Local Time 22:59 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite and Micromite Plus Beta 31
Posted: 06:12pm 19 Sep 2015
Another beta. Hopefully this one has nailed all the lingering bugs in the MX170 version (famous last words). You can download it from: http://geoffg.net/Downloads/Micromite/Micromite_4.7_Beta.zip (clear your browser cache first).
The changes are listed in the file Changes.txt but the important ones are:
- Fixed the bug related to the TOUCH(X) function.
- Implemented the ability to call the subroutine MM.PROMPT at the command prompt. The manual has been updated to document this feature (page 21).
Please let me know if you find any more bugs.
atmega8
Posted: 08:11pm 19 Sep 2015
Geoff,
issues.txt says:
"The Silicon Chip Driver has issues with Windows 10. The workaround is to power
the PIC32 separately (ie, not use the USB +5V)."
So we have to wait until Silicon Chip or Microsoft will fix the Bug?
When providing external Power, but use the USB console, will the console work?
( I will test this tomorrow..)
THX for all this cool enhancements😄, great!
Atmega8
Edited by atmega8 2015-09-21
Posted: 08:14pm 19 Sep 2015
  atmega8 said  So we have to wait until Silicon Chip or Microsoft will fix the Bug?
I should be able to fix it in firmware. I will let you know.
atmega8
Posted: 08:22pm 19 Sep 2015
Thank you Geoff.....
Posted: 09:13pm 19 Sep 2015
@Geoff,
Possible bug . . .
On 28-pin MX170 (not tried any other MMs), with a MM.PROMPT Sub (either saved in library; or just existing within a program), then you loose the '>' prompt at the start of the line.
I am using usb-to-ttl into TeraTerm.
As soon as I delete (or rename) the MM.PROMPT sub (or library) then the '>' returns
WW
kiiid
Posted: 09:21pm 19 Sep 2015
Geoff, I would like to find out a bit more about the mentioned issue with pin 22 and ssd1963-based displays. Can you please say a few words why is it and will pin 22 be available for use in future or, or never?
http://rittle.org
Posted: 09:25pm 19 Sep 2015
@Geoff,
If you exit the Editor using ESC, the MM.PROMPT Sub is not run (and you see the '>' prompt)
Posted: 10:37pm 19 Sep 2015
After a LIBRARY SAVE, the MM.PROMPT sub is not run and the prompt is the default.
After LIST it is run and the prompt reverts to my custom prompt.
18:24:32 >> LIBRARY SAVE
> list
18:25:10 >>
18:25:16 >>
18:25:17 >>
18:25:17 >> library list
Sub MM.PROMPT
Print Time$ " >> ";
18:25:47 >>
18:26:19 >>
MMEdit looks for the ">" in a few places so custom prompts which don't end in ">" will cause a few issues. I can add a timeout, but for now, please put the ">" in the custom prompt string if you are using MMEdit.
Posted: 10:51pm 19 Sep 2015
After reading Jim's post (and Page21) I see that the built-in command prompt is 'removed' and hence ignore my previous post . . .
  WhiteWizzard said   @Geoff,
Possible bug . . .
WW
However, MM.Prompt is not run when using 'ESC' to exit the Editor; as well as immediately after LIBRARY SAVE. I assume it should be??
Chris Roper
Posted: 11:55pm 19 Sep 2015
This is a weird one:
I did an XModem transfer of this code:
[code]
Const ds4 = 4
Const ds3 = 5
Const ds2 = 6
Const ds1 = 7
Const sw1 = 16
Const rp1 = 26
sub mm.prompt
setpin ds4, dout
setpin ds3, dout
setpin ds2, dout
setpin ds1, dout
setpin sw1, din
setpin rp1, ain
Print "LPCDB>"
end sub
[/code]
and the Micromite (28pin) went into an unbreakable loop with the following Console Output:
Chris
http://caroper.blogspot.com/
boss
Posted: 06:24am 20 Sep 2015
@Geoff
Does exists road map for 100 pin chip FW?
