Forum Index : Microcontroller and PC projects : CMM2: Bug reports
| GregZone Senior Member Joined: 22/05/2020 Location: New ZealandPosts: 114 |
Test successfully completed with new b1q version and resistor removed. All good, as with resistor. Just noting my comment above re. the Busy LED. With everything disconnected Pin 40 to GND measures ~30M / ~370K depending on test lead polarity. However note that I get the same readings measuring Pin 40 to 3.3V. ie. I believe Pin 40 appears to be floating? Certainly not a silly question, especially if we have floating inputs? No, the board is certainly not sittng on anything with conductivity! Although it's been raining heavily today so the air is pretty moist, even with the dehumidifier going. |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12188 |
Your readings could be a meter issue but with a Fluke 87 I get zero in both directions. One more test. In the attached I've re-instituted the pin 40 test but I've added a 250mSec delay before it to give the internal pullup time to overcome any capacitance/ bleed resistance on the pin. Please try this without a resistor and see if the fault returns CMM2V5.05.03b1q.zip |
Here ya go... > ? PIN(40) Error: Pin is not an input > SETPIN 40,DIN,PULLUP > ? PIN(40) 1 > Can you explain the purpose of this test? The PIN appears to be returned to "not an input" upon a reset. |
My readings were with my trusty Fluke 179. Which I totally trust! :) |
That is what the firmware does to check for reset, it then does a SETPIN 40,OFF Our posts crossed, please see my previous post. Thanks for your efforts. The fact you are seeing some resistance suggests to me that there is some contamination of the PCB which is probably the route cause of the issue Edited 2020-06-18 19:04 by matherp |
The issue returns with this firmware version. ie. That's a test fail. Well, I could throw my board into my Ultrasonic PCB cleaner, but I think this is not really the answer. Especially noting that CircuitGizmos is reporting the exact same issue with his new JLC assembled PCB's. So does this mean that for your pin 40 function, a PCB revision is necessary to add an external Pin 40 pull-up resistor? |
It hasn't been necessary for 8 machines I've built A number of machines Grogster has built A number of machines WW has built 6 machines distributed to the original development group Machines hand crafted by KeepIs and SWA-Guy There is an issue with CGs versions that needs understanding and fixing otherwise other issues such as the possible impairment of SDcard operation may be there and impacting users |
GregZone One last try please without resistor CMM2V5.05.03b1q.zip let me know what happens. Thanks |
Agree. CircuitGizmos does appear to be the common factor with this issue. However, understanding that you are setting the pin as an input with internal pull-up, and then testing for it being pulled low, then this seems perfectly reasonable... So... silly question... Are you 100% sure your test code change did correctly implement a 250ms delay before reading the input value? Just checking, as a 250ms delay would seem quite reasonable to allow the pin to stabilise, and clearly the internal pull-up is effective. |
I have been running with a relatively long 40 way cable and a breadboard attached with no problems with random rests which is why I didn't think to consider it as a possibility. It was only when I deliberately forced a reset while monitoring the backup ram that I experienced exactly your fault. The rest was easy. I agree with Peter that finding the route cause of the problem is important for continued reliability. Prevention is always better than cure. Jim GregZone, can you measure the resistance to ground with the Waveshare module removed. Edited 2020-06-18 19:56 by TassyJim VK7JH MMedit |
In the latest version I check the pin 3 times at 100mSec intervals and only if all three read low do I reset |
Just for reference to something mentioned by Peter: Full size SD Card reader on flying leads, 8, 16, 32 and 64 GB Micro SanDisk (via adaptor) all perfect, and I've been hammering the SD, cheap Jaycar adaptor with resistors for Level shift and all, this one would not work on the ARM-H7 CMM2 loves it. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
As you suspected, my resistance measurements were with the Waveshare in place. The high resistance values I measured would have been due to the SoC connected pin. However, the values measured would not have impacted the correct pull-up with the internal pull-up resistance (as shown by the PIN(40) tests). Given the potential for impairment of the 80pin header sockets, I'm reluctant to remove the Waveshare board again simply to verify a higher restnace value / open circuit. |
Have you tried the software I posted at 9:43? |
YES! We have success. Nice work. ![]() So, I think this just leaves: 1. After reset the Red LED remains constantly ON, until the SD Card is first accessed (eg. a LS command). Then it reverts to correctly lit only during access. 2. Throughout I have still seen occasional unexpected key repeats. |
We just cross-posted (see prior post). Sorry for the delay, it's getting quite late here so I'm about to sign-off for the night. Thanks for your excellant work on this issue! |
This is correct, it indicates a USB keyboard has been enumerated. Try without the keyboard and then plug it in. See the user manual page 11 This suggests the keyboard isn't playing nicely and the S/W is missing the key up events. Have you tried different keyboards? Not so fast - I've just coded round an underlying H/W problem - not a good solution Edited 2020-06-18 20:45 by matherp |
I'd suggest that slow settling time of the applied internal pull-ups is more likely related to PCB trace capacitance / inductance. I've left my workroom for the night, so I haven't inspected the PCB routing associated with pin 40, but is it possible that this is a longer trace perhaps running alongside a ground trace or copper fill? (Just thinking out loud with some end of day tired thoughts). ps. Hopefully CircuitGizmos can replicate the last test successfully with his boards as well. |
Hi Peter, Just updated to 5.05.03b1q and I am now seeing the issue where an edit made to a .bas file is being ignored when the file is being Run. I can't reproduce this with a simple example, nor with Z-MIM R1, but it is happening consistently with my Z-MIM development version. Do you want to take a look? How do you want the files? Regards, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Certainly need to get to the bottom of it. Please try the following test version and let me know if the issue still occurs CMM2V5.05.03b1r.zip |
