Local Time 23:52 11 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA DEMO
     Page 13 of 14
javavi
Posted: 09:16am 22 Aug 2026
Option ANGLE DEGREES
RX=MM.HRES: RY=MM.VRES: CX=RX/2: CY=RY/2
Umin=-180: Umax=180: Ustep=14
Vmin= -90: Vmax= 90: Vstep=14
SCALE=220: C=1
Colour RGB(Cyan)
CLS
 If C>0 Then C=0 Else C=1
 For S=0 To 12 Step 2
   For V= Vmin To Vmax Step Vstep
   For U= Umin To Umax Step Ustep
     U=U+S
       x=Cos(U)*Cos(V)
       y=Sin(U)*Cos(V)
       z=Sin(V)
     U=U-S
     Plot_XY
     If Inkey$ <> "" Then End
   Next U: Next V
 Next S
Sub Plot_XY
 x=SCALE*x: y=SCALE*y: z=SCALE*z
 y=y/3
 If y<0 Then
   Circle CX+x-y,CY+z-y,1,,,C
 Else
   Pixel CX+x-y,CY+z-y,C
 EndIf
javavi
Posted: 06:09pm 23 Aug 2026
Tesseract The Space Stone / The Cosmic Cube
MODE 3
CX=MM.HRES\2
CY=MM.VRES\2
Dim P(5),Q(5)
For L=0 To 5
 S=Pi/3*L
 P(L)=500*Sin(S)
 Q(L)=500*Cos(S)
Next
X=0:Y=500
For L=0 To 320000
 R=Int(Rnd*6)
 X=(X+P(R))/2
 Y=(Y+Q(R))/2
 PX=CX+X\2
 PY=CY+Y\2
 G=Pixel(PX,PY)
 Color Map(1)
 If G>0 Then Color Map(7)
 Pixel PX,PY
Next
javavi
Posted: 05:39pm 01 Sep 2026
Strudel aus den Kreisen
Excuse my German, but if you watch it for a long time, it should start spinning
MODE 2
Map Reset
For Y=0 To 240-1
 Color Map(1+(Y Mod 8))
 Line 0,Y,320,Y
Next
Color 0
Pause 1000
C=36
For O=0 To 7
 For A=0 To 7
   B=(A*8+O)*Pi/32
   L=120*Sin(B)+160
   M=((68*Cos(B))\8*8)+125
   For Y=M-C+O To M+C Step 8
     R=Sqr(Abs(C*C-(Y-M)^2))
     Line L-R,Y,L+R,Y
   Next
 Next
Next
Pause 1000
Dim CM%(15)
CM%(1)=RGB(Cyan)
 For i%=0 To 7:CM%(i%)=CM%(i%+1):Next
 CM%(8)=CM%(0)
 For i%=1 To 8:Map(i%)=CM%(i%):Next
 Map Set
 Pause 60
Loop While Inkey$=""
javavi
Posted: 09:49am 06 Sep 2026
Circular Strudel
MODE 3
Dim C%(15)=(0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15)
Colour Map C%(), C%()
xc=MM.HRES\2
yc=MM.VRES\2
 r=r+Pi/180
 w=w+Pi/72
 For i=1 To 11
   x=xc+200*Cos(w+i*Pi/6)*Sin(r)
   y=yc+200*Sin(w+i*Pi/6)*Sin(r)
   Circle x,y,40,,,C%(6),C%(0)
   ww=ww+Pi/80
   If i=1 Then
     For j=1 To 11
       xx=x+100*Cos(ww+j*Pi/6)*Sin(r)
       yy=y+100*Sin(ww+j*Pi/6)*Sin(r)
       Circle xx,yy,20,,,C%(8),C%(0)
       w3=w3+Pi/80
       If j=1 Then
         For k=1 To 11
           x3=xx+50*Cos(w3+k*Pi/6)*Sin(r)
           y3=yy+50*Sin(w3+k*Pi/6)*Sin(r)
           Circle x3,y3,10,,,C%(1),C%(0)
         Next k
       EndIf
     Next j
   EndIf
 Next i
javavi
Posted: 02:46pm 14 Sep 2026
Hyperboloid
MODE 3
XC=MM.HRES\2: YC=MM.VRES\2
D=3: CX=0: CY=-1: CZ=1
For CY=-1 To 1 Step 2
 For I=0 To 2*Pi Step Pi/26
   XM=CX+Sin(I): YM=CY: ZM=CZ+Cos(I)
   XD=CX+Sin(I+Pi/2): YD=-CY: ZD=CZ+Cos(I+Pi/2)
   If (ZM+ZD)/2>CZ Then Color RGB(Cyan) Else Color RGB(Yellow)
   SXM=XM*D/(ZM+D): SYM=YM*D/(ZM+D)
   SXD=XD*D/(ZD+D): SYD=YD*D/(ZD+D)
   Line XC+XC*SXM,YC+YC*SYM,XC+XC*SXD,YC+YC*SYD
 Next
Next
javavi
Posted: 06:10pm 14 Sep 2026
Eldritch
MODE 2
FRAMEBUFFER CREATE
FRAMEBUFFER WRITE F
Dim PLGNX%(6)
Dim PLGNY%(6)
CX=MM.HRES\2:CY=MM.VRES\2
C%=RGB(Red)
 CLS
 For z=1 To 63
   For t=0 To 6
     x=CX+(Sin(t*1.05+Sin(Timer/300+z/10))*(z*4))
     y=CY+(Cos(t*1.05+Sin(Timer/300+z/10))*(z*4))
     PLGNX%(t)=x:PLGNY%(t)=y
   Next
   Polygon 6,PLGNX%(),PLGNY%(),C%
 Next
 FRAMEBUFFER COPY F,N,B
JulesO
Posted: 11:49am 15 Sep 2026
Thanks Javavi, it's always fun to test and play with your work. Great code to learn from.
