Forum Index : Microcontroller and PC projects : Micromite V4.7 Beta 8
I have a new beta version of V4.7 for the Micromite for anyone who would like to try it out. It can be download it using this link: http://geoffg.net/Downloads/Micromite/Micromite_4.7_Beta8.zip This has three major changes over beta 3. - The character set of font 2 has been expanded to include the space, plus, minus and equals characters in addition to the existing numbers and colon. - The SPI port can also be used within a BASIC program at the same time as it is being used with the LCD and touch controllers. - CFunctions now have the ability to call some functions within MMBasic. This means that they can do more intelligent things. As an example, included in the zip files are new versions of SerialTx and SerialRx that now work with any I/O pin (you simply specify just the pin number, no lookup table is required). @G8JCF will be updating his tutorial to suit and I believe that @matherp will have some new and interesting CFunctions that use this new ability. Great thanks to both of these gentleman who helped to refine this feature. Also included are the updated pages from the Micromite Manual describing the new features (changes are highlighted in yellow). Geoff Geoff Graham - http://geoffg.net |
Thanks Geoff, thanks PeterM! That's fantastic!
Do you think that we can get an extension of the PEEK function to locate the character set table (to replace some characters using POKE e.g. "°" the degree sign)? That's seems to open a new world!
Regards Michael EDIT: The chr$(127) looks a bit strange! Or I need glasses. |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12181 |
Michael The font table is in flash so can't be changed with POKE. You can use the Bitmap command to output any arbitrary 8x8 bitmap. Try bitmap x,y,&H0000000c12120c00 |
Hi Peter, thanks for the quick clarification!
Maybe I can patch the hex file. For your Graphic Library I replaced chr$(127) with the degree symbol. BITMAP can serve as a workaround, I think. But the degree symbol in the character set would be more convenient. I'm lazy! [)] Regards Michael EDIT: or BitMap 10,20,&HFFFFFFF3EDEDF3FF (black on white) BitMap 10,30,&H0000000006090600 BitMap 10,60,&HFFFFFFFFF9F6F9FF (black on white) Jims(Tassyjim) font editor (called "fontoMite") can be a tool for creating bitmap patterns. |
Very nice additions Geoff..! I love the "auto control" of the CS pin... Makes it dead easy for the end user to get things working... Ok... as you close the SPI port, the CS pin goes back to open pin assignment... So, each SPI device's CS pin needs a soft (10k) pull-up to keep it off the bus... Also, should there be pull-up's for the display and touch controller also..? Not trying to be a pest, but wanted to set my thinking straight on this from the get-go... |
Hi Zonker, My thinking was that before any command was run (SPI OPEN, CONFIG LCDPANEL, etc) the chip select pins could be used for anything - therefore they should not have a soft pullup enabled. After they are opened they are driven by the firmware both high and low so no pullups are required. I am not sure that many programs would want to close the SPI channel after it was opened but if they did, and they wanted CS to be high, then yes, an external pullup would be required. If CONFIG LCDPANEL DISABLE was used the user obviously does not want to use the LCD any more so the chip select (and other pins) should go to unconfigured as they were before CONFIG LCDPANEL was used. Geoff Geoff Graham - http://geoffg.net |
No, your eyes are OK. That is a bug, the character is not in the printable character set and therefore should have printed as a blank (I will fix it in the next release). By the way, in this version unprintable characters will print as a space. I thought that this was more helpful than the previous version which did nothing. Geoff Geoff Graham - http://geoffg.net |
Beta 8 meter test... (more playing)... 2015-05-29_042724_2-4_inch_meter_test.zip
| viscomjim Guru Joined: 08/01/2014 Location: United StatesPosts: 925 |
Just tried your meter code Zonker. Very cool. Thanks for posting! |
Gday Zonker, Hey! I love that Meter test.. Any chance of implementing it to read actual ANALOG inputs ? Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
| ThierryP Newbie Joined: 12/04/2012 Location: NetherlandsPosts: 12 |
Tested the Micromite with 4.7 beta 8 on a "HY-1.8 SPI" display I had lying around. Works OK, which I hoped it would, as it's an ST7735 with same specs as advised in the manual. Difference: works with 3.3V or 5V and has a LED current limiting resistor built-in. see: Ebay |
@bigmik Ok... get R1=100k and R2=20k and a .1 cap and attach it to pin 5... This should scale down the 20 volt scale back in range... Then run this... 2015-05-31_221800_2-4_inch_volt_meter_demo.zip Works OK here... |
Hi Zonker, Have I missed something here? It must be too early in the morning for me.
