Forum Index : Microcontroller and PC projects : Want very very cheap prebuilt micro board
What's the cheapest board anyone knows? Needs to be commercially available, don't need many I/Os or a fast CPU. Price is to include the essential parts (CPU, xtal, PCB, etc) and pre-built. Let's say that even the Olimex PIC32-Pinguino-MX220 at 9.95 euro (about $12 or £8) is too expensive, so what's cheaper? John |
muddy0409![]() Senior Member Joined: 15/06/2011 Location: AustraliaPosts: 125 |
Boy, you're a bit hopeful aren't you?? Don't poo poo conspiracy theories. Remember that everything ever discovered started somewhere as a theory. |
If you need it only as a reference and you still need to specify the microcontroller... If is an 18F, see here: jaluino bee The cheapest one is the one you make yourself if you have already the required parts. Otherwise, you can buy only the pcb from seeedstudio. Hobbit name: Togo Toadfoot of Frogmorton Elvish name: Mablung Miriel Beyound Arduino Lang |
| DuinoMiteMegaAn Senior Member Joined: 17/11/2011 Location: AustraliaPosts: 231 |
DIY "Do it yourself" PINGUINO32 Only when the Pinguino team completes everything for this board.
BTW ... Lets not forget about the PICAXE and the Basic Micro Nano 8. Dirt cheap 8 bangers. |
I'd suggest a "smart card" , using a smallish pic (I think). Futurlec have one at ca $1.30.(?) $12 each ? There would have to be many, many sold for any worthwhile return. |
| djuqa Guru Joined: 23/11/2011 Location: AustraliaPosts: 447 |
AVR AtMega48 Dev. Board $12 on ebay posted to AussieLand VK4MU MicroController Units |
I think this is a good choice http://www.sparkfun.com/products/10807 Right now, www.picaxe.com is down but there is a good source - is in your country and it can be cheaper... Otherwise, you need first a programmer for your microcontroller of choice. With help from friends from this forum I started with a picaxe08m, then I continued with a pic12f675, a serial programmer made with 2 transistors and Jal language. Destroyed 2 other microcontrollers and started saving for a pickit2 programmer - it was the best decision but not the best selection of the online market - got it three times expensive than usual on Romanian market. Atmel have great microcontrolers but not for beginners - is too expensive to start with (including failures caused by wrong fuse configuration). Hobbit name: Togo Toadfoot of Frogmorton Elvish name: Mablung Miriel Beyound Arduino Lang |
So that's a couple at $12 (£8) pre-built. Lower? I had no luck finding anything lower from Futurlec, so don't think they do unless I missed it. Please, only pre-built complete (i.e. populated with CPU, xtal etc) boards. DIY is out. John |
The best and lowest cost microcontroller development board with debugging (emulator) is by far the TI MSP430G value line LaunchPad Development Kit for $5.00 USD. BTW... JohnS - Google works for me
crackerjack![]() Senior Member Joined: 11/07/2011 Location: AustraliaPosts: 164 |
I second the TI Launchpad option at $4.30 delivered (worldwide) - each