Local Time 11:53 12 Nov 2026 Privacy Policy
     Page 15 of 25
Posted: 08:20am 25 Oct 2024
A lot of development has happened since 5.08. :)
This is a stopgap file that is intended ro fill the gap since the 5.08 manual and is more or less up to date:
MMBasic catchup - 22-10-24.pdf
RC9 is the latest, but is basically a bug-squashing release. I'm not aware of anything new in it.
Posted: 11:32am 25 Oct 2024
V6.00.00RC10
PicoMiteRP2350V6.00.00RC10.zip
PicoMiteRP2040V6.00.00RC10.zip
I've reverted to compiler version 12.2.1 as it generates slightly faster code than the current version
Changes USB channel allocations so that:
This will always try and allocate slot 1 to the keyboard and slot 2 to a mouse.
It will always try to allocate slot 3, if free, to the first game controller and slot 4 to the second.
In the event that you are trying to use three of more game controllers or two or more keyboards or mice then this of course will break down and the extra ones will be allocated to the highest available slot.
In addition, this version now assumes that generic gamepads pid/vid use either 2079/58369 or
2064/58625 so you shouldn't see the phantom (NB: Sony ds3/ds4 are already handled separately)
Hopefully, this change doesn't exclude any of the available generics but if anyone does find a gamepad is no longer found then please run the previous posted version and report the VID/PID to me so I can special case it as well.
This version also unlocks the ADC speed for the ADC command. Valid total frequecies are now anywhere between CPU_speed_in_Hz/96/65536 and CPU_speed_in_Hz/96.
Normal ADCinput using the pin function is not affected and uses the default sampling rate.
stanleyella
Posted: 04:51pm 25 Oct 2024
it didn't change options, which is safe now, only if necessary?
option list
PicoMiteHDMI MMBasic USB Version 6.00.00RC10
OPTION AUTORUN  ON
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION KEYBOARD UK, 0, 0, 600, 150
OPTION CPUSPEED (KHz) 315000
OPTION HDMI PINS  1, 3, 7, 5
OPTION SDCARD GP22, GP6, GP7, GP4
OPTION MODBUFF ENABLE  192
stanleyella
Posted: 05:34pm 25 Oct 2024
quick example of pixel folowing mouse movements :)
(Correct mouse device channel must be if not 3 as in my case)
MODE 2
Device mouse set 3,MM.HRes\2,MM.VRes\2,0
If DEVICE(MOUSE 3,x) <> tmpx Or DEVICE(MOUSE 3,y) <> tmpy Then
Pixel tmpx,tmpy,0
Pixel DEVICE(MOUSE 3,x),DEVICE(MOUSE 3,y)
tmpx=DEVICE(MOUSE 3,x)
tmpy=DEVICE(MOUSE 3,y)
End If
Edited 2024-10-22 15:37 by electricat
don't work?
this wireless kb works but not the mouse pad
Bleep
Posted: 07:01pm 25 Oct 2024
Hi Peter,
Trying to test the VGA 2040 and can't get my options programmed in
> option list
PicoMiteVGA MMBasic USB Edition  6.00.00RC10
OPTION SERIAL CONSOLE COM2,GP24,GP25
OPTION FLASH SIZE 16777216
OPTION KEYBOARD ES
OPTION HEARTBEAT OFF
OPTION PICO OFF
OPTION CPUSPEED (KHz) 252000
> option system spi gp18,gp19,gp16
Error : Invalid Option
Any ideas.
Regards Kevin
Posted: 07:08pm 25 Oct 2024
Hi Kevin,
In the VGA (without re-defining the VGA pins) gp16,18 and gp19 are used for VGA.
Maybe you should first re-allocate the VGA pins...
Bleep
Posted: 08:25pm 25 Oct 2024
Ah, ok, it's a bit confusing that it doesn't show those options in the options list, also the error would be more useful if it said GP16... already allocated, rather than Invalid Option. Anyway I'll try de-allocating the VGA and then re-allocating to the pins I  actually use. Thanks Harm. :-)
Posted: 08:55pm 25 Oct 2024
PicoVGA doesn't have SYSTEM SPI, you setup the SD card something like this:-
OPTION SDCARD GP13, GP10, GP11, GP12
Other SPI devices use the regular SPI commands
OPTION VGA PINS is in the 5.08 manual.
Edited 2024-10-26 06:56 by phil99
stanleyella
Posted: 09:12pm 25 Oct 2024
PicoMiteVGA MMBasic USB Edition  6.00.00RC2
OPTION KEYBOARD US
OPTION DISPLAY 30, 53
disco4now
Posted: 09:45pm 25 Oct 2024
  stanleyella said
don't work?
Your mouse is most likely on USB 2 not USB 3
Print "Device: 0=not used,1=Keyboard,2=Mouse,128=PS4,129=PS3,130=SNES/Generic"
Print "chan  device    VID     PID"
For x=1 To 4
Print x,MM.Info(USB x),Hex$(MM.Info(USB VID x),4),Hex$(MM.Info(USB PID x),4)
Next
> run
chan  device    VID     PID
1       1      046D    C52B
2       2      046D    C52B
3       0      046D    C52B
4       0      0000    0000
Test the mouse.
