Local Time 12:42 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Armmite - STM32H7: Developments
     Page 11 of 11
Frank N. Furter
Posted: 07:35am 30 Aug 2018
Hi goc30,
is this where you live? VERY NICE!!!
Frank
Posted: 08:00am 30 Aug 2018
Release 5.04.29
This implements PRINT #GPS and SENSORFUSION as per the MMX (see the MMX manual for details).
2018-08-30_175244_Armmite1.3.zip
I think this completes all the relevant functionality from the MMX so I suppose it is time to do a manual for the Armmite H7
I'll start a new thread once the manual is complete as this will be the first full release. In the meantime please continue to report any bugs on this thread.
goc30
Posted: 09:47am 30 Aug 2018
  Frank N. Furter said   Hi goc30,
Frank
yesss! you see me??
panky
Posted: 07:38am 01 Sep 2018
Hi Peter,
I have my Nucleo up and running with the 1.2 backpack and with a small veroboard adapter, a 4" Pi ILI9481 LCD running just fine.
I have sucessfully set the display to also act as a console with
OPTION LCDPANEL CONSOLE but short of a reset, I can't figure out how to stop the LCD acting as a console - any suggestions?
Thanks,
Doug.
Posted: 07:48am 01 Sep 2018
  Quote  OPTION LCDPANEL CONSOLE but short of a reset, I can't figure out how to stop the LCD acting as a console - any suggestions?
OPTION LCDPANEL NOCONSOLE, same as MM+
goc30
Posted: 08:04am 01 Sep 2018
hi peter
I have a problem with input's pins
I want to use some pins in interrupt mode as explained in Micromite's doc like
SETPIN 42, INTH, Spbtn1
do
loop
sub Spbtn1
end sub
system send
Invalid configuraton
if I use without target, it accept my config and work correctly (need scanning in do...loop)
where is my fault ??Edited by goc30 2018-09-02
Posted: 08:32am 01 Sep 2018
  Quote  I have a problem with input's pins
Thanks for the report - hopefully this should fix it - no version change
2018-09-01_183214_Armmite1.3.zip
goc30
Posted: 09:11am 01 Sep 2018
I field good
I have also an Rotary encoder and for that I need interrupt mode
thank peter Edited by goc30 2018-09-02
Posted: 09:29am 01 Sep 2018
  Quote  I have also an Rotary encoder and for that I need interrupt
Here is my patented switch-bounce immune rotary encoder I/F code
option default integer
const false=0
const true=1
const in0=3 'encoder pins pulled high so should be reading high in detent positions, centre pin connected to ground
const in1=2 'swap the pin definitions as required to get the correct sense of rotation
init:
setpin in0,intB,rint 'enable interrupts on both edges of both pins
setpin in1,intB,rint
rotatedright=false
rotatedleft=false
resetenc=true
value=0
lastvalue=0
print value
MAIN:
if value <> lastvalue then
print value
lastvalue=value
endif
end
sub rint:
pin0=NOT pin(in0) 'reverse sense to get positive logic
pin1=NOT pin(in1)
if pin0 then
if pin1 and not resetenc then 'in0 and in1 both active
if rotatedleft and not rotatedright then
value=value-1
rotatedleft=false
endif
if rotatedright and not rotatedleft then
value=value+1
rotatedright=false
endif
else 'only in0 active
if resetenc and not rotatedleft then
rotatedright=true
resetenc=false
endif
endif
else
if pin1 then 'only in1 active
if resetenc and not rotatedright then
rotatedleft=true
resetenc=false
endif
else 'both off so reset
rotatedleft=false
rotatedright=false
resetenc=true
endif
endif
if pin(in0)=pin0 or pin(in1)=pin1 then goto rint 're-enter if another change has happened almost immediately
ireturn
goc30
Posted: 04:14pm 01 Sep 2018
hi peter
I had to change your "rint" sub because I had an error (too many subs for interrupt)
new version
sub rint
rint2:
pin1=NOT pin(in1)
if pin0 then
value=value-1
rotatedleft=false
endif
value=value+1
rotatedright=false
endif
rotatedright=true
resetenc=false
endif
endif
else
rotatedleft=true
resetenc=false
endif
rotatedleft=false
rotatedright=false
resetenc=true
endif
endif
if pin(in0)=pin0 or pin(in1)=pin1 then goto rint2 're-enter if another change has happened almost immediately
end sub
for digital inputs I use an anti-rebound procedure
my prog is like exemple prog in Micromite manual
const false=0
const true=1
const in0=49
const in1=50
Dim integer protb 'lecture pin 3 avec antirebond
Dim integer valrot 'valeur codeur rotatif
dim integer lastvalue
Dim integer vrot
Dim integer vrotsens 'sens de rotation 0=positif, 1=negatif
init:
setpin in0,intH,rint3 'enable interrupts on high of rot A pin
setpin in1,DIN
Protb=(Pin(in1) xor 1) 'to define first state of pin "B"
value=0
print value
MAIN:
'--- need 2 pass minimum with same value to confirm
Protb=((Protb*2) And 3) Or (Pin(in1) xor 1)
if valrot<> lastvalue then
print valrot
lastvalue=value
endif
end
'------- interrupt proc ----
rint3:
If Protb=3 Then 'state 1 confirm
valrot=valrot+1
'vrotsens=0
End If
If protb=0 Then 'state zero confirm
valrot=valrot-1
'vrotsens=2
End If
valrot
'Print valrot
IReturn
I also cabled the circuit specified by manufacturer in datasheet (2 x 10k and 1 x 10nf))Edited by goc30 2018-09-03
Posted: 11:01am 25 Sep 2018
  TassyJim said   Inbuilt editor seems to be happy.
I have created a spreadsheet with the pin mappings. MMBasic uses the CPU pin numbers.
The spreadsheet data is taken from the datasheet for the processor and the module.
There appears to be a lot of 5V tolerant pins which is nice to see.
2018-06-12_164535_NUCLEO-H743ZI-pinout.zip
Hi Jim.
I was just converting your spreadsheet into a load of Const statements so the ST notation can be used in my code and it threw up an error that D70 was already declared. Checking back to your spreadsheet, the offending lines are C:14 & C:55 on sheet 2
just sayin...
Posted: 12:31pm 25 Sep 2018
C55 should be D7
Posted: 02:21pm 25 Sep 2018
thanks
     Page 11 of 11
