Forum Index : Microcontroller and PC projects : VT100 Output Help.
Hi All, Can anyone see what I'm doing wrong here? On the output screen, the "Active Point" is marked with a "*" at the beginning of the line. It's hard to follow that line easily with the eyes, so I thought I'd simply underline it. I can get that working, but then the formatting changes; Stuff moves to the left... Esc[4m attribute set to underline the active point, & stuff is moved left. This is the code that's writing the screen. The line to set the underlined attribute is shown commented out. After the point number & description are printed he TAB(18) is supposed to move to column 18 before the C_Val is printed. That seems to be what fails when the attribute is set. Thanks Phil. |
I think it's something to do with the TAB(). If I try padding it out with spaces, I end up with a mess, Double spaced etc, And I lose the alignment of the /'s separating the On/Up & Of/Dn values if they contain 2 digit values. Works fine until I try to introduce the attribute to underline the current point. |
@Phil23 Out of interest, does the weird formatting issue still occur IF instead you use a colour code setting to change the colour of the 'highlighted' line (instead of setting it with an underline escape code)? I have come across a weird issue with TeraTerm which appeared to show incorrect formatting - however, it then worked when using PuTTY. Maybe worth seeing if PuTTY works with your underline code. I am not in front of a MM at moment to be able to try this out - sorry WW |
I have never liked TABs. Always cause grief. TAB does different things depending on the terminal/text editor. Why don't you pad all the S_Desc$(Pn) descriptions out to the same length with spaces and do away with the TAB altogether. That will give you total control over the layout no matter which terminal you use to view it (or even pasting into a text editor) Jim VK7JH MMedit |
That was my first idea, to use colours, but it had similar issues, and was also breaking lines in two. Not sure what you are referring to as colour codes; I just tried colours with VT attributes. IE [Code] Yellow - Esc[33m Blue - Esc[34m and for the underline I used Underline - Esc[4m Normal - Esc[0m [/code] Using the colours I get this. |
Pretty much the same in PuTTY. Need to look at the HEX output, as I think the TAB is causing the issues. It's almost as if the characters used in the Esc codes are adding to the cursor position counter when MMBasic tries to output the spaces. |
This is the HEX capture of what the Micromite is outputting when the underline is set. Haven't tried to identify the TABS yet; work is calling. Phil [Code] 30 30 3A 32 30 1B 5B 66 1B 5B 66 20 20 50 23 20 00:20.[f.[f P# 44 65 73 63 72 69 70 74 69 6F 6E 20 20 4D 20 20 Description M 43 5F 56 61 6C 20 20 50 72 65 5F 33 20 20 50 72 C_Val Pre_3 Pr 65 5F 32 20 20 50 72 65 5F 31 20 20 52 5F 56 61 e_2 Pre_1 R_Va 6C 20 20 44 5F 56 61 6C 20 20 4F 6E 2F 55 70 20 l D_Val On/Up 20 4F 66 2F 44 6E 1B 5B 4B 0D 0A 3D 3D 3D 3D 3D Of/Dn.[K..===== 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D ================ 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D ================ 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D ================ 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D ================ 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 3D 1B 5B 4B 0D 0A ===========.[K.. 1B 5B 30 6D 20 20 31 31 20 41 6D 62 69 65 6E 74 .[0m 11 Ambient 20 20 20 41 20 20 31 31 2E 37 35 20 20 31 31 2E A 11.75 11. 36 33 20 20 31 31 2E 36 39 20 20 31 31 2E 37 35 63 11.69 11.75 20 20 31 31 2E 37 35 20 20 32 34 2E 30 30 20 20 11.75 24.00 20 31 2F 35 20 20 20 20 31 2F 35 1B 5B 4B 0D 0A 1/5 1/5.[K.. 1B 5B 34 6D 2A 20 31 32 20 52 6F 6F 66 5F 54 65 .[4m* 12 Roof_Te 6D 70 20 41 20 20 31 36 2E 32 35 20 20 31 36 2E mp A 16.25 16. 33 31 20 20 31 36 2E 33 31 20 20 31 36 2E 32 35 31 16.31 16.25 20 20 31 36 2E 32 35 20 20 32 36 2E 30 30 20 20 16.25 26.00 20 31 2F 35 20 20 20 20 31 2F 35 1B 5B 4B 0D 0A 1/5 1/5.[K.. 1B 5B 30 6D 20 20 31 33 20 4C 5F 44 5F 54 65 6D .[0m 13 L_D_Tem 70 20 20 41 20 20 32 31 2E 37 35 20 20 32 31 2E p A 21.75 21. 