20V range is on the `meter' ... Where would I connect the R1, R2 and Cap? I would have just fitted a potentiometer between 3v3 and GNd with the wiper on pin(5) and adjusted the scale to read 0-3.3 or similar.. Regards, Mick PS. Ohhh, I am waking up... I think you intend me to connect up to 20V with a voltage divider that would make the max reading 1/6 of 20v or 3.3v on pin(5) with presumably a smoothing cap pin(5) to Gnd?? Mik Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Mike, I was wondering where the 20v had come from too - was that another thread? If anyone tries this, can they post a video please? WW |
Yep... That was the Idea...
Of course, you can play around with the code and make the meter scale to be different.. I figured 20v would be useful for something..! The main thing, is to try creating more GUI toys to share about..!! I kinda like the graph chart trend display..!! These touch panels are awesome.... |
Good evening Gents... I must admit to a little head scratching going on here...
I am trying to talk to an external SPI chip while running the 2.4" touch panel and just keep getting back zeros for the IC data.. After looking through the PDF, and trying several things, I'm kind of stuck, not knowing what to try next... I am trying to read the status reg inside the IC. To do that you need to send the read command byte, (value=3), address MSB byte, (0) address LSB byte, (0) and then read back the value of the status reg... So, taking the advice in the PDF, I let MMBasic control the SPI CS pin and setup a simple test: Sub LTCread_status_reg SPI open 4000000,0,8,26 ' 4meg speed, mode 0, 8bits, CS=26 SPI write 3,3,0,0 SPI read 1, LTCrxdata%(1) SPI close end sub I do dim the LTCrxdata var before calling. If I unplug the IC I do get back the expected 255 (hex FF) so I think the hardware and code snippet are working... I guess the first question is how does the CS get turned on and off... Each transaction in the snippet starts by opening the SPI port, then starting to do the write command... this should drop the CS line low.. After completing the read command, the SPI port is closed.. (just like the example in the PDF) Now, to me, this doesn't make sense... If you close the SPI port. the CS pin will be "de-inited" back to a floating pin, and without a pull-up, might interfere withe the LCD display... I would like to open the the SPI port just once and leave it open... If I do that, then how does the MM firmware know when the CS pin needs to go high..? Or, does it cycle the CS pin on every read or write command..? If so, this could be the cause of my problem.. The CS pin must stay low during the writing and reading commands as a group... It's to late tonight to get out the scope to check... I have two 28pin based DIP-600-28 boards both running v4.07 beta 8 firmware The original program without the LCD installed is using the standard SPI type commands and was written for the v4.6B firmware and works fine... I then moved it to v4.07B8 firmware on the first board and works just fine using the standard SPI commands as used in v4.6B... The second board has the LCD installed... It was tested and the touch cal went OK... I can write a "time$" string to it and seems to work correctly... I tried at first using the program "as-is" but kept getting back zeros... So, after going over the examples again in the PDF, i decided to rewrite the subroutine like above and test it... yep, still getting back zeros... Yikes.. Losing beard hair over here..!!
