Forum Index : Microcontroller and PC projects : Pico Computer 3 - One board to rule them all
| cdeagle Senior Member Joined: 22/06/2014 Location: United StatesPosts: 273 |
Is it possible to plug the PicoMite 3 into a PC and use TeraTerm and MM Edit 5? |
It has a built-in serial to USB adapter (U7 - CH340) for the serial console, connected to COM2 on GP8 & 9. The console USB-C socket (USB2) is near the HDMI socket. . Edited 2026-11-11 07:49 by phil99 |
Depending on which firmware you have loaded, MMEdit will connect to the USB "firmware update" port just like a "normal" picomite. If you load one of the standalone firmwares, you use the serial-USB adapter which is part of the PC3. In this case you have to be sure to use the correct baud rate. Usually 115200 Jim VK7JH MMedit |
Thanks guys. That worked especially when I turned on the power switch. Call me old fashioned. |
