Local Time 15:10 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite eXtreme: The PCB portfolio
     Page 1 of 3
Posted: 12:10am 20 Mar 2017
For built versions and/or bare PCBs contact WW or use the gerbers to make your own
64-pin
Features:
PIC16F1455 USB/UART and PIC32 programmer
All pins broken out on a breadboard compatible 0.1" grid
Direct mount for 2.8" ILI9341 display including SDcard connection
Optional PWM control of display backlight
Gerbers
2017-03-20_092558_backpack64MZ.zip
Schematic
2017-03-20_092620_Schematic.pdf
100-pin: Type 1
Features:
All pins broken out
Function specific headers for COM, SPI and I2C ports
GPS header
GY-91 header
RTC header
Direct mount for 4.3" SSD1963 display
Micro SDcard slot
Onboard line-level sound output circuitry
6-off each pins to supply GND, 5V and 3.3V for additional circuitry
Gerbers
2017-03-20_093120_Backpack100min.zip
Schematic
2017-03-20_093141_Schematic.pdf
100-pin: Type 2
NB:
The picture shows the first prototype which has a few faults (wire links in picture). These are corrected in the attached gerbers but the revised version has not been fabricated at this point
Features:
All pins broken out
Function specific headers for COM, SPI, COUNT, Keyboard, mouse and I2C ports
PWM ports arranged for direct connection of servos with 5V supply
GY-91 header
RTC header
Direct mount for 5" and 4.3" SSD1963 displays
Micro SDcard slot
Onboard sound output circuitry with audio amplifiers for direct speaker connection
14-pin header for additional analogue and digital I/O with 14 each 3.3V and GND connections
Gerbers
2017-03-20_095340_Backpack100.zip
Schematic
2017-03-20_095022_Schematic.pdf
144-pin
Function specific headers for COM, COUNT, SPI and I2C ports
40-pin header for addition Analogue and digital I/O with 20 each 3.3V and GND pins
Onboard pullups for 8 I/O pins allowing direct connection of DS18B20 etc.
NunChuck Connection
PS2 Keyboard port
PS2 Mouse port
RTC header
Direct mount for 7" SSD1963 display
Micro SDcard slot
Direct PIC32 USB connection
VGA monitor port
Onboard line-level sound output circuitry with audio jack socket
Gerbers
2017-03-20_100754_Backpack144.zip
Schematic
2017-03-20_100824_schematic.pdf
Edited by matherp 2017-03-21
panky
Posted: 02:40pm 20 Mar 2017
Peter,
Absolutely awsome work - I have several of your 470 boards and a 144 Extreme and they all work flawlessy. Will round out the family with the other boards as soon as I can convince herself of my needs (for more toys )
Thank you for sharing your passion.
Doug.
palcal
Posted: 12:00pm 21 Mar 2017
@ matherp
I purchased a SnadPic baord and they have sent me the ECH version instead of EFH. Will it still work or do I send it back.
Paul.
Posted: 12:38pm 21 Mar 2017
send it back.
panky
Posted: 05:40pm 23 Mar 2017
Hi Peter,
Do you have a BOM for the boards above? If so, could you post it please? Even a rough list with the P/Ns of the bits you used would be helpfull.
Doug.
Intellecta
Posted: 01:10pm 24 Mar 2017
Dear Peter,
AS always ... fantastic work on the extreme devices and boards. I was interested in the 64 pin variation as a school project and I just wanted to try seeed pcb as a manufacturing option. They indicated a significant number of issues on the Gerbers - tracks to ground plane etc. I viewed the Gerbers in Diptrace with the same conclusion. Is there a correct version somewhere.??
Once again... fantastic work,
Tony Pugatschew
Posted: 02:28pm 24 Mar 2017
Hi WW, PeterM, All,
I note that Peter's 144 has all MALE headers and WW's has All FEMALE headers..
Is there going to be a standard here? Personally I have always felt that Males should be on the Main board and females on the Plug ins as if any header wears out it would be the female so the plugin is easier to replace than the main but in reality it is a moot point.. I don't want to build mine with the `wrong' headers.
Kind Regards,
MickEdited by bigmik 2017-03-26
VK2MCT
Posted: 03:44pm 24 Mar 2017
Hi All,
Does anyone (WW ?) have built Xtreme 144(s) for sale ?
I'm after 2.
Thanks,
John B
VK2MCT
Posted: 04:09pm 24 Mar 2017
My 144 has female headers for the display connector and the RTC.
No other headers installed yet and they will be male.
I would like the display header to be one with long pins so you have a female header on the underside and male header on the top side. That way a 40 way cable can be used to connect to a display, as well as the option to mount it piggy-back.
There is no way I am going to try and remove the 40 way connector now it's soldered on. I made do with a couple of 40 way male-male gender benders to use an old IDE cable. You have to be careful to get the pins the correct way around when playing with cables.
Posted: 09:12pm 24 Mar 2017
  TassyJim said   My 144 has female headers for the display connector . . .
There are various option cables out there (look for 40-way RPi GPIO cables). I have managed to use one such cable that allowed me to 'remote connect' a TFT with male pins to the female MMX.
It all depends on which side of the 'ribbon' the connector is mounted. With careful planning you can make your own cable without the need for a 'gender-bender'
WW
Posted: 10:36pm 24 Mar 2017
  Quote  hey indicated a significant number of issues on the Gerbers - tracks to ground plane etc.
