Local Time 08:35 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite eXtreme V5.4.05
Posted: 12:04am 28 Jul 2017
Attached is the latest release 5.4.05 for the 100 and 144-pin parts
2017-07-28_095959_MMX5.4.05.zip
and for the 64-pin parts
2017-07-28_100050_MMX645.4.05.zip
This brings the MMX back in line with the Micromite and Micromite+
This fixes a bug in counting input (SETPIN n,CIN)
Other Changes are as per the Micromite:
New Features:
 Relaxed error checking on I2C addresses to allow addresses 7 and below to be used.
 ERASE will now also delete non array variables.
 Where the GUI command can operate on all controls (ie, GUI DISABLE ALL) it will now
only affect the controls on the current page(s). Previously it affected all pages.
Bug Fixes:
 Corrected a problem that caused the LEFT$() function to throw an error if asked to return
zero characters.
 Fixed a bug that prevented ERASE from deleting some arrays.
Posted: 12:55am 28 Jul 2017
Nice. thanks Peter.
Posted: 01:08am 28 Jul 2017
There is a bug in analogue input as reported by Micro-80 in another thread - been there for some time so obviously not much used - I'm working on it but looks like a compiler/library change so may be tricky
Posted: 01:17am 28 Jul 2017
On the subject of AIN.
What are the possibilities of providing an override for the voltage conversion - a switch that allows the ADC count to be returned instead. Maybe something like
SETPIN x,AINRAW
I have been using the CFunction ReadADC to do it but it is an overhead and I can't do it on MMX.Edited by CaptainBoing 2017-07-29
Posted: 05:12am 28 Jul 2017
  Quote  There is a bug in analogue input
This appears to be 100-pin specific - more testing needed but analogue on the 144 works fine.
If anyone has a 100-pin EFG please could they test analogue input
Current status is that it works fine on EFM but fails on EFH
Minor tweak for 64-pin which definitely works for analogue.
2017-07-28_160230_mmx645.4.05.zip
Remember on the MMX you can set the analogue reference voltage which is used to calculate the analogue levels
OPTION VCC N.NNNN
This option is not stored and defaults to 3.3 everytime the MMX is powered upEdited by matherp 2017-07-29
Posted: 06:25am 28 Jul 2017
hmmm.
never used pic32prog and my mmx100 has a hard soldered 1454
I installed it and found the port but no matter what baud rate I set it to it always says "FAIL" (yes i am pressing the mode button and getting a red LED)
I would happily test but I am a bit stuck with only 2 mins of playing in between work.
Posted: 06:33am 28 Jul 2017
UPDATE
Current status is that analogue input works fine on PIC32MZ2048EFM100 but fails on PIC32MZ2048EFH100. I'm interested to know if it works on a PIC32MZ2048EFG100
I can't see anything in the datasheet that would account for this as the only differences are that the EFM has crypto whereas the EFH doesn't and the EFH is approved for 252MHz operation
Posted: 06:35am 28 Jul 2017
Andrew,
What is the exact command you are typing to 'run' PIC32prog?
WW
Posted: 06:39am 28 Jul 2017
I am running it from the P32P Gui.exe
if you have a recommended ...
Posted: 06:44am 28 Jul 2017
Try following from a command prompt (assuming you running Windoze?):
pic32prog -d ascii:comx filename.hex
Substitute Port number (x) and exact filename. Make sure .hex file in same folder as pic32prog.exe
This is how I installed your MMX firmware into the 100pinner (not forgetting the Mode button press to turn on the red LED )
Edited by WhiteWizzard 2017-07-29
Posted: 07:06am 28 Jul 2017
It gets worse
I've got two PCBs with PIC32MZ2048EFH100 installed and one with PIC32MZ2048EFM100
The EFM works fine with analogue input AND one of the EFH works but the other doesn't and causes a restart whenever you try and read an analogue input. The chips are exactly the same ID and version
The analogue code I'm using is taken directly from the Microchip application note on using analogue on the MZ and before today I've never seen a problem. However, one of my boards behaves the same as Micro-80 reports but all others are OK.
All/any ideas appreciated
Posted: 07:55am 28 Jul 2017
Long shot - but something to consider.
IF the chips are 'samples' then I remember reading in MicroChip's 'Sample T&Cs' that the chips are not 'guanteed' I guess they may 'give away' their 'silicon errors'?
If you buy from them, then these may still contain 'silicon issues' BUT if their range is fast-moving, then you are more likely to end up with the latest versions of silicon.
Hope this makes sense . . .
Posted: 08:15am 28 Jul 2017
  WhiteWizzard said   Try following from a command prompt (assuming you running Windoze?):
still no joy. Complains it can't configure the port even when i force the baud rate on the port
Micro-80
Posted: 08:33am 28 Jul 2017
Maybe this link carries useful information about ADC in PIC32MZEFH100?
https://forum.mikroe.com/viewtopic.php?f=172&t=69030
Posted: 09:11am 28 Jul 2017
Andrew,
Which driver did you install? Have you got the MicroChip driver?
Worth uninstalling and re-installing (link on Geoff's site - scroll to bottom of page)
Posted: 09:19am 28 Jul 2017
  WhiteWizzard said   Andrew,
yep that is the same link. I am setting the baud rate from device manager and putty has no problem talking to it.
I have to zip out now.
Sorry Peter, it will be Sunday when I next get to play - hardly fits with any definition of "quick test"
mikroprofesszor
Posted: 12:59pm 29 Jul 2017
Hi everybody,
I'm a newby in the using of this forum.
Would anybody reply for my problem?
I use the Micromite 5.2 system for a simple program and I gave up to figure what I do in a bad way?
May be I caught an arithmetic bug in Micromite?
I should like use the 64 bit integer to store coded informations but the program code running unexpected way.
Larger numbers than 8,388,608 (hex80 00 00) the LSB bit of the result of neither arithmetic or logic operation vill be wrong.
See the picture of consol's history below:
Posted: 02:40pm 29 Jul 2017
Hi and welcome to the shed.
You need to specify Integers. By default, MMBasic uses floating point numbers and as you have seen, they are not exact.
Either set the default to integers or use the % suffix for integers
> x% = 8388603
> print hex$(x%,16)
00000000007FFFFB
> x% = x% + 1 :print hex$(x%,16)
00000000007FFFFC
00000000007FFFFD
00000000007FFFFE
00000000007FFFFF
0000000000800000
0000000000800001
0000000000800002
0000000000800003
0000000000800004
0000000000800005
0000000000800006
0000000000800007
read "MMBasic Characteristics" in the micromite manual for more details.
mikroprofesszor
Posted: 09:51pm 29 Jul 2017
Jim: Many thanks you for enlightening me!
(I note only in brackets: I used to write "Option default integer" in the very first line, except in this program)
Conclusion and recommendation: the electronic machine is always right!
Other:
I still have my ZX81 and it operates.
Have a nice day!
Cherokeecruiser
Posted: 03:34am 30 Jul 2017
Hi
Thanks heaps for the revised firmware
I dont have enough knowledge to provide any useful input into the problem with AIN, but can report that I have 2 boards of my own design currently with PIC32MZ2048EFH100 installed running the latest firmware and using analogue inputs. I have had no issues with this or earlier firmware using analogue inputs if this helps.
This is the board for interest - Its a weather station with 3G chipset to provide voice weather report and the display is repeated wirelessly to an additional MMX as a remote display
Works well, but I'm sure there are mistakes