Has anyone else tried doing this type of setup..? Any feedback might help... Thanks Gent's..! |
It has to do this as otherwise a graphic or touch call between two SPI calls will fail. In this case you must handle CS manually rather than letting the software do it for you. I think there may be a case for a new SPI command "SPI exchange" in which the outgoing data is replaced with the incoming data. Thus would allow you to combine the write and read commands into a single statement. Remember in all SPI transactions at a hardware level a databyte is read for each byte output and visa versa |
I tried going back to controlling the CS with the old routines and still got back zeros... So, I disabled touch and LCD and hit run again... Works like a champ... Next , i tried pulling up the SPI data pins with a 2.2k resistor to see if that would help... No luck... I will try connecting just a single channel thermo IC to see if that is affected also... Has anyone else out there tried the SPI Port..? Will keep playing... |
Yes it does... and that I think is the cause of the problem. This issue with SPI has been causing me some angst also. Sharing the SPI with the display and touch is not as easy as it first seems. The main problem is that SPI is not really standardised, especially the behaviour of the chip select signal. My thinking at this time is that it is best to scrap the idea of letting MMBasic manipulate the CS pin and trying to switch configurations back and forth. So, in your program you should initialise CS and manipulate as you wish. This means that pullup resistors are not required. Also, the SPI port should be opened just before any send/receive and closed straight after. Between the OPEN/CLOSE you should not use a command that sends something to the display or use the TOUCH() function - MMBasic will throw an error if you do (in the next beta). The following example (using your code) will work in the current beta: ' initialise everything DIM LTCrxdata%(2) PIN(26) = 1 SETPIN 26, DOUT ‘ pin 26 will be used as the enable signal ' other stuff including possible display and touch commands LTCread_status_reg ' get the status reg ' more general code including possibly more display and touch commands LTCread_status_reg ' get the status reg for a second time ' more stuff END ' sub to get the LTC status Sub LTCread_status_reg SPI open 4000000,0,8 ' 4meg speed, mode 0, 8bits PIN(26) = 0 ' chip select low SPI write 3,3,0,0 SPI read 1, LTCrxdata%(1) PIN(26) = 1 ' chip select high SPI CLOSE end sub Does this sound workable? Geoff Geoff Graham - http://geoffg.net |
Zonker I've just tested this by patching the touch controller across to another pair of control pins. So I have "option touch 3,4" and "option lcdpanel ili9341,p,15,9,11" set up The touch control pins are then actually connected to pins 2,1 The attached program then works fine. 'Display commands on MX170: ' 'DISPLAY OPEN displayname, command/data pin, chip select pin, reset pin ' Valid displaynames are ILI9341 and ILI9163 'DISPLAY CLOSE 'DISPLAY xstart, ystart, foreground colour, background colour, textstring, (optional x-scale, or x and y if only this parameter specified),(Optional y-scale) 'PIXEL x-coordinate, y-coordinate, colour 'LINE x-start-coordinate, y-start-coordinate, x-end-coordinate, y-end-coordinate, colour 'CLS (optional parameter colour) 'BOX x-coordinate, y-coordinate, width, height, colour, (optional parameter F to fill) 'CIRCLE x-coordinate, y-coordinate, radius, colour, (optional parameter F to fill) 'TRIANGLE x1-coordinate, y1-coordinate, x2-coordinate, y2-coordinate, x3-coordinate, y3-coordinate, colour, (optional parameter F to fill) 'BITMAP x-coordinate, y-coordinate, foreground colour, background colour, bitmap (long long integer giving 8 x 8 bitmap). ' The code treats this as an array of type char[8]. This is read bit7 to bit0, array-index[0] to array-index[n]. The screen then updates the 8 x 8 box top left to bottom right. 