Local Time 20:55 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite/VGA/WEB V5.07.08 release candidates
     Page 12 of 18
vegipete
Posted: 08:58pm 13 Nov 2023
Could it be possible to change the transparent colour of the layer framebuffer without closing it?
If I do
FRAMEBUFFER Layer 13
' do some stuff
FRAMEBUFFER Layer 0
I get "Error : Layer already exists"
If I add the required FRAMEBUFFER Close L, I lose my image on the layer buffer. Grr.  ;-)
Posted: 10:53pm 13 Nov 2023
  Quote  Could it be possible to change the transparent colour of the layer framebuffer without closing it?
Don't see why not - untested
PicoMiteVGA (2).zip
vegipete
Posted: 11:59pm 13 Nov 2023
Seems to work properly. Although there might be an odd background colour left over after the FRAMEBUFFER is closed. (CLS by itself at the end of the program clears the screen to white.)
Do we not have the ability to set the FRAMEBUFFER LAYER transparent colour to -1, meaning no colours are transparent?
autosave
Option DEFAULT INTEGER
MODE 2
CLS
Dim ctab(15):For i = 0 To 15: Read ctab(i) : Next
colr:   ' order is messed up
Data RGB(BLACK),RGB(BLUE),RGB(GREEN),RGB(CYAN),RGB(RED)
Data RGB(MAGENTA),RGB(YELLOW),RGB(WHITE),RGB(MYRTLE)
Data RGB(COBALT) ,RGB(MIDGREEN),RGB(CERULEAN)
Data RGB(RUST), RGB(FUCHSIA),RGB(BROWN),RGB(LILAC)
' draw a back ground image
For j = 1 To 20
 For i = 33 To 127
   Print Chr$(i);
 Next i
Next j
FRAMEBUFFER layer 0 ' -1 for no transparent colour?
FRAMEBUFFER write L
CLS
For j = 0 To 3
 For i = 0 To 3
   x = i * MM.HRes / 4
   y = j * MM.VRes / 4
   c = ctab(j * 4 + i)
   Box x,y,MM.HRes/4,MM.VRes/4,1,0,c
 Next i
Next j
For i = 1 To 15   ' make each colour transparent
 FRAMEBUFFER layer i
 Pause 1500
Next i
FRAMEBUFFER close
CLS 0   ' must specify 0 for black?
amigawizard
Posted: 07:20am 14 Nov 2023
Peter,
can we have  LINE x, y, - , - [, LW [, C]]
same as  LINE x1, y1, MM.INFO(HPOS), MM.INFO(VPOS) [, LW [, C]]
I have used this for year`s in Oscilloscope`s
is much faster than  LINE x1, y1, x2, y2 [, LW [, C]]
thank you !
Wayne !
Posted: 08:42am 14 Nov 2023
  Quote  can we have  LINE x, y, - , - [, LW [, C]]
Please explain the use-case with a simple example. Does the line command update mm.info(hpos) etc.?
Edited 2023-11-14 18:59 by matherp
amigawizard
Posted: 09:55am 14 Nov 2023
Peter,
HScan = 250000
Option base 1
Dim array1!(5000) , array2!(5000)
start:
keyin$ = Inkey$
If Not ( keyin$ = "" ) Then DoIt
GoTo start
Sub DoIt
Cro
Display
grid
Sub Cro
'ADC open 125000 , 2
'ADC open 250000 , 2
ADC open HScan , 2
ADC start array1!()  ,  array2!()
ADC close
Sub Display
CLS
Box 0,0,480,320,,(RGB(red))
For x = 2 To 478   Step 1
Line x , 250 - array1!(x) * 35 , - , - ,, RGB(green)
Line x , 400 - array2!(x) * 35 , - , - ,, RGB(yellow)
Next x
Sub grid
   For x = 12 To 478   Step 35
   For y = 20 To 316  Step 35
'      Pixel x , y  , RGB(cyan)  ''(yellow)
     Pixel x , y  , RGB(pink)  ''(yellow)
   Next y
 Next x
End
             Wayne  !!
Posted: 10:17am 14 Nov 2023
That can't work as written. Assuming the first line resets HPOS to x1 then the second line will end at the endpoint of the first line and not the point last written by the second line - think about it
Posted: 10:32am 14 Nov 2023
Try this
PicoMite.zip
Note the two lines have to be drawn separately and the use of PIXEL with -1 as the colour to position cursor.
HScan = 250000
Option base 1
start:
keyin$ = Inkey$
GoTo start
Sub DoIt
Cro
Display
grid
Sub Cro
ADC open HScan , 2
ADC close
Sub Display
CLS
Pixel 1,250-array1!(1),-1
Line x , 250 - array1!(x) * 35 ,,,, RGB(green)
Next x
Pixel 1,400-array2!(1),-1
Line x , 400 - array2!(x) * 35 ,,,, RGB(yellow)
Next x
Sub grid
  Next y
Next x
End
Edited 2023-11-14 20:48 by matherp
amigawizard
Posted: 10:44am 14 Nov 2023
Yes it was only an example
      needed pixel set for the first location
      pixel can do two lines at a time
      but as you suggest i will try your code
       thank you for this  !
             Wayne  !!!
Posted: 10:49am 14 Nov 2023
It will be faster if you put up with while lines
amigawizard
Posted: 11:38am 14 Nov 2023
Peter,
      Yes  that is "Fast"
      thank you  again for the help !
             looking forward to the final  Release
             Wayne  !!!!