37 35 20 20 32 31 2E 37 35 20 20 32 31 2E 37 35 75 21.75 21.75 20 20 32 31 2E 37 35 20 20 32 33 2E 30 30 20 20 21.75 23.00 20 31 2F 35 20 20 20 20 31 2F 35 1B 5B 4B 0D 0A 1/5 1/5.[K.. 1B 5B 30 6D 20 20 31 34 20 42 65 64 5F 54 6D 70 .[0m 14 Bed_Tmp 20 20 20 41 20 20 31 35 2E 38 31 20 20 31 35 2E A 15.81 15. 38 31 20 20 31 35 2E 38 31 20 20 31 35 2E 38 31 81 15.81 15.81 20 20 31 35 2E 38 31 20 20 32 35 2E 30 30 20 20 15.81 25.00 20 31 2F 35 20 20 20 20 31 2F 35 1B 5B 4B 0D 0A 1/5 1/5.[K.. 1B 5B 30 6D 20 20 31 35 20 46 72 6F 6E 74 5F 4F .[0m 15 Front_O 66 66 20 41 20 20 31 37 2E 35 36 20 20 31 37 2E ff A 17.56 17. 35 36 20 20 31 37 2E 35 36 20 20 31 37 2E 35 36 56 17.56 17.56 20 20 31 37 2E 35 36 20 20 32 34 2E 30 30 20 20 17.56 24.00 20 31 2F 35 20 20 20 20 31 2F 35 1B 5B 4B 0D 0A 1/5 1/5.[K.. 1B 5B 30 6D 20 20 31 36 20 42 61 63 6B 5F 4F 66 .[0m 16 Back_Of 66 20 20 41 20 20 31 37 2E 35 30 20 20 31 37 2E f A 17.50 17. 34 34 20 20 31 37 2E 35 30 20 20 31 37 2E 35 30 44 17.50 17.50 20 20 31 37 2E 35 30 20 20 32 34 2E 30 30 20 20 17.50 24.00 20 31 2F 35 20 20 20 20 31 2F 35 1B 5B 4B 0D 0A 1/5 1/5.[K.. [/code] |
Padding the descriptors would probably make them hard to use elsewhere in the code, and I'm not sure how I would deal with keeping the Slashes in a line when a 2 digit number is used for the on/up etc. But I'm open to any suggestions. Lines are just hard to read across when they are mid screen for a selected point. Phil |
If you don't want to change the descriptors, padd as required as you print The 16 might need adjustment. MMBasic doesn't know that your 'underline' code is not a printable character so it is counted as printable. If you want to stick with TABs, you could also adjust the TAB(18) to TAB(xx) whenever you do the underline. Jim VK7JH MMedit |
Why not just output a real tab. It is CHR$(9). You still have to make sure the string you output is same length as a tab is left aligned and your numbers are right aligned. Having the output using tabs will make it a lot easier to import the output to a spreadsheet or other program. Microblocks. Build with logic. |
the below function, at$(), may be of some help to you: clrscr For X = 1 To 10 For Y = 1 To 5 Print at$((X*5)+10,(Y*2)+2) X*Y Next Y Next X Print at$(1, 20) "press enter to exit "; Line Input S$ End Function at$(x,y) at$=Chr$(27)+"["+Str$(Y)+";"+Str$(X)+"H" End Function Sub clrscr Print Chr$(27)+"[2J"; End Sub clrscr Print at$(21,3) ca$(4) "Colour MicroMite Demonstration" For B=30 To 37 For C=40 To 47 Print at$((B-25)*4, C-35) ca$(1, B, C) "abcd" Next C: Next B For A=0 To 9 Print at$(17+(A*4),14) ca$(0, 37, 40) Str$(A) Print at$(16+(A*4),16) ca$(A, 37, 40) "xxx" Next A Print at$(1, 20) ca$() "press enter to exit "; Line Input S$ End Function at$(x,y) at$=Chr$(27)+"["+Str$(Y)+";"+Str$(X)+"H" End Function Function ca$(A, B, C) Local temp$ temp$=Chr$(27)+"["+Str$(A) If B<>0 Then temp$=temp$+";"+Str$(B) If C<>0 Then temp$=temp$+";"+Str$(C) ca$=temp$+"m" End Function Sub clrscr Print Chr$(27)+"[2J"; End Sub cheers, rob :-) |
Thanks All, That's exactly what I discovered from the HEX output. Because MMbasic is incrementing the cursor position for the control codes, excluding the Esc, the [4m adds 3 to the cursor position, hence the TAB command adds 3 less spaces than required. I fried my brain a little trying to read the HeX output in Teraterm, before waking up to myself & realising Jim's HEX display in MMedit is far superior, having both Hex & Text on the screen, as any Hex display should offer. So yes, TAB(18) became TAB(21) & the 70 became 73. More readable now with the underline..... |
@Phil23 Immediately thought of you as I read the opening sentence to this article |
From the article (re spaces vs tabs): Yet: (survey of 12,400 developers). One could draw the "(non-?)objective conclusion" that if you code professionally in a variety of languages, and sometimes move your code for display or documentation purposes to an environment other than the one you use for coding, you will find out that tabs often cause display problems, and spaces never do. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