'RBOX x-coordinate, y-coordinate, width, height, radius of corners, colour, (optional parameter F to fill) 'ROTATE orientation. Orientation can be: ' 0: Portrait ' 1: Portrait 180 ' 2: Landscape ' 3: Landscape 180 ' ' option explicit option default NONE CPU 48 ' const NSAMPLES=9 'number of times to sample each touch point const t_CS=2 'chip select pin for XPT2046 touch controller const T_IRQ=1 'interrupt pin for XPT2046 touch controller DIM INTEGER XLEFT0, XRIGHT0, YTOP0, YBOTTOM0 ' global variables to hold calibration values DIM INTEGER XLEFT, XRIGHT, YTOP, YBOTTOM ' global variables to hold active values DIM INTEGER xvalues(NSAMPLES-1),yvalues(NSAMPLES-1)' arrays to hold raw sample values pin(t_CS)=1 setpin t_irq,din setpin t_cs,dout CONST default_rotation=0 'default screen orientation for this display type, in this case portrait const screen_width=240 'width of display in use const screen_height=320 'height of display in use dim integer width=screen_width, height=screen_height 'set active values based on default orientation ' 0=portrait, 1=portrait inverted, 2=landscale, 3=landscape inverted DIM integer XSAMPLE0=&H90 'parameters to hold XPT commands, these may be reversed by the calibration routine 'for a particular application these values can be saved and set as constants DIM integer YSAMPLE0=&HD0 DIM INTEGER XSAMPLE, YSAMPLE ' dim integer x,y 'main program variables ' spi open 1000000,3,8 ' pause 1000 T.calibrate 'calibrate the touch sensor xleft=xleft0: xright=xright0 : ytop=ytop0 : ybottom=ybottom0 ' set the parameters for the default orientation 'for a particular application these values can be saved and set as constants main: if t.screenpos(x,y,1000) then if x>3 and x<width-3 and y>3 and y<height-3 then circle x,y,3 endif goto main sub T.rotate(r as integer) local integer temp rotate r 'set the screen rotation if default_rotation\2=r\2 then XSAMPLE=XSAMPLE0 YSAMPLE=YSAMPLE0 width=screen_width height=screen_height if r=default_rotation then xleft=xleft0: xright=xright0 : ytop=ytop0 : ybottom=ybottom0 else xleft=xright0: xright=xleft0 : ytop=ybottom0 : ybottom=ytop0 endif else XSAMPLE=YSAMPLE0 YSAMPLE=XSAMPLE0 width=screen_height height=screen_width if ((r mod 2) = (default_rotation mod 2)) then if default_rotation=2 then xleft=ybottom0 xright=ytop0 ytop=xleft0 ybottom=xright0 else xleft=ytop0 xright=ybottom0 ytop=xright0 ybottom=xleft0 endif else if default_rotation=0 then xleft=ybottom0 xright=ytop0 ytop=xleft0 ybottom=xright0 else xleft=ytop0 xright=ybottom0 ytop=xright0 ybottom=xleft0 endif endif endif end sub ' sub T.calibrate 'gets the orientation correct and then sets global variables XLEFT0, XRIGHT0, YTOP0, YBOTTOM0 LOCAL integer x,y,refsize=(height+width)/100, refoffset=refsize\2, charsize=refsize\3 print "" XSAMPLE=XSAMPLE0 YSAMPLE=YSAMPLE0 if (refsize mod 2) then refsize=refsize+1 if charsize=0 then charsize=1 SWITCHXY: box 0,height\2-refoffset,refsize,refsize text width\2-charsize*4*6,height\2-charsize*4,"Touch box" print "Touch left edge in centre" T.gettouch(xleft0,y) if xleft0>500 and xleft0<1500 then 'Switching orientation XSAMPLE0=&HD0:XSAMPLE=XSAMPLE0 YSAMPLE0=&H90:YSAMPLE=YSAMPLE0 GOTO SWITCHXY