Bo
Posted: 12:05pm 20 Sep 2015
Chris
I think the important part is the error message I got at the beginning of the output:
sub mm.prompt
setpin 4, dout
setpin 5, dout
setpin 6, dout
setpin 7, dout
setpin 16, din
setpin 26, ain
Print "LPCDB>"
end sub
Saved 313 bytes
[11] SetPin 4, dout
Error: Pin 4 is reserved on startup
[11] SetPin 4, dout
[11] SetPin 4, dout
I am using pin 4 for the LCD so the error message is valid, just no way of fixing it.
Eventually the message changed to too many SUBs the same as Chris.
I was unable to reset the MM+ and had to bring out the programmer....
I think that if there is an error in MM.PROMPT, we should be put back to the normal prompt without trying to run the sub again.
Posted: 02:49pm 20 Sep 2015
  boss said
@Geoff
Bo
I know I am not Geoff, but I do know that the 100-pin version has not been developed yet, so there won't be any road map or other. It is mentioned in the documentation, as once the 64-pin one is up and running and as bug-free as possible, it is my understanding that the 100-pin chip will follow soon after that - it is a future release. But for right now, it is sort of in limbo, so to speak.
Posted: 03:36pm 20 Sep 2015
Yes, now that I am concentrating on the MX470 (Micromite Plus) I plan to do the 100-pin version as well as some important bugs (eg, USB and Win 10).
This beta has a couple of issues with MM.PROMPT - First, it is not consistently recognised after EDIT, XMODEM, etc. The second is that an error inside the sub causes mayhem. I will fix both of these in the next release.
  kiiid said   Geoff, I would like to find out a bit more about the mentioned issue with pin 22 and ssd1963-based displays. Can you please say a few words why is it and will pin 22 be available for use in future or, or never?
This is only temporary. Another priority for the next beta.
CFLY
Posted: 05:18am 21 Sep 2015
Thank you Geoff!
TOUCH (X) is OK and TEST GUI TOUCH also on screen 5 '
CFLY
Posted: 11:06pm 21 Sep 2015
A pb !?
I load my program (in B31, Micromite+) by the serial interface with MMEdit,
I enter the "option autorun on",
Off/on the supply and the program start ... OK.
I disconnect the serial interface,
Off/on the supply and nothing !!!
I connect the serial interface,
I disconnect only the the link "Data to Micromite",
Off/on the supply, "Micromite Plus MMBasic Ver 4.7 Beta 31 ..." on MMEdit ... OK, but the program is not started
I connect the link "Data to Micromite" and I disconnect "Data from Micromite", no prompt on MMEdit ... OK and the program start
With serial interface connected, I stop MMEdit,
Pb known?
CFLY
Posted: 11:15pm 21 Sep 2015
With the serial<=>USB disconnected from the pc, not ok
With the serial<=>USB connected with only 5V it's ok ...
CFLY
Posted: 11:24pm 21 Sep 2015
With the serial interface (serial console) not connected, after power on, I can, only, star the program by the reset switch ...
CFLY
Posted: 11:26pm 21 Sep 2015
On my card, the MCLR has only a 10k on 3.3v ...
Posted: 11:57pm 21 Sep 2015
Sounds like you are getting parasitic power from the serial connection, and once you remove that connection, that source of parasitic power is then gone, so the chip does not start, or has a dirty start because there is no 'Clean' power. Parasitic power can supply enough power to run the chip, if that is where the supply is coming from, so you need to look carefully at the way you are powering the chip.
What exactly are you using to power the circuit?
Are you using a pre-built module or your own chip circuit on a breadboard?
Breadboards have been the source of many problems before today......
EDIT: Seems OK on my module - I just setup a "Hello" loop, and then reset the MM+, and away it went as it was supposed to:
Edited by Grogster 2015-09-23
