
 Has pan: No
in the editor, the keypoard works ok but the mouse is so sensitive that the slightest move lets the cursor jump around 20+ lines ... same with a newer K270 desktop
On the other side a wireless Hama mouse is working, but to scroll 1 line you have to move the mouse about 10 cm.
Is there any way to adjust mouse movement sensitivity?
Gerald
73 de OE1HGA, Gerald
Posted: 04:21pm 05 Dec 2025
The issue is that the report descriptor does not include the dpi of the mouse. So, your 12-bit MK-320 mouse is presumably set to a high DPI whereas my 12-bit mouse isn't. In boot mode as they were configured before (no wheel) they presumably have to return a specific dpi. I'll have a think about how to allow the user to adjust the sensitivity.
     Page 19 of 19