endif PRINT "XSAMPLE0=",hex$(XSAMPLE0) PRINT "YSAMPLE0=",HEX$(YSAMPLE0) print "XLEFT0=",xleft0 cls : pause 1000 box width-refsize,height\2-refoffset,refsize,refsize text width\2-charsize*4*6,height\2-charsize*4,"Touch box" print "Touch right edge in centre" T.gettouch(xright0,y) print "XRIGHT0=",xright0 cls : pause 1000 box width\2-refoffset,0,refsize,refsize text width\2-charsize*4*6,height\2-charsize*4,"Touch box" print "Touch top edge in centre" T.gettouch(x,ytop0) print "YTOP0=",ytop0 cls : pause 1000 box width\2-refoffset,height-refsize,refsize,refsize text width\2-charsize*4*6,height\2-charsize*4,"Touch box" print "Touch bottom edge in centre" T.gettouch(x,ybottom0) print "YBOTTOM0=",ybottom0 cls : pause 1000 end sub ' function T.screenpos(x as integer, y as integer, timeout as integer) as integer local integer j IF T.getxy(xvalues(),yvalues(),timeout,NSAMPLES)<>0 then ' j=shellsortARM(xvalues(),NSAMPLES) 'uncomment to use sort as required j=shellsortMX(xvalues(),NSAMPLES) 'uncomment to use sort as required ' j=shellsortARM(yvalues(),NSAMPLES) 'uncomment to use sort as required j=shellsortMX(yvalues(),NSAMPLES) 'uncomment to use sort as required x=xvalues(NSAMPLES\2) 'get the median value y=yvalues(NSAMPLES\2) 'get the median value if xleft>xright then 'x coordinates reversed if x<xright then x=xright if x>xleft then x=xleft x=width-((x-xright)*width/(xleft-xright)) else 'x coordinates normal if x<xleft then x=xleft if x>xright then x=xright x=(x-xleft)*width/(xright-xleft) endif if ytop>ybottom then ' y coordinates reversed if y>ytop then y=ytop if y<ybottom then y=ybottom y=height-((y-ybottom)*height/(ytop-ybottom)) else 'y coordinates normal if y<ytop then y=ytop if y>ybottom then y=ybottom y=(y-ytop)*height/(ybottom-ytop) endif T.screenpos=1 else T.screenpos=0 endif end function sub T.gettouch(x as integer, y as integer) local integer j, n=51,xvalues(n-1),yvalues(n-1) loophere: x=-500 IF T.getxy(xvalues(),yvalues(),1000,n)<>0 then j=shellsortMX(xvalues(),n) 'change to use sort as required j=shellsortMX(yvalues(),n) 'change to use sort as required x=xvalues(n\2) 'get the median value y=yvalues(n\2) 'get the median value endif if x=-500 then goto loophere end sub ' function T.Getdata(command as integer) as integer 'get data from the touch controller local integer i,j,k pin(T_CS)=0 i=spi(command) j=spi(0) k=spi(0) pin(T_CS)=1 T.Getdata= (j*256+k)>>4 end function ' function T.getxy(x() as integer, y() as integer, timeout as integer, samples as integer) as integer local integer i timer=0 T.getxy=1 for i=0 to samples-1 do while timer<timeout and pin(T_IRQ)=1:loop if timer>=timeout then T.getxy=0 else y(i)=T.getdata(YSAMPLE) x(i)=T.getdata(XSAMPLE) endif next i end function ' CFunction shellsortMX 00000000 8ca20000 27bdfff8 afb10004 afb00000 00401821 00032fc2 00a31821 00031843 5060003d 00001021 0062282a 10a0fffa 00032fc2 00036823 000370c0 000d60c0 008e7021 0080c021 008c8021 00607821 0000c821 01e3282a 01c03021 8dd10000 14a0001e 8dcb0004 8f070004 03202821 0167402a 11000034 8f090000 01e04021 000840c0 00884021 00a3502a 02003021 ad090000 1540000f ad070004 8cc70004 8cc90000 0167402a 00ad5021 1100001f 00cc3021 00a04021 01402821 000840c0 00884021 00a3502a ad090000 1140fff3 ad070004 000528c0 00853021 25ef0001 01e2282a acd10000 accb0004 27390001 25ce0008 27180008 14a0ffd6 26100008 00032fc2 00a31821 00031843 1460ffc7 0062282a 00001021 00001821 8fb10004 8fb00000 03e00008 27bd0008 14ebffe9 0229402b 5100ffe8 000528c0 00a04021 1000ffde 01402821 54ebffe5 25ef0001 0229402b 5500ffca 01e04021 1000ffe0 25ef0001 End CFunction |
