Forum Index : Microcontroller and PC projects : Newie got a few questions
| Justplayin Guru Joined: 31/01/2014 Location: United StatesPosts: 330 |
Your list of RMC is missing a couple of parameters. 0 - Message ID ($GPRMC) 1 - UTC Time 2 - Status (A or V) 3 - Latitude 4 - N/S Indicator 5 - Longitude 6 - E/W Indicator 7 - Speed Over Ground in knots 8 - Course Over Ground 9 - Date 10 - Magnetic Variation 11 - Mode (A=Autonomous, D=DGPS, E=DR) 12 - Checksum So, to get the date you will need arg$(9), and since you only want it when the data is valid, I would add the line directly after the valid record check. If secs < 4 Then 'IF Seconds is less than 4 then restart the GPS KeepSearching: Do Pin(23) = 0 'TURN GPS Power ON GetGPSRecord ' get a GPS record Loop Until arg$(0) = "GPRMC" ' we only want the RMC record If arg$(2) <> "A" Then ' "A" means valid record L$ = arg$(9) ' copy the date to L$ Pin(16) = 0 ' Turn HC-12 ON Print "Searching For GPS signal" Print #2, "START" , "Searching" GoTo KeepSearching ' go back and keep looking EndIf --Curtis I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
Thanks Curtis |
I have a "weird" problem with a routine Line2$ IS the current time in Hours Mins and Secs If I PRINT LINE2$ I get 10:16:00 ***Which is correct*** I want to extract the hour, mins and sec from Line1$ so I used this [code] H1 = Val(Left$(LINE2$(1), 2)) ' extract the hour M2 = Val(Mid$(LINE2$(1), 3, 2)) ' extract the min S2 = Val(Mid$(LINE2$(1), 5, 2)) ' extract the sec [/code] However when I Print H1 , "," , M2 , "," , S2 I get ***10,0,6*** Which IS INCORRECT Anyone see why it's going wrong? |
H1 = Val(Left$(LINE2$(1), 2)) ' extract the hour M2 = Val(Mid$(LINE2$(1), 4, 2)) ' extract the min S2 = Val(Mid$(LINE2$(1), 7, 2)) ' extract the sec |
Ah I forgot about the : Thanks |
Any ideas why this isn't working? [code] If Mid$(#1,11,4) = "Time" Then T5 (T5 is a sub) [219] If Mid$(#1,11,4) = "Time" Then Error: Invalid syntax > [/code] #1 is COM1 - I'm looking for "TIME" and then go to sub T5 |
Hi Lewis, The first parameter within the brackets needs to be a string. I guess you want to read from COM1 and look for the string 'Time'. What you need to do (if this is the case) is first read COM1 into a string$ and then use the loaded string in your MID$ command. Phil PS: sorry for the silence recently - been extremely busy I will email you later today . . . |
Thanks Phil Another conundrum D$ = FieldArray$(1) Is there any way to have E$ = FieldArray$(1) +(2) +(3) or is there any way to have a E$ = the value of several field arrays? **Fieldarray** is the comma seperated value of a sentence like "44,1,23,98" and similar |
In the above example, I assume FieldArray (lets call it FA for short!) is as follows: FA$(1)="44" FA$(2)="1" FA$(3)="23" FA$(4)="98" And that you want E$ to equal "68" (i.e. 44+1+23). Is this correct? If so then you can use VAL and str$ as follows: E$=str$( val( FA$(1) ) + val( FA$(2) ) + val( FA$(3) ) ) All we are doing is converting the strings into values, then adding the values, and finally converting the resultant value back into a string. Hope this helps |
Almost but not quite I don't want to add them up I want them to be a string with the comma's in as well What I am tryin gt do is this [code]Print #2,"TIME" , "," , Y1 , "," , M1 , "," , D1 , "," , H1 , "," , M2 , "," , S2 ' Send correct date/time to Indoor unit to set RTC[/code] This is what the com port sends What I want to send to the RTC is this[code]RTC SETTIME E$[/code] Where E$ = Y1 , "," , M1 , "," , D1 , "," , H1 , "," , M2 , "," , S2 extracted from the above string that starts with "TIME, "," , Thats' the string the indoor unit gets D$ = FieldArray$(1) which is "START" What I want is to set the RTC with Fieldarrays 3 - 11 which should be Year,Month,Day,Hour,Min,Sec |