no=2 'Set correct mouse channel
MODE 2
Device mouse set no,MM.HRes\2,MM.VRes\2,0
If DEVICE(MOUSE no,x) <> tmpx Or DEVICE(MOUSE no,y)
<> tmpy Then
Pixel tmpx,tmpy,0
Pixel DEVICE(MOUSE no,x),DEVICE(MOUSE no,y)
tmpx=DEVICE(MOUSE no,x)
tmpy=DEVICE(MOUSE no,y)
End If
Footnote added 2024-10-26 11:12 by disco4now
Correction - needs to be on a single line
If DEVICE(MOUSE no,x) <> tmpx Or DEVICE(MOUSE no,y)<> tmpy Then
F4 H7FotSF4xGT
stanleyella
Posted: 09:48pm 25 Oct 2024
this was posted to show pin use
MM.Startup
end
Sub MM.Startup
Local Integer m, n
For m=0 To 28
 n = MM.Info(pinno "GP"+Str$(m))
 If MM.Info(pin n)="OFF" Then SetPin n, DIN, PULLUP
 print n,"GP"+Str$(m), MM.Info(pin n)
Next
but get
RUN
1     GP0     DIN
2     GP1     DIN
4     GP2     DIN
5     GP3     DIN
6     GP4     OFF: Boot Reserved
7     GP5     DIN
9     GP6     OFF: Boot Reserved
10    GP7     OFF: Boot Reserved
11    GP8     OFF: Boot Reserved
12    GP9     OFF: Boot Reserved
14    GP10    DIN
15    GP11    DIN
[8] n = MM.Info(pinno "GP"+Str$(m))
Error : Invalid pin
Posted: 10:10pm 25 Oct 2024
My guess is HDMI pins are not treated as GPIO pins.
To test this idea, at the command prompt type:-
? MM.INFO(pinno GP12)
then
? MM.INFO(pin GP12)
If either gives an error modify MM.STARTUP to exclude the HDMI pins from testing.
I don't have a HDMI setup so can't test.
It works without error on VGA
Edited 2024-10-26 08:19 by phil99
stanleyella
Posted: 10:12pm 25 Oct 2024
for n=0 to 28
print  MM.Info$(pin n)
next
gives
RUN
Invalid
OFF
OFF
Invalid
OFF
OFF
OFF: Boot Reserved
OFF
Invalid
OFF: Boot Reserved
OFF: Boot Reserved
OFF: Boot Reserved
OFF: Boot Reserved
Invalid
OFF
OFF
Invalid
Invalid
Invalid
Invalid
Invalid
Invalid
Invalid
Invalid
Invalid
Invalid
OFF
OFF
Invalid
Posted: 10:25pm 25 Oct 2024
try
For m=0 To 28
Next
stanleyella
Posted: 10:48pm 25 Oct 2024
my actual vga usb options are
Connected to COM11 at 115200
> option list
OPTION AUTORUN  ON
OPTION CPUSPEED (KHz) 378000
OPTION AUDIO GP0,GP1', ON PWM CHANNEL 0
Phil
RUN
1     GP0     OFF: Boot Reserved
2     GP1     OFF: Boot Reserved
4     GP2     OFF
5     GP3     OFF
6     GP4     OFF
7     GP5     OFF
9     GP6     OFF
10    GP7     OFF
14    GP10    OFF: Boot Reserved
15    GP11    OFF: Boot Reserved
16    GP12    OFF: Boot Reserved
17    GP13    OFF: Boot Reserved
19    GP14    OFF
20    GP15    OFF
21    GP16    OFF: Boot Reserved
22    GP17    OFF: Boot Reserved
24    GP18    OFF: Boot Reserved
25    GP19    OFF: Boot Reserved
26    GP20    OFF: Boot Reserved
27    GP21    OFF: Boot Reserved
29    GP22    OFF
41    GP23    DOUT
42    GP24    DIN
43    GP25    HEARTBEAT
31    GP26    OFF
32    GP27    OFF
34    GP28    OFF
stanleyella
Posted: 11:51pm 25 Oct 2024
  disco4now said
  stanleyella said
don't work?
For x=1 To 4
Next
> run
chan  device    VID     PID
1       1      046D    C52B
2       2      046D    C52B
3       0      046D    C52B
4       0      0000    0000
Test the mouse.
MODE 2
<> tmpy Then
Pixel tmpx,tmpy,0
End If
the mouse demo works now and the micro wireless keyboard touch pad. yippee!
dunno why didn't work before when should . rc10 maybe? but it's nice it works!
maybe the usb adaptors from big to little.
I can think of uses... missile command :) but click icon like gui touch for whatever
thanks Peter for sorting. looking forward to checking new ain. stan
<> tmpy Then
has to be on one line
Edited 2024-10-26 09:59 by stanleyella
Posted: 06:31am 26 Oct 2024
Correct - HSTX (HDMI) pins are not GPIO pins and are not available. The Pico has probably disconnected them from the GPIO pin matrix and connected them to the HSTX peripheral internally so they no longer exist. :)
Posted: 07:51am 26 Oct 2024
Thanks for confirming that Mick.
Stan, try this version for the Olimex HDMI board.
It should skip over the HDMI pins, but as I don't have one it is untested.
Sub MM.Startup
 Local Integer m, n
 For m=0 To 28
  if m=12 then m=20
 Next
Posted: 09:02am 26 Oct 2024
For m=0 To 28
a$="mm.info(pin GP"+Str$(m)+")"
Print Eval(a$)
Next
Edited 2024-10-26 19:03 by matherp
stanleyella
Posted: 02:18pm 26 Oct 2024
  phil99 said  Thanks for confirming that Mick.
Sub MM.Startup
 Local Integer m, n
 For m=0 To 28
  if m=12 then m=20
 Next
Phil. results, get one, they're tidy boards.
RUN
1     GP0     DIN
2     GP1     DIN
4     GP2     DIN
5     GP3     DIN
7     GP5     DIN
14    GP10    DIN
15    GP11    DIN
26    GP20    DIN
27    GP21    DIN
29    GP22    OFF: Boot Reserved
41    GP23    DOUT
42    GP24    DIN
43    GP25    HEARTBEAT
31    GP26    OFF: Boot Reserved
32    GP27    OFF: Boot Reserved
34    GP28    DIN
stan
     Page 15 of 25
