Forum Index : Microcontroller and PC projects : PicoMite V6.00.02 betas
I'd certainly appreciate that. Thanks, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
V6.00.02b7 now available https://geoffg.net/Downloads/picomite/PicoMite_Beta.zip Fixes bug in RP2350VGA mode 3 Fixes bug in LIST SYSTEM I2C when GP1 is assigned to a special use Changing mode to itself now does a full clear |
Thank you Peter, I'll be having another look at the gamepad issues as soon as I find some free time. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
The bit I'm stuck with is how the device descriptor maps onto the bits in your sdl coding. In the case of my gamepad the 8 buttons are in byte 5 bits 4,5,6,7 and byte 6 bits 0,1,4,5 The d-pad is pseudo analog in bytes 0 and 1. If you look at the AI print on the other thread - you can interpret the analog dpad and it points to byte 5 and 6 for the buttons but I can't see how to understand which bits are which. Perhaps that is in the sdl info? Have you got a readout for PID E401, VID 081F? you can let me see? |
Found another bug of your latest version (with fixed mode3 - confirmed): Play mp3 works fine, but wav does not. It plays but it is awful broken distortet... Not overclocked (!) everything default VGA (ps/2) version with audio via PWM @ GP6,GP7 Edit: forgot to mention it is running on the Pico2... Greetings Daniel Edited 2025-02-03 21:00 by Amnesie |
> option list PicoMiteHDMI MMBasic USB RP2350A Edition V6.00.01 OPTION SERIAL CONSOLE COM2,GP8,GP9 OPTION SYSTEM I2C GP20,GP21 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION KEYBOARD GR OPTION CPUSPEED (KHz) 315000 OPTION SDCARD GP22, GP26, GP27, GP28 OPTION AUDIO GP10,GP11', ON PWM CHANNEL 5 OPTION RTC AUTO ENABLE OPTION MODBUFF ENABLE 192 OPTION F9 FLASH RUN 2 OPTION PLATFORM HDMIUSB Bug report for Loc() on drive b: (SD-Card) (RP2350A Edition V6.00.01) Sub testloc Open "tt.nsa" For input As #1 Print Loc(#1) Line Input #1,A$ Print A$,Len(A$) Print Loc(#1) close #1 End Sub > a: > run 1 DIR: nsa 8 11 > b: > run 1 DIR: nsa 8 219 The same code produces different results for different drives. If this has already been fixed, please just forget about it. tt.zip BTW: Line Input (and Loc()) works not with "open "xxx" for random"? Regards Michael |
Side effect of buffering reads - Will fix Typo introduced when implementing I2S - will fix |
Peter, I found another problem. The firmware of the WebMite RP2350A no longer works after version: Firmware updated WebMite MMBasic RP2350A Edition V6.00.02b5 Copyright 2011-2025 Geoff Graham Copyright 2016-2025 Peter Mather The standard versions do work in the Raspberry Pi Pico 2 W. This flashed in a Raspberry Pi Pico 2 W. PicoMite MMBasic RP2350A Edition V6.00.02b7 Copyright 2011-2025 Geoff Graham Copyright 2016-2025 Peter Mather Greetings, Jan |
The image has got bigger than I allowed - will fix |
Wow Peter, I can't imagine how much hard work this is to maintain all these versions. Thank you so much for all this effort! :) Greetings Daniel |
There is only one codeset with a bunch of conditional compilation so building the versions isn't an issue. What I can't do when in beta is test all the versions each time so I rely on feedback to iron out the bugs. Most like the ones reported today are completely trivial so its not a big deal. |
V6.00.02b8 now available https://geoffg.net/Downloads/picomite/PicoMite_Beta.zip Fixes bugs reported above |