Posted: 11:55am 14 Nov 2023
This is even faster. I like making things go fast
PicoMite.zip
HScan = 250000
Option base 1
start:
keyin$ = Inkey$
GoTo start
Sub DoIt
Cro
Display
grid
Sub Cro
ADC open HScan , 2
'ADC start now has the capability of defining the range to map the output
'for each channel specify where 0V should be converted and where VCC should be converted
ADC start array1!()  ,  array2!(),,,250,250-35*3.3,400,400-35*3.3
ADC close
Sub Display
CLS
Timer =0
colour rgb(green)
Pixel 1,array1!(1),-1
Line x , array1!(x)
Next x
' Pixel command now has the ability to set the cursor position by specifying a colour of -1
colour rgb(magenta)
Pixel 1,array2!(1),-1
'line now has the ability of drawing from the x,y specified to the current cursor position and if used in this way then updates the cursor position
Line x , array2!(x)
Next x
Print Timer
Sub grid
 Next y
Next x
End
Edited 2023-11-14 22:41 by matherp
Posted: 01:18pm 14 Nov 2023
What is this example code supposed to do besides draw a red-outlined box?
Posted: 02:29pm 14 Nov 2023
Its doing a plot of adc readings on the y axis against time (x)
stanleyella
Posted: 02:41pm 14 Nov 2023
Could we have xor for b/w primitive lcd graphics. a scope grid that doesn't get erased when you erase the previous trace. but that would need read pixel??
Posted: 03:53pm 14 Nov 2023
V5.07.08RC18
Prompted by amigawizard I've added some ultra-fast plotting capability
New command
LINE PLOT ydata() [,nbr] [,xstart] [,xinc] [,ystart] [,yinc] [,colour]
ydata is an array of floats or integers to be plotted
nbr is the nbr of line segments to be plotted - defaults to the lesser of the array size and MM.HRES-2 if omitted
xstart is the x-coordinate to start plotting - defaults to 0
xinc is the increment along the x-axis to plot each coordinate - defaults to 1
ystart is the location in ydata to start the plot - defaults to the array start
yinc is the increment in ydata to add for each point to be plotted
colour is the colour to draw the line
This give a huge performance increase over plotting discrete line segments. For example plotting 319 line segments on the VGA version takes around 1mSec @ 252MHz
Example
If MM.Device$="PicoMiteVGA" Then MODE 2
Dim array!(2000)
For i=0 To 2000:array!(i)=Sin(Rad(i*2))*MM.VRes\8+MM.VRes\3:Next
CLS
Timer =0
Line plot array!() 'plot from start of array 1 line segment per x coordinate
Print @(0,0)Timer
Pause 4000
Timer =0
Line plot array!(),,,2,,,RGB(red) 'plot every second x = zoom in
Print @(0,0)Timer
Pause 4000
Timer =0
Line plot array!(),,,,,2,RGB(cyan) 'plot every second y = zoom out
Print @(0,0)Timer
Pause 4000
For i=0 To 2000:Inc array!(i),MM.VRes\3
:Next
Timer =0
Colour RGB(green)
Line plot array!(),200,50 'plot 50 samples starting at x=50
Print @(0,0)Timer
Pause 4000
Timer =0
Colour RGB(magenta)
Line plot array!(),250,50,,50 'plot 150 samples starting at x=50 from position 50
Print @(0,0)Timer
Pause 4000
In addition I've added extra capability to the ADC START command to optionally scale the reading as required
ADC START CHAN1arr!() [,Chan2arr!()] [,Chan3arr!()] [,Chan4arr!()] [,C1min] [,C1max] [,C2min] [,C2max] [,C3min] [,C3max] [,C4min] [,C4max]
By default the min and max values are set to 0 and VCC to give voltage readings. But if the data is for display then you can use other values so:
C1min=200 and C1max=100 will create values ranging from 200 to 100 for equivalent voltages of 0 - 3.3. This allows you to scale the reading for display without further manipulation or to recover the original ADC readings (C1min=0.0, C1max=4095.0)
Edited 2023-11-15 02:14 by matherp
Posted: 04:21pm 14 Nov 2023
Vectrex emulation for the PicoMite anyone?  :)
Posted: 05:56pm 14 Nov 2023
Very cool.
stanleyella
Posted: 06:03pm 14 Nov 2023
Amazing work but not sure what is lcd applicable or just vga.
could this be polygram?
Edited 2023-11-15 04:11 by stanleyella
Posted: 06:12pm 14 Nov 2023
All the above work on any type of display
I'm on a roll today. If you re-download RC18 then it now has a new MATH function
MATH(CROSSING array() [,level] [,direction]
level defaults to 0
direction defaults to 1 (valid -1 or 1)
This returns the array index at which the values in the array pass the "level" in the direction specified. This makes plotting ADC data for an oscilloscope application even easier than before
Example code
Dim array%(2000)
Do ' create a sine wave with a random start point
 j=(Rnd * 360)
 For i=0 To 2000:array%(i)=-Sin(Rad(i*2+j))*MM.VRes/8+MM.VRes/3:Next
 CLS
 Colour RGB(green)
 Line plot array%()
 Colour RGB(magenta)
 Line 0,MM.VRes/3,MM.HRes-1,MM.VRes/3,,RGB(blue)
 x%=Math(crossing array%(),MM.VRes/3,-1)
 Text 0,0,Str$(x%)
 Line plot array%(),250,50,,x% 'plot 250samples starting at the crossing point
 Pause 100
Edited 2023-11-15 04:13 by matherp
     Page 12 of 18
