Local Time 12:13 12 Nov 2026 Privacy Policy
     Page 13 of 25
JanVolk
Posted: 07:07pm 17 Oct 2024
Peter,
Possibly already seen?
> list functions
MM.Info$( Occurs twice.
Jan.
Bleep
Posted: 08:16pm 17 Oct 2024
Hi Peter,
Ok,...  LCDs that don't have a 16bit parallel interface. :-)
PS.  what is the max overclock now on a 2350? if not VGA or HDMI
Hi Harm,
See link to Peters memcopy
Regards Kevin.
Edited 2024-10-18 07:34 by Bleep
Posted: 08:23am 18 Oct 2024
Hi Peter, Geoff,
I think this is a bug. The INSTR( ) function cannot work with calculated string indexes. I guess this is in MMBasic core (Geoff's original work).
Example:
dim a$(2)
a$(0)="Peter Mather"
a$(1)="Hello World"
a$(2)="Lobster Soup"
x=1
print instr(a$(x),"World")
print instr(a$(x-1),"World") 'this line errors
end
The calculated index (x-1) is not seen as a number.
Edited 2024-10-18 18:24 by Volhout
Posted: 08:37am 18 Oct 2024
It doesn't error for me.  I get:
7
0
The last number is correct as x-1 is zero and that index does not contain "World"
This is using ancient V5.05.05
What version are you using?  And what error message?
Edited 2024-10-18 18:50 by Geoffg
Posted: 08:50am 18 Oct 2024
Hi Geoff,
I am seeing this problem in PicoMite VGA RP2040 6.0.0 RC4
The problem exists in 5.08.00 (last official release), 5.09.00RC5 and the 6.00 series.
Edited 2024-10-18 18:58 by Volhout
Posted: 08:52am 18 Oct 2024
What is the error message?
Posted: 08:57am 18 Oct 2024
Harm: looks like my bug as doesn't happen on the MM2 - will investigate
Posted: 09:07am 18 Oct 2024
Hi Geoff,
The error is:
Error : Expected a number
Bleep
Posted: 09:17am 18 Oct 2024
Hi Peter,
I was thinking about these results
'Pico 2040 @ 378MHz VGA normal 336mS VGA Framebuffer 418mS
'Pico 2350 @ 378MHz VGA normal 193mS VGA Framebuffer 194mS
The difference between the 2040 & 2350 for a framebuffer copy appears to be much greater than I would have thought, I realise it's a completely different processor and you tuned it, but I'm assuming that a memcopy should be reasonably standard, & well optimised, in the SDK, so the difference between them seems overly large, ~2mS compared with ~82mS, or is there something else going on? Bus contention, waiting for a frame sync. etc...
Any insights, because this seems like quite a big speed hit.
Regards Kevin.
Edited 2024-10-18 19:20 by Bleep
Posted: 09:21am 18 Oct 2024
  Volhout said  Hi Geoff,
The error is:
OK, I just tested it on a RP2350 V6.00.00 (latest RC) and got that same error.  So, something has gone wrong deep in the internals of MMBasic.
Peter?
Edited 2024-10-18 19:29 by Geoffg
disco4now
Posted: 09:38am 18 Oct 2024
I see it in PicoMite HDMI RC8. Looks like its came when the option to allow use of regular expressions in INSTR was added as I also see it in the Armmite H7 which also allows regular expressions.( I copied from Picomite).
dim a$(2)
a$(1)="Hello World"
x=1
end
Saved 148 bytes
7
[8] Print Instr(a$(x-1),"World") 'this line errors
F4 H7FotSF4xGT
Posted: 10:35am 18 Oct 2024
Works OK on the various Linux versions I tried.
Posted: 10:45am 18 Oct 2024
  disco4now said  ... I see it in PicoMite HDMI RC8. Looks like its came when the option to allow use of regular expressions in INSTR was added ...
  JohnS said  Works OK on the various Linux versions I tried.
MMB4L doesn't have the regular expression feature at the moment.
Posted: 10:52am 18 Oct 2024
  thwill said  MMB4L doesn't have the regular expression feature at the moment.
No worries and also don't rush to add it...
Posted: 11:02am 18 Oct 2024
MMB4W v5.07.03b24 output:-
 7
 0
no error
Posted: 11:46am 18 Oct 2024
Unfortunately, it's nothing to do with regular expressions. Much deeper inside MMBasic than that.
Posted: 11:55am 18 Oct 2024
Peter,
There is an option to use a starting position in the string, as a first value. That must be a numerical. Could it be that it sees the string as the optional starting value.?
Posted: 12:29pm 18 Oct 2024
Peter,
I have one more observation on RC8. (2040 VGA PS2)
Tried several programs, and at some point I ran a program that just output text to the VGA screen in mode 1. The program itself contains a "mode 1:cls", and displays nice white text on a black background. But when the text begins to scroll, the new lines have white background, but the text printed on them is white text on black background.
So you are looking at normal text, and from the last character to the end of the line is white. Not black.
I checked the tiles, but they do not cause it.
I manually typed "mode 1" and that didn't solve it.
I ran the program several times, the phenonem remained.
I did a CPU RESTART and then the problem was gone.
I do not know what caused it. Honestly I looked so long into this that I can't even remeber what program I ran before it. But it seems that program left something in memory that is not erased at a new RUN.
I know this is by no way reproducible. So you can't solve it.
But maybe someone else sees the same, and give more info.
Edited 2024-10-18 22:30 by Volhout
Posted: 03:04pm 18 Oct 2024
V6.00.00RC9
PicoMiteRP2350V6.00.00RC9.zip
PicoMiteRP2040V6.00.00RC9.zip
Fixes bug in instr when an expression is used as the index to an array as the first parameter
Fixes DS18B20 functionality ( and possibly DHT22?). This was caused by a change introduced to try and circumvent, to the extent possible, errata E9 on the RP2350
Removes spurious MM.INFO$ in LIST FUNCTIONS
Further fix to MM.STARTUP
ville56
Posted: 05:11pm 18 Oct 2024
Peter,
another problem with DS18B20 still persists. If you have a loop with 2 sensors and a print statement  within the loop the firmware locks up completely after some time. It can only be restarted by power-cycling or the reset signal. It can even be reproduced without any sensors connected. Takes a few minutes of runtime but it is reproducable. If the loop has only 1 sensor, it works ok.
Example code (excuse some unneccesary variables and setpin statements):
 Option EXPLICIT
 Option DEFAULT NONE
 const acc_18B20 = 0
 const ar_size = 9
 Dim integer idx, flg
 dim float temp_R, temp_HK, temp_R_arry(ar_size), temp_HK_arry(ar_size), m_temp_R, m_temp_HK
 'set pins to high for DS18B20 supply
 setpin gp8,dout
 pin(gp8)=1
 setpin gp12,dout
 pin(gp12)=1
   'start conversions
   tempr start gp9,acc_18B20
   tempr start gp13,acc_18B20
   'read sensors
   temp_R = tempr(gp9)
   temp_HK = tempr(gp13)
   print "Heater=";temp_HK, "Room=";temp_R
Omitting the print statement make the loop work, at least over more than 12 hours.
Regards, Gerald
73 de OE1HGA, Gerald
     Page 13 of 25