WebMite MMBasic RP2350A Edition V6.00.02b8 Copyright 2011-2025 Geoff Graham Copyright 2016-2025 Peter Mather > option list WebMite MMBasic RP2350A Edition V6.00.02b8 OPTION SYSTEM SPI GP10,GP11,GP12 OPTION SYSTEM I2C GP4,GP5 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION CPUSPEED 200000 'KHz OPTION DISPLAY 48, 99 OPTION SDCARD GP15 OPTION AUDIO I2S GP1,GP13', ON PWM CHANNEL 11 OPTION RTC AUTO ENABLE > list pins GP0 1 OFF GP1 2 Boot Reserved : I2S BCLK GP2 4 Boot Reserved : I2S LRCK GP3 5 OFF GP4 6 Boot Reserved : SYSTEM I2C SDA GP5 7 Boot Reserved : SYSTEM I2C SCL GP6 9 OFF GP7 10 OFF GP8 11 OFF GP9 12 OFF GP10 14 Boot Reserved : SPI SYSTEM CLK GP11 15 Boot Reserved : SPI SYSTEM MOSI GP12 16 Boot Reserved : SPI SYSTEM MISO GP13 17 Boot Reserved : I2S DATA GP14 19 OFF GP15 20 Boot Reserved : SD CS GP16 21 OFF GP17 22 OFF GP18 24 OFF GP19 25 OFF GP20 26 OFF GP21 27 OFF GP22 29 OFF GP23 41 Boot Reserved : CYW43 GP24 42 Boot Reserved : CYW43 GP25 43 Boot Reserved : CYW43 GP26 31 OFF GP27 32 OFF GP28 34 OFF GP29 44 Boot Reserved : CYW43 > list system i2c HEX 0 1 2 3 4 5 6 7 8 9 A B C D E F 00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- 57 -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- > Thanks Peter. List system I2C now also works and also my 4x20 display and RTC clock. The audio works and with an Amplifier or Headphones or a Multi-point Bluetooth Transmitter I have excellent sound. We still miss Play Stream support for the PCM5102A I2S with 3 pins, otherwise we would also have affordable Web Radio. It does work with a VS1053 which I have yet to try. But very satisfied with a module I still had and it costs 3 Euro in China. I don't understand 'ON PWM CHANNEL 11 in the OPTION list? Greetings, Jan |
Play stream can never work with I2S. It relies on the VS1053 doing the real-time mp3 decoding without any defining header. I2S uses a PWM channel as a timer. Since the RP2350A can't use PWM 11 for any of its pins it is a good choice. |
V6.00.02b8 updated - no version change Fixes bug in PIO assembly of "OUT PC,n" command Allows ";" as a comment separator for PIO commands New PIO functionality for RP2350A and RP2350B Adds MOV PINDIRS,src as valid instruction Adds support for 'prev' and 'next' for the IRQ command New PIO functionality for RP2350B PIO SET BASE pionum, n 'sets the base of logical PIO pins to 0 or 16 to allow pins GP30-47 to be used for PIO Edited 2025-02-05 04:10 by matherp |
Hi Peter, MOV PINDIRS,x does not work yet. > list PIO assemble 1 .program test .line 0 Mov pindirs,3 Out pc,5 .end program list >run [5] Mov pindirs,3 Error : Syntax Volhout PicomiteVGA PETSCII ROBOTS |
Only RP2350 |
OK, That was a reserved destination in MOV in 2040 (probably planned for pindirs, but buggy). Thanks, I learned something new... Volhout PicomiteVGA PETSCII ROBOTS |
Also the valid sources are: pinS, x, y, null, status, isr, OSR you can't use a number. That would be a SET command NB: Away for the next few days so no updates Edited 2025-02-05 18:59 by matherp |
| cosmic frog Guru Joined: 09/02/2012 Location: United KingdomPosts: 311 |
Hi Peter, Just testing out the MP3 function on the RP2350Zero. In the manual it says - PLAY MP3 file$ [,interrupt] "..If file$ is a directory the Pico will play all of the files in that directory in turn." If I try PLAY MP3 "dirname" it says "ERROR:Could not find the file". If I then try PLAY MP3 "B:/dirname" it lists the directory and gives the error "ERROR:Display not configured". PLAY NEXT says "ERROR:Nothing to play" or if a track is playing it says "Last track is playing", yet the manual says "..[PLAY NEXT] Stops playback of the currnt audio file and starts the next one in the directory. > option list PicoMite MMBasic RP2350A Edition V6.00.02b8 OPTION SYSTEM SPI GP10,GP11,GP12 OPTION FLASH SIZE 4194304 OPTION CPUSPEED 200000 'KHz OPTION SDCARD GP13 OPTION AUDIO GP6,GP7', ON PWM CHANNEL 3 Thanks. Dave. |