javavi
Posted: 02:33pm 04 Oct 2026
Comet
MODE 2 '1 2 3
cx=MM.HRES\2
cy=MM.VRES\2
cr=7
rd=cy-cr
C=RGB(Cyan)
 For i=1 To 1000
   Pixel Rnd*MM.HRES,Rnd*MM.VRES,0
 Next
 t=Timer/5000
 x=cx+rd*Cos(3*t)
 y=cy+rd*Sin(4*t)
 Circle x,y,cr,,,C,C
mozzie
Posted: 03:05pm 07 Oct 2026
G'day Javavi,
Some of these short programs are a great learning device, I always look forward to trying out the latest one to see how they work and what can be changed.
That last one had me guessing how it new where to erase the tail, until the realization that its entropy at work. Brilliant in its simplicity
Hope to see many more.
Regards, Lyle.
PilotPirx
Posted: 07:05am 08 Oct 2026
Hi mozzie,
yes, it's a clever little program.
It's interesting that random deletion produces such an effect.
If you disable the delete function, it draws a Lissajous figure with a frequency ratio of 3:4.
DaveJacko
Posted: 09:08pm 08 Oct 2026
Fascinating work, guys!.. amazing how a little bit of mathematics can produce such images, (and remind us of the concept of entropy, and how strange.. maths controls the universe)
I am minded of the work of Alan Turing into the maths of Leopard spots and all sorts of other patterns in biology. Might be a bit more computationally expensive, but, we've got a compiler now!.. anyone inspired? I never got much beyond "Conway's game of life" myself.
BTW the WikiP article on Conway's game of life is excellent
Edited 2026-10-09 07:13 by DaveJacko
Try swapping 2 and 3 over
BarryH
Posted: 04:12am 09 Oct 2026
Yes, the Wikipedia article is fascinating and just like the Mandelbrot equations & fractals, show that initially inane constructs and discoveries can indeed have great scientific value.
BarryH
javavi
Posted: 03:30pm 11 Oct 2026
Turbulent flows
MODE 2
For YM=0 To MM.VRES-1
 For XM=0 To MM.HRES-1
   X=XM:Y=YM
   U=X:V=Y
   For L=0 To 3
     U=U+Sin(V*.01*L)*30
     V=V+Sin(U*.01*L)*30
   Next
   O=Sin(Int(V/2)*123.45)*12
   O=O-Int(O)
   Color Map(15 And(Int(U)+O*16))
   Pixel X,Y
 Next
Next
Dim integer CM(15)=(0,9,15,9,0,0,0,0,0,0,0,0,0,0,0,0)
Colour Map CM(),CM()
 Tmp=CM(0)
 For i=0 To 14: CM(i)=CM(i+1): Next
 CM(15)=Tmp
 For i=0 To 15: Map(i)=CM(i): Next
 Map Set
 Pause 50
javavi
Posted: 05:46pm 16 Oct 2026
Moore sphere-filling curve
A Moore curve (after E. H. Moore) is a continuous fractal space-filling curve which is a variant of the Hilbert curve.
MODE 1
Dim Integer CX,CY,X1,Y1,X2,Y2
CX=MM.HRES\2
CY=MM.VRES\2
X1=CX-CY*Sqr(1/2)
Y1=CY-CY*Sqr(1/2)
ProcH(-1,-1,2,0,0,2,7)
End
Sub ProcH(A,B,C,D,E,F,N)
 If N<=0 Then ProcL(A+(C+D)/2,B+(E+F)/2): Exit Sub
 ProcH(A,B,D/2,F/2,C/2,E/2,N-1)
 ProcH(A+C/2,B+E/2,C/2,E/2,D/2,F/2,N-1)
 ProcH(A+C/2+D/2,B+E/2+F/2,C/2,E/2,D/2,F/2,N-1)
 ProcH(A+C/2+D,B+E/2+F,-D/2,-F/2,-C/2,-E/2,N-1)
Sub ProcL(X,Y)
 X2=CY*X*Sqr(1-Y*Y/2)+CX
 Y2=CY*Y*Sqr(1-X*X/2)+CY
 Line X1,Y1,X2,Y2
 X1=X2:Y1=Y2
Edited 2026-10-17 07:08 by javavi
javavi
Posted: 05:20pm 24 Oct 2026
Find a way out of the maze
A German friend of mine @dejanoff, while experimenting with AI, created a small program in MMBasic for the PicoMite and sent it to me to check out.
