Local Time 15:58 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite climbs to 25,777m
edu001
Posted: 04:10am 06 Oct 2014
EDUPIC1 High Altitude Balloon tracker first successful flight completed
44 pin Micromite Lite from micromite.org
uBlox Max8 GPS module
Radiometrix RF Transmitter
DS18b20 Temp sensor
Single 1.5v AAA Lithium Energiser Battery
The DATA is compiled into a string and transmitted in RTTY over RF in the following format
$$EDUPIC1,941,12:59:55,5141.98759,00133.86900,09,18493.3,0,- 31.5,1.3*C538
$$payload,count,time,lat,long,sats,alt,flightmode,temp,batte ry volts,crc
Suspended on a small helium balloon it reached an altitude of 25,777m and a temperature of well below -30 degrees
Another flight is planned in the near future to an altitude of 36,000m +
Thanks to the WhiteWizzard for his invaluable assistance with coding :)
Edited by edu001 2014-10-07
plasma
Posted: 04:46am 06 Oct 2014
Yea , i like this idea !
viscomjim
Posted: 05:00am 06 Oct 2014
This is very cool. Even cooler would be more details on your interfaces and maybe code so we can learn from your great project. How exactly do you recover this and how long a trip (time wise) is this? Are you logging the data into the uMite and how much data (how many samples over how much time?). I bet this is the furthest away from earth a uMite has ever traveled.... unless air shipping to US the plane probably goes higher, but the uMite isn't running...
Great Job!!!!
Edit...
How did you mange to use one 1.5v battery, boost converter???Edited by viscomjim 2014-10-07
edu001
Posted: 05:11am 06 Oct 2014
I will post more detail later today
Here is the received DATA over time for 1 flight
2014-10-06_151046_EDUPIC1_Example.zip
edu001
Posted: 05:33am 06 Oct 2014
  viscomjim said   This is very cool. Even cooler would be more details on your interfaces and maybe code so we can learn from your great project. How exactly do you recover this and how long a trip (time wise) is this? Are you logging the data into the uMite and how much data (how many samples over how much time?). I bet this is the furthest away from earth a uMite has ever traveled.... unless air shipping to US the plane probably goes higher, but the uMite isn't running...
Great Job!!!!
Edit...
Yes just a 1.5v to 3.3v stepup
atmega8
Posted: 06:00am 06 Oct 2014
Great Job!!!!
Edit...
He talked about > 25.000 meter, not feet ;-)
mindrobots
Posted: 08:06am 06 Oct 2014
Wow!
84,570 FEET - for those of us State side that don't talk meters!
That's 16 miles up in the air!
Great project, thanks for sharing!
viscomjim
Posted: 08:43am 06 Oct 2014
Holy Cow that awesome. Looks like 6.5 hours flight time? Which radiometrix transmitter gave you that range on small powersupply and what did you use for a receiver? Also, do you need any kind of agency clearance to let a balloon go like that?
I looked at your flight information zip file. How do the lat and long numbers work? I tried to google the numbers but had no luck.
super impressive!!!!!Edited by viscomjim 2014-10-07
edu001
Posted: 09:03am 06 Oct 2014
Some more details on the tracker
The setup is
ublox GPS connected to COM2
Radiometrix MTX2 transmitter connected to COM1
I read the correct NMEA sentence from the GPS filter out the unwanted fields/sentences and compile it into a string which is sent to the MTX2 for transmission on 434Mhz a 10mw signal can be received over hundreds of kilometers
There are quite a few receiving stations all over europe we decode the RTTY using fldigi software and send the data over the net to Spacenear.us check it out it will all make sense
The balloons are quite small this one is a foil
Launched on Saturday it covered 822km at 7000m ill post the details on that flight as soon as I have the data
atmega8
Posted: 09:18am 06 Oct 2014
Wow,
is this within the restrictions of the "law" ?
Do you need a start "permition" ?
Posted: 09:33am 06 Oct 2014
  viscomjim said   ...Which radiometrix transmitter gave you that range on small power supply...
Having worked with Jed on this project; mainly power saving techniques and a complex CRC code module I am in a position to elaborate on the above and how we maximised the battery life.
The 'set-up' comprises of a 44-pin MicroMite module plugged into an expansion board; the layout of which Jed takes full credit. On this stackable expansion board is a high quality GPS receiver, a high quality RadioMetrix Radio Transmitter, a standard PCF8563 Real Time Clock, and a very efficient StepUp booster.
High level operation is as follows. The MicroMite is normally in 'Sleep' mode. Periodically the RTC will wake the MicroMite which then immediately wakes the GPS module. The current GPS location is read along with some other data. The GPS is then put to sleep and the Radio Tx woken. A string of data based upon GPS co-ordinates, GPS altitude, and GPS Time is compiled and then transmitted at 50baud via the Radio Tx. The Radio is then put to sleep along with the MicroMite; ready for the next 'WakeUp'. During the time the MicroMite is awake, it is set to the appropriate CPU speed depending on the function it is performing - all in a bid to minimise average current drain.
The GPS has a typical current draw of upto 20mA while 'awake', and a similar current draw for the Radio module while transmitting.
