Forum Index : Microcontroller and PC projects : PicoMiteHDMIUSB motherboard reference design
| okwatts Regular Member Joined: 27/09/2022 Location: CanadaPosts: 93 |
Hi Just bumping this topic as I finally got around to ordering the 2B version but didn't order the panels as PCB's. After printing this version on my 3D printer I realized that the one called Korper2.stl was for the original Pico2 version. Has anyone converted the new version suitable for 3D printing or at least can someone instruct me on how to convert to STL from either the gerbers or the DXF files. ( My knowledge of Fusion expired a long time ago). I will have 3 for sale with case and possible proper panels for anyone in Canada. If interested let me know. Unfortunately with shipping,duties etc and the poor exchange rate they work out to $80 CDN plus shipping cost. |
Hi, I extruded (1.7 mm) the DXF file (2025-03-22_041114_HDMIUSBV2.0B.zip) (https://www.thebackshed.com/forum/ViewTopic.php?TID=17301&P=11#236097) again using Fusion and tested it with Cura. To me, it looks very similar to the images shown above. Maybe it will help someone. HDMIUSBV2.0Bstl.zip Regards Michael Edited 2026-05-06 18:00 by twofingers |
I thought I had thanked you Michael for posting this, but it seemed to disappear. It works fine for me on my boards and cases. Thanks again. |
Old thread resurrected and recycled.... :) Has anyone in the UK got one of the latest HDMIUSB reference designs (4 holes and I2S audio) for sale? Further afield would be ok, but the cost of posting it almost certainly clobbers that. . Edited 2026-05-28 17:09 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
Are you referring to the one as per my post on page 12 of this thread? If so, I think I may have (I can look in workshop tomorrow and confirm…..) |
Yes, that's the one. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
Mick: I have four available PCBs, two with PSRAM installed (genuine Mouser part), and two without (but can be added). I also have the Front and Rear panels (black PCB with white text), and somewhere I have the cases too (not located those yet). Will load the latest Firmware, however, with the speed Peter works, it will be several versions out of date! Let me know if you're still interested in any of the above, and if so, simply drop me a PM with your preferred shipping address. |
Spot the difference |
BT ? WIFI ? Volhout PicomiteVGA PETSCII ROBOTS |
yup |
That's cruel... Just as I was thinking of getting one of the existing design... lol Mick Zilog Inside! nascom.info for Nascom & Gemini |
| Bleep Guru Joined: 09/01/2022 Location: United KingdomPosts: 875 |
Hi Folks, Does anyone in the UK or possibly EU have a spare older version of Peters HDMIUSB ref. design, the type that you solder your own Pico2 to it, I've just gone and bought 2x Pico2W so I could check out the new BlueTooth firmware (before Peter showed us the new HDMIBTH layout) :-( Happy to pay for board and postage. Thanks. Regards Kevin. |