I find that when using spaces i have no control how the source looks like. Some people use two spaces, some four spaces for indentation. When it is done with tabs i can setup my preferences in my editor so that it looks like I want it to look like. Hence i always use tabs and never spaces. Also using proportional fonts that are so much better to read and use space much more efficiently will completely destroy a layout when spaces are used. With tabs again much more control and even proportional fonts will not completely mess up indentation. Especially when code snippets are used in documentation tabs will make the editing process a lot easier. Most editors nowadays will replace tabs with spaces while you type, without you noticing it. Until you have to go print out some, then you are in for a treat. All my editors are setup to use real tabs. Prevents a lot of time wasting editing later on. Microblocks. Build with logic. |
I can see there the TAB() gives me grief, & usually my screen layouts are controlled by the space characters. In this one, keeping all the forward slashes in a vertical line is required for the layout to appear correct. Doing that with spacing became messy & long winded, while the Tab worked just fine until Introduced some control sequences. Phil. |
instead of TAB() use chr$(9). Still even with that you will need to make sure your numbers are formatted with equal length so that you can right align them. As such it does not really matter what you use as a way to separate those values, you always have to make them fixed length before displaying. The easiest way to do that is with STR$() as you already did. The only difficulty arises with the '/' that needs to be aligned. [code] Print Str$(I(Pn,Curr_onup),4);"/";Str$(I(Pn,Time_onup));Tab(70);Str$(I(Pn,Curr_offdwn),3);"/";Str$(I(Pn,Time_offdwn));Esc+"[K" [/code] change that into: [code] Print Str$(I(Pn,Curr_onup),4);"/";left$(Str$(I(Pn,Time_onup)) + " ", 4);Str$(I(Pn,Curr_offdwn),3);"/";left$(Str$(I(Pn,Time_offdwn) + " ", 4);Esc+"[K" [/code] Above is untested, so play with it a bit. Microblocks. Build with logic. |
phil, the at$(x,y) function i posted earlier will allow you to position the cursor at an exact location on the screen, will this not achieve what you are after? multiple calls to at$(x,y) can be embedded in a single print statement, allowing you to reposition the cursor for each item in a multi-item print statement. the only thing you will need to ensure is that the numbers or strings you are printing are of a fixed field width each time round. cheers, rob :-) |
Thanks Rob, Yes, it will achieve exactly what I want & I plan on adding that function to all my screen output code. It will make life easier. Unfortunately I have one of those problem solving minds that needs to know why somethings not working. TAB() worked fine just plain text, but issues appeared when adding other attributes & control code. Puttting TAB() aside because it wasn't working properly, was tainted by one thing... Why??? I understand it's short comings now & can move on from it. Painful & time wasting, but it's how my head works. Cheers Phil. |
In MMBasic, TAB(x) inserts extra space characters into the PRINT stream to increase the size of the stream to the number in the TAB command. MMBasic has no idea where the data is going to or if the receiver interprets any characters as other than printing characters. TAB() is just one of the ways you can format your data before sending it. MMBasic seems to ignore some control codes when counting character positions. Sending a TAB character CHR$(9) requires the receiving device to do the formatting. In the case of a VT100 terminal, the tab stops can be set at any position so you would normally send the commands to clear all currently set positions and then set the required positions before using CHR$(9). If you rely on the tab stops being set before you send your data, you may be in for a few surprises. The other way control print locations is to use the VT100 commands to locate the cursor. Rob's at$() functions makes this easier to do. You need to set the line as well as column each time. This can add more work in keeping track of the line position but gives the most control. Earlier versions of MMBasic used the PRINT @x,y command to print at specified locations on the screen. It was intended for use on graphic screens but would also send the VT100 positioning commands (suitably scaled) to the console. Jim VK7JH MMedit |