Hi Lewis, I don't think getting E$ in the format will help. The RTC SETTIME command will not be happy if you pass it a string, no matter what is in it. The syntax below must be satisfied first or it wont look at it further. RTC SETTIME year, month,day, hour, minute, second The first thing it will do is check you have passed it six parameters by breaking it up at the commas, then it will check you have actually given it numbers. The parameters can be expressions but they must evaluate to numbers. Something like RTC SETTIME val(FA$(1)) , val(FA$(2)) , val(FA$(3)),val(FA$(4)) , val(FA$(5)) , val(FA$(6)) should work. Regards Gerry F4 H7FotSF4xGT |
I tried this code [code]IF LOC(#1) > 0 THEN SERIAL1 'If data in COM1 then GOSUB Serial1 END IF IF LOC(#2) > 0 THEN SERIAL2 'If data in Com1 then GOSUB Serial1 END IF SUB SERIAL1 'Com1 data B$ = Input$(254, #1) 'Suck everything in buffer out N = GetFieldArray(B$) D$ = FieldArray$(1) 'Start or Time E$ = FieldArray$(2) ', symbol F$ = FieldArray$(3) 'Year G$ = FieldArray$(5) 'Month H$ = FieldArray$(7) 'Day z$ = FieldArray$(9) 'Hour J$ = FieldArray$(11) 'Min K$ = FieldArray$(13) 'Sec If Mid$(D$,11,4) = "Time" Then RTC SETtime F$ , E$ , F$ , E$ , G$ , E$ , H$ , E$ , z$ , E$, J$ , E$ , K$ ; 'Set RTC to correct local time and date RTC GETTIME Text 90,215, DOW$(DayOfWeek(Year, Month, Day)), CM, 1, 2, RGB(BLACK), RGB(63, 133, 195) 'Print the Day of week Under Big Ben Text 90,270, Date$, CM, 1, 2, RGB(BLACK), RGB(63, 133, 195) 'Date secs=Val(Right$(Time$,2)) mins=Val(Mid$(Time$,4,2)) hours=Val(Left$(Time$,2)) print time$ , "RTC TIME" ; ELSE T6 END SUB[/code] but it doesn't work, the RTC does not set itself to the correct time The string being received on COM1 is this [code]Print #2,"TIME" , "," , Y1 , "," , M1 , "," , D1 , "," , H1 , "," , M2 , "," , S2 [/code] Y1 = year (2016) M1 = month (12) D1 = day (9) H1 = hour (22) M2 = min (22) S2 = sec (37) date and time right this second* Anyone see what I'm doing wrong, or any suggestions how to get it right? Gerry I did try what you said but it wouldn't work as RTC SETTIME needs comma's between each section Is it possible to have something like W = Y1,"."M1","D1","H1","M2","S2 then do this? RTC SETTIME W EDIT: just tried it and it doesn't work |
Lew disco4now gave you the answer above. The format for settime is RTC SETTIME year, month, day, hour, minute, second The parameters are numeric and separated by commas. Suppose the date was 10 December 2016 and the time was 11:12:30 the way ahead is [code] RTC SETTIME 16,12,10,11,12,30 [/code] or you can do it as [code] yy=16 mm=12 dd=10 hh=11 min=12 ss=30 RTC SETTIME yy,mm,dd,hh,min,ss [/code] You can use any variable names that suit but they must be numeric not strings and forget about quote marks "". |
Or to use your example of Y1 = year (2016) M1 = month (12) D1 = day (9) H1 = hour (22) M2 = min (22) S2 = sec (37) you would have to do Y1=year(16) because the required value for the year is only the last two digits. and the command would be RTC SETTIME Y1,M1,D1,H1,M2,S2 not sure why you are using arrays but you could also do Y1=16 M1=12 D1=9 H1=22 M2=22 S2=37 RTC SETTIME Y1,M1,D1,H1,M2,S2 |
Agreed. [Quote=Lew]RTC SETtime F$ , E$ , F$ , E$ , G$ , E$ , H$ , E$ , z$ , E$, J$ , E$ , K$ ; 'Set RTC to correct local time and date[/Quote] This will throw an error as soon as the command hits F$, and the code will break to the command prompt with an error. RTC SETTIME MUST follow the correct syntax, and the numbers past to it must also be integer numbers - strings or floating-point will be instantly rejected. Good luck - you almost have it, you just need to convert the strings to numbers with the VAL command as disco and Bob are saying. Smoke makes things work. When the smoke gets out, it stops! |