On a wakeup every minute, the overall battery-life is a matter of days - remembering we can parallel batteries to provide longer flight times (but obviously at increased payload weight).
This project has been very interesting to work on and hats off to Jed for an excellent combination of hardware to achieve something very impressive.
I look forward to Jed's posts as I know he has many more stories to tell you all regarding his 'flights'.
As this is Jed's 'baby' I will let him keep you all informed with updates and will only chime in when I feel necessary!
For those really interested, we will be making the hardware available to everyone very soon so that you can begin to fly your own balloons . . . .
edu001
Posted: 10:53am 06 Oct 2014
  atmega8 said   Wow,
Of course! 434Mhz on 10mw is Licence Exempt and provided that you stay within 2 meter size limit at any point during the flight including the payload, you do not require a NOTAM
From CAA doc CAP393
Section 1 Part 32 Page 3
Exceptions from application of provisions of the Order for certain classes of aircraft
253 (1) This article applies to:
(a) any small balloon;
(b) any kite weighing not more than two kg;
(c) any small unmanned aircraft; and
(d) any parachute including a parascending parachute.
Section 1 Part 33 Page 16
'Small balloon' means a balloon of not more than two metres in any linear dimension
at any stage of its flight, including any basket or other equipment attached to the
balloon;
edu001
Posted: 11:04am 06 Oct 2014
  viscomjim said   Holy Cow that awesome. Looks like 6.5 hours flight time? Which radiometrix transmitter gave you that range on small powersupply and what did you use for a receiver? Also, do you need any kind of agency clearance to let a balloon go like that?
That is what I read from the uBlox (google DDMM.MMMM) GPS then I do some calculations to get Decimal Degrees
The flight we just did lasted 12 hours+ then went out of range it had about 40 hours battery life
Posted: 01:04pm 06 Oct 2014
Very impressive - well done.
I guess you found a place where you were well out of the commercial flight-paths!
You're up with the jet engines at that altitude.
I'm very surprised that the regs DON'T restrict you in that area - sucking your project into an airliner engine would not make you any friends at ATC(air traffic control) - quite the opposite.
I was also very impressed with the -30 degree temperature. At that altitude, it is very cold, as you know, but I would have thought that that kind of cold may have caused the unit to fail - but it didn't - impressive test of the hardware too.
Keep up the great work, and please do post back with any new projects etc.Edited by Grogster 2014-10-07
G8JCF
Posted: 01:31pm 06 Oct 2014
Totally Awesome/Incredible/Fantastic/Impressive
The only Konstant is Change
Posted: 04:25pm 06 Oct 2014
There are a lot of balloon flights in Australia. Most start from South Australia and head east.
Tasmania (where I am) is too small, we would end up sending all the gear to New Zealand and have to ask Grogster to post it back.
Most GPS units stop working at high altitude so you have to choose units carefully.
paceman
Posted: 06:58pm 06 Oct 2014
  Grogster said  I guess you found a place where you were well out of the commercial flight-paths!
Up with the rocket or scramjet engines more like it. 27,555m is close enough to 85,000ft - Wow! Commercial jets cruise at around 32-35,000ft. I think the record for a 'jet' is held by the US "Blackbird" SR71 spy-plane and as I remember it's in the 70,000's, not the 80,000ft range.
That temperature actually seems a little high for that altitude. The outside air temp that you see on the screens in the cabins of planes are often in the low -50 degree area - I assume oC. I read somewhere that temperature actually starts increasing again when you get high enough - are we up in that range?
Greg
edu001
Posted: 08:25pm 06 Oct 2014
Greg
There seems to be a cold layer at lower altitudes, this graph shows how cold it can get I tracked it to -61 but the data was erratic but the Micromite was still running I think the battery froze :)
Data file 2014-10-07_062522_cold.csv.zip
Posted: 08:44pm 06 Oct 2014
Good point Grogs: My office is on the final approach to Heathrow (planes at 1,500ft (500m) altitude). Best I don't launch from there
Seriously though, a little foil balloon carrying a MicroMite + expansion board would be no threat to a plane - it would simply be blown off course a bit (the balloon I mean, NOT the plane!)
WW
paceman
Posted: 09:39pm 06 Oct 2014
OK, I checked temperature out.
edu001's (Jed?) balloon got to got to 25,777m which is pretty much fair in the middle of the stratosphere (12-50km altitude). Temperature does indeed start going up again when you get up to about a third of the way into the stratosphere - up till then it's been around -60C from about 12km altitude. It keeps increasing till it hits 0 deg C at the top of the stratosphere - about 50km up, so the -35oC reading he's getting at 25,777m is probably pretty close to the mark! The battery operating through these temps (to say nothing of the poor little MicroMite and the other bits) is pretty surprising. It'd be interesting to see what the battery voltage was doing through all this!
This gives a good rundown:
Atmosphere temp etc
Greg
EDIT: well I didn't need to look far, the voltage was in the log Jed gave us to download (I didn't open it till after the post). Doesn't look like the -60oC area affected it a lot at all.
EDIT 2: Err... correction again; that temp log only went to 12,000m, about where jets fly, and showed 1.0 volts with air temperature at -51oC. How low can the voltage go before the supply 'carks' it?Edited by paceman 2014-10-08