It didn’t run quite right on my end, though, because it had been designed for an 800x600 resolution, which didn’t match the resolution I was using. I showed the program to a Google AI and asked it to modify the code so that it would work with other resolutions. Now, the demo runs at any resolution, provided it has a 4:3 aspect ratio.
Maze.zip
Posted: 11:59am 25 Oct 2026
Nice,
Works flawless on picomite VGA in mode 2.
Martin H.
Posted: 09:20am 08 Nov 2026
Campfire on Sunday
Doom Fire for Pico
Option default integer
MODE 2 'MODE 7 for MMB4W CMM2
Dim fire(160,20)
'Prepare source
Dither 0,RGB(RED):Box 8,0,8,2,,RGB(RED)
Dither 8,RGB(255,64,0):Box 16,0,8,2,,RGB(255,64,0)
Dither 16,RGB(255,128,0):Box 24,0,8,2,,RGB(255,128,0)
Dither 24,RGB(yellow):Box 32,0,8,2,,RGB(yellow)
Dither 32,RGB(White):Box 40,0,2,2,,RGB(White)
For f=0 To 20:Sprite read f+1,f*2,0,2,2:Next
CLS 0
Box 0,238,320,2,,RGB(white)
For f=0 To 160:fire(f,20)=20:Next
 For y=0 To 19
     yy=198+(y<<1)
     For x=0 To 159
       r=Int(Rnd*4)
       xr=(x+(r>>1))Mod 160
       fr=fire(xr,y+1)-r:fr=MAX(0,fr)
       fire(x,y)=fr
       Sprite write fr+1,x<<1,yy,0
     Next
 Next
'Pause 20 for MMB4W
Sub dither x,col
Pixel x+2,0,col:Pixel x+4,0,col:Pixel x+6,0,col
   Pixel x+7,0,col:Pixel x+5,1,col:Pixel x+7,1,col
.It also works with MMB4W, though in Mode 7 and with a short pause before the “loop”
Edited 2026-11-08 20:33 by Martin H.
'no comment
Martin H.
Posted: 03:33pm 10 Nov 2026
option compile on
Randomize (Timer)
CLS
Dim fire(160,20),fire2(160,20),ranr(2048)
For f=0 To 2047:ranr(f)=Int(Rnd*4):Next
'Prepare source
CLS 0
rp=Int(Rnd*2048)
tt=Timer
For y=0 To 19
    y1=y+1
    yy=198+(y<<1)
    xx=0
    For x=0 To 159
      r=ranr(rp)
      xr=(x+(r)) Mod 160
      fr=fire(xr,y1)-r:If fr <0 Then fr=0
  If fire2(x,y)<> fr Then fire(x,y)=fr:fire2(x,y)=fr:Sprite write fr+1,xx,yy,0
      Inc xx,2:Inc rp: If RP>2047 Then rp=0
    Next
Next
Print @(0,0);Timer-tt;"     "
'Pause 20' for MMB4W
Sub dither x,col
By precomputing the random numbers, 3,200 queries per frame are eliminated.
Previously, 3,200 sprites were drawn per frame. Thanks to double-checking,
the system now detects whether a cell has changed, and only that cell is redrawn.
At 378 MHz, this reduces the time per frame from 140 to less than 80 ms.
I can't think of many more ways to optimize it right now; that might be a candidate for mmb2csub.
Martin
Edited 2026-11-11 01:36 by Martin H.
'no comment
javavi
Posted: 05:35pm 10 Nov 2026
Hi Martin,
The demo is absolutely fire!
> OPTION COMPILE ON
Bleep
Posted: 06:03pm 10 Nov 2026
Hi Martin,
On My HDMIUSBI2S board at 378MHz I get about 63mS on 7.00b8.
I tried compiling it, but it can't compile the Sprite Write, The only way round this I can think of is to calculate the fr,xx,yy in the Csub and put them in an array, then exit the Csub loop to do the Sprite Write fr,xx,yy,0 in a tight loop, then return to the Csub to calculate the next lot.
Regards Kevin.
Just found if you change Sprite for Blit it drops to 45mS!
Edited 2026-11-11 04:48 by Bleep
     Page 13 of 14