DO NOT USE ANY OF THE ABOVE GERBERS!!!!!
I've just upgraded to DesignSpark V8.0 from 7.2 and it looks like there is a bug in the new release. I've submitted a support ticket.
Thanks for the heads up.
Posted: 11:06pm 24 Mar 2017
  bigmik said   Hi WW, PeterM, All,
Mine is just the testbed and was easier for me to include female headers for the I/O connections.
I supply the MMX with a female TFT connection (as most TFTs have male pins) AND female RTC sockets to accept the DS3231 module (that also has pins on it typically).
I then supply a range of pins/sockets (loose) so the end user can choose what they wish to use.
Some may even want to use right angle male/female . . .
WW
Posted: 06:03pm 25 Mar 2017
WW
I have used the IDE extension cables in the past but I spent a long time searching the shed for one without any luck.
I have plenty of standard IDE cables and 40 way female connectors so used what I had for now.
It works so that's good enough for me.
Posted: 07:52pm 25 Mar 2017
Hi Jim,
It would be interesting to know what distance can be obtained between the MMX and TFT connectors whilst still retaining a perfect image (and also accurate response to touch).
I was using a 6" (150cm) ribbon cable on a 4.3" SSD and it all worked perfectly.
What distance have you got there? Thanks
WW
Posted: 09:05pm 25 Mar 2017
@WW
Currently I am using a 300mm cable including the two gender-benders.
I would be more comfortable with 200mm M-F cable.
Posted: 10:39pm 25 Mar 2017
I now believe the Gerbers posted in this thread are OK. I've checked them with GC-Preview and the look fine. Please see attached response from DesignSpark support (very impressed with their responsiveness for a "free" product). Gerbview definitely seems to be the problem rather than the gerbers themselves.
  Quote  Can you identify the precise issue please, looking at the image seems to show more of a 'redraw' issue in the viewer. All viewers will also show render issues due to screen resolution until the layer is zoomed appropriately.
I attach an image using DFM Now! and a PDF from GC-Preview for examination.
I do not know which viewer you have, but we have always had reported issues with Gerbv as it is very selective in what it accepts from the Gerber files. DesignSpark PCB is checked against the Gerber licence holders software for compatibility.
Let me know what you find, whether it is a Gerber viewer issue, your gerber files are different from mine or more precise indication of the issue for me to explore.
Kind regards.
Posted: 05:03am 29 Mar 2017
Hello group.
for the MMX+144, I use the following CONST definitions to map the bank of IO pins on the board to the actual PIN number to use in your code.
Might help someone, it certainly takes the knots out of my brain
'Standard IO Mappings to Pins for MMX+144
'Legend for each is
' A - analogue capable
' 5 - 5V tolerant
' P - pulled up (use OC in your code when defining)
' use as follows
' SETPIN(IO1) etc...
CONST IO1=1 'A
CONST IO2=4 'A
CONST IO3=21 'A
CONST IO5=36 'A
CONST IO6=40 'A
CONST IO7=44 'A
CONST IO8=46 '5
CONST IO9=51 '5P
CONST IO10=53 '5P
CONST IO11=59 'A
CONST IO12=65 'A
CONST IO13=67 'A
CONST IO14=81 '5P
CONST IO15=83 '5P
CONST IO16=87 '5P
CONST IO17=100 '5P
CONST IO18=102 '5P
CONST IO19=113 '5P
CONST IO20=128 '5
CONST IO21=144 'A
CONST IO22=135 '5
CONST IO23=103 '5
CONST IO24=101 '5
CONST IO25=92 '5
CONST IO26=84 '5
CONST IO27=82 '5
CONST IO28=68 '5
CONST IO29=66 'A
CONST IO30=60 'A
CONST IO31=56 'A
CONST IO32=52 '5
CONST IO33=50 'A
CONST IO34=45 '5
CONST IO35=43 'A
CONST IO36=39 'A
CONST IO37=31 'A
CONST IO38=22 'A
CONST IO39=5 'A
CONST IO40=2 'A
Edited by CaptainBoing 2017-03-30
Posted: 05:31am 29 Mar 2017
  Quote  Might help someone, it certainly takes the knots out of my brain
Great, I'll add it to the manual as an appendix if that is OK?
Posted: 06:15am 29 Mar 2017
'course
Phil23
Posted: 10:53am 29 Mar 2017
  TassyJim said  I would like the display header to be one with long pins so you have a female header on the underside and male header on the top side. That way a 40 way cable can be used to connect to a display, as well as the option to mount it piggy-back.
Hi Jim,
Not sure if I remember clearly,
but when I built my E100, with the display connector on the wrong side I think when I considered a cable, I think I decided it wouldn't work as the pins would be mirrored.
Someone correct me if I'm wrong, but I thought the conductors in the ribbon cable would end up swapped at one end like this:-
[Code]
1 --> 2
2 --> 1
3 --> 4
4 --> 3
5 --> 6
6 --> 5
7 --> 8
8 --> 7
..[/code]
And assumption here is that you'd be connecting to the pins on the opposite side of the board.
Phil.
Edited by Phil23 2017-03-30
     Page 1 of 3