Lew, rather than do so many conversions from strings to numbers and back again, I think the GPS data is fixed length so it would be easier to send the original fields "as is" and do the extraction in the indoor unit. In your outdoor code: In the KeepSearching: sub, after you have extracted the other data add two new lins GPSdate$ = arg$(9) GPStime$ = arg$(1) To send the data to the indoor unit use: Print #2,"TIME" +GPSdate$+GPStime$ instead of Print #2,"TIME" , "," , Y1 , "," , M1 , "," , D1 , "," , H1 , "," , M2 , "," , S2 then the line received by the indoor unit is one string "TIMEyyMMddhhmmss" assuming you have is captured as E$ Y1 = val(mid$(E$,5,2) M1 = val(mid$(E$,7,2) D1 = val(mid$(E$,9,2) H1 = val(mid$(E$,11,2) M2 = val(mid$(E$,13,2) S2 = val(mid$(E$,15,2) you will need to convert from UTC to local time. I am not sure if you are changing the RTC for daylight saving. If not, there is no conversion needed. to set the RTC RTC SETTIME Y1,M1,D1,H1,M2,S2 Jim VK7JH MMedit |
deleted* I made an error |
While the outdoor unit is searching for the GPS lock it sends this to the indoor unit Then once it has a correct lock and converted the time to the CORRECT LOCAL TIME it then sends this where Y1 = year M1 = month D1 = day H1 - hour M2 = min S2 = sec [code] Searching For GPS signal Searching For GPS signal Searching For GPS signal CHECK1 16 12 10 13 35 23 13:35:23 ********************************* 13:36:09 Sat 10-Dec-2016 Battery Voltage 4.00 V Direction: 94.6041 Degrees WindSpeed: 0 MPH Gust 0.42 MPH Highest Gust 0.42 MPH Rain Today 0.00 mm Rain Yesterday 0.00 mm Temperature 24.12 C Highest Temp 24.12 C Lowest Temp 24.12 C Hi Temp Yesterday 0.00 C LOW Temp Yesterday 0.00 C Pressure 1008.55 mB HUMIDITY 54.41% UV Index: 0.02 ******************************* [/quote] This is what the indoor unit sees [quote] START Searching START Searching START , 24.12, 0, 0, 94.6041, 0, 0.416667, 0.416667, 0, 0, 24.12, 0, 24.12, 0, 0.02, 4.0043[/quote] Anyone see WHY NEITHER [quote] PRINT #1,"START" Y1,M1,D1,H1,M2,S2 ***OR*** Print #1,"TIME",",", Y1,",",M1,",",D1,",",H1,",",M2,",",S2 ' Send correct date/time to Indoor unit to set RTC[/quote] are sending the the indoor unit? I know it's not sending because the string starts with the word "START" which the indoor unit already recognises and prints whatever is after this |
I'm struggling with the English a bit but... The first PRINT won't output any commas (they're not in quotes so just act as punctuation). The second does not have the word START in it, if you need that as I think you say. So, let's suppose Y1 M1 D1 H1 M2 S2 are the numbers (for example 1 2 3 4 5 6, the first would print something like START 1 2 3 4 5 6 the second something like TIME , 1 , 2 , 3, 4 , 5 , 6 (I think) John |
Sorry I should have explained a bit better The indoor unit looks for EITHER the word START or TIME and does different things depending on which it receives It's receiving and getting both the searching string from the outdoor unit, and also the string where it receives the actual weather data It's NOT getting these strings from the outdoor unit PRINT #1,"START" Y1,M1,D1,H1,M2,S2 ' this sends the correct local time and date or Print #1,"TIME",",", Y1,",",M1,",",D1,",",H1,",",M2,",",S2 ' Send correct date/time to Indoor unit to set RTC EDIT: the example above that begins with [code] and ends in ]/code] is what I see on the CONSOLE output from the indoor unit so I know it's sending the correct info The line CHECK1 16 12 10 13 35 23 is actually a check for myself to see that Y1,M1,D1,H1,M2,D2 are actually the time and date and are correct |
