Forum Index : Microcontroller and PC projects : Number to string
| Chrisk Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 137 |
Hi Guys I have a need to convert a number to a text string. I thought that this would work however when I run it it get the error message shown below. CUR=0 Print CUR If CUR=1 then CUR$ = "open" else CUR$ = "closed" Endif Print CUR$ End [4] Else CUR$ = "closed" Error: Unexpected text Can someone assist please Regards Chrisk |
Hi Chrisk, As anyone here knows, I am not a really good programmer but what if you put your ELSE statement in the same line as your if statement? I.e. Remove the line feed before ELSE. You prob need to remove the endif also in my example Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Hi Chrisk, Mick is right! CUR=0
Print CUR If CUR=1 then CUR$ = "open" else CUR$ = "closed" Endif Print CUR$ End OR CUR=0
Print CUR If CUR=1 then CUR$ = "open" else CUR$ = "closed" Print CUR$ End BTW I think it is a good practice to use different var names to make your code more bulletproof. (e.g. Cur_num and Cur_str$) Regards Michael |
| factus10 Regular Member Joined: 30/12/2014 Location: United StatesPosts: 45 |
ChrisK, You can do this with an array, too. DIM CURS(1) AS STRING = ("Closed","Open") cur = 0 print curs(cur) v4.5 dim cur$(1) length 6 cur$(0) = "Closed" cur$(1) = "Open" cur = 0 print cur$(cur) To fix your code, put the CURS$="closed" on its own line. |
Completely agree. Although you probably can use CUR as a numeric variable, and CUR$ as a string, I also think that is a bad idea. While it may well work just fine if MMBASIC does not care, but it would make your code a nightmare to debug, as you would be confusing CUR and CUR$ all the time, and they are two distinctly different variables - not my idea of fun! Smoke makes things work. When the smoke gets out, it stops! |
Thanks Guys Some good suggestions here. I will implement the solution ASAP. Thanks again for your prompt replies. It was bugging me for ages. Chrisk |
| Dylan Regular Member Joined: 17/06/2013 Location: NetherlandsPosts: 81 |
Disagree completely and utterly. The $ sign is part of the variable name in BASIC. It is pronounced "string". It is natural to use X$ ("x-string") for the string representation of X (a number), in much the same way that it is not natural to use X_str$ ("X underscore <str> string") for a completely unrelated number X_num. That said, ONLY use the same variable "name" for both numbers and strings if they represent the same thing - as they do here - unless of course you are limited to single characters (A-Z and A$-Z$) which is not the case here. |
You may disagree but in 4.7 it is not allowed. Like many things this is a judgement call but the issue is that unless you force variable declaration for all variables, i.e. dim a as integer dim a$ as string then it is too easy to type "a" when you intended "a$". Without strict data declaration and typing this doesn't generate an error but just creates a new unintended variable making debugging a nightmare. For this reason, and with the inclusion of integers since 4.6, as a new datatype, Geoff has now made trying to declare "a" and "a$" in the same program give an error: "Error: variable or constant already declared" You can still do what you want but in a more controlled way DIM myvar_int as INTEGER DIM myvar_str as STRING note that you don't have to use $ to make a string but you could equally go DIM myvar_int% DIM myvar_str$ |
| jeffj Regular Member Joined: 04/02/2012 Location: AustraliaPosts: 84 |
Hi folks I am stuck on a string problem the foll is a test programme for an alarm system I cannot get the program to print the text of the alarm name eg when AL(i)=1 I want it to print Battery.I cannot get around mixing up Nos and text Yr help would be appreciated jeff AL1$= "Batty" AL2$= "NFT flow" AL3$= "Pump- ExStarts" AL4$="G House Leak" dim AL(5) i=1 let AL(3) =1 do A=(i) print "A=";A B$= str$(A) print "B=";B$ if AL(i)=1 then print AL;B$;$'This Not ok print AL1$'This ok i=i+1 loop until i=4 end |
This if AL(i)=1 then print AL;B$;$'This Not ok is bad syntax. There is no such thing allowed as $ by itself - see the semi-colon. It would also fail because AL is an array and you would need to say which element i.e. AL(1) or whatever. John |
More info: You probably want to put the strings AL1$, AL2$ etc into an array, say name$(4). Then you can print name$(i) in your loop. I suggest you either read up more on BASIC syntax or look at sample programs - or both :) John |
@Chrisk -- I think you have two separate problems here. 1. You are mixing the single line IF with the multi-line IF. Either form should work. if CUR=1 then CUR$="open" else CUR$="closed" or if CUR=1 then CUR$="open" else CUR$="closed" endif When MMBasic sees If CUR=1 then CUR$ = "open" it thinks it is reading a single line if construction and it has reached the end of the line and the end of the construction.Then in the next line it sees else CUR$ = "closed" and doesn't know what to do because it isn't expecting an ELSE so it stops and says "Unexpected text".2. In line 1 you define the variable CUR as either an integer or a float with CUR=0 then, in line 3, you define it again as a string with CUR$="open". MMbasic might accept this, but after the second definition of CUR$ as a string the first definition with CUR=0 will likely cease to exist. Microsoft BASIC, and its doppelgangers, permitted the simultaneous existence of the same variable name as multiple types, that is A$ (string), A% (integer), A! (16 byte float) and A# (eight byte float) could all exist simultaneously. In order to simplify the internal variable table Geoff decided not to follow this pattern. You can't use the same variable name as different type variables at the same time. You can, however, add a suffix to the variable name like this. CURi%=0 : CURf!=22 : CURs$="sss" @jeffj -- Your code is failing in line 14 if AL(i)=1 then print AL;B$;$ This asks MMbasic to print "AL" which has not been defined, then print "B$" which has been defined, then print "$" which is not a valid variable name but a type designator. If you're trying to print failure codes based on the setting of an integer try this ' define and fill a message$() array with strings DIM message$(5) = ("Batty","NFT flow","Pump- ExStarts","G House Leak"," ") ' define a trip array DIM trip%(5) ' this automatically fills all the elements with zero ' test it for i%=1 to 5 for j%=1 to 5:trip%(j%)=0:next j% ' set all trip%(1-5) elements to zero trip%(i%)=1 ' set one trip%() element to 1 ' display the results print "For i = "; i% for j%=1 to 5 if trip%(j%)=1 then print " j = "; j%, "TRIP! "; message$(j%) else print " j = "; j%, "NO TRIP! " endif next j% next i% end Have fun guys. Paul in NY |
Maybe I have missed this but having gone through the thread, there seems to be a lot of "might be allowed..." etc but no-one seems to have picked up on this... you can't have CUR and CUR$. It seems the way variable names are handled that the type indicator can be implicit but the name part is absolute. > clear > cur=1 > cur$="fred" Error: CUR already declared > I think this is the root of the OP's problem |
aahemm ... @CaptainBoing/Andrew 1. This thread is 3 year old. 2. Peter (matherp) explained it (the OP's problem) perfectly (3 years ago). Sorry! The second issue (jeffj's) seems also solved. Best regards Michael |
LOL! good catch... I guess I was too intent on reading the thread to notice the dates Thanks for pointing it out |
Yes, twofingers is correct. This thread is very old now, and A-LOT of development has happened within MMBASIC in the last three years, I am sure most members here would agree. ![]() @ Glenn - Would it be worthwhile locking threads that get this old, and that way, no-one can post on them once they get to a certain age? This would mean any questions about what was in the thread, could be addressed easily with a NEW thread, that points to the old one, so people can go back and read the old thread if they want to. I probably have missed something obvious here, otherwise old threads WOULD be auto-locked, but..... The fact that members were caught out by reading the old info and not quite noticing the age of the thread first, is a case in point. Smoke makes things work. When the smoke gets out, it stops! |
Thanks Paul for yr prompt reply. I know it was an old post but it was the only one I could find that was relevant to strings. I tried to click on "new topic" but it wouldn't work Paul I am having a problem with line 4 It comes up with the error unable to find variable and I couldn't find how to fix it' The % in the code has me foxed.Excuse my ignorance thanks Jeff |
Jeff, What device are you programming on - Maximite or micromite etc? and what version of MMBasic is it running? There are a lot of differences between the devices and getting advice for the wrong setup will cause much head-banging. Jim VK7JH MMedit |
Hi Jim V4.5 and mono maximite Jeff |
The % in the code has me foxed.Excuse my ignorance thanks Jeff Hi Jeff, Line 4 in your code seems to be AL4$="G House Leak" Is that the line which produces the error unable to find variable? That doesn't make any sense since line 4 simply defines and initializes a string variable.A "%" following a variable name defines it as an integer variable, the "$" makes it a string variable, and the "!" makes it a floating point variable which can store decimal points and fractions. The first time MMBasic sees a variable it will assume it is a floating point variable unless it is told otherwise. You can define variables before using them with the DIM command -- DIM xyz as string -- or -- DIM xyz$. After doing this MMBasic will handle xyz as a string even if you do not include the "$" after the variable name. I, personally, like to use the type identifiers after each use of a variable like this. for i%=1 to 10 print i% next i% This makes my code look like it's full of fly specs, but it keeps the variables sorted out. Arrays also have a type property and must be defined with a DIM before being used. ' define and fill a message$() array with strings DIM message$(5) = ("Batty","NFT flow","Pump- ExStarts","G House Leak"," ") ' define a trip array DIM trip%(5) ' this automatically fills all the elements with zero Loops work faster when the counter variable is an integer. for i%=1 to 10000:print i%;:next i% ' integer counter if faster than for i=1 to 10000:print i;:next i ' float counter Have fun. Paul in NY |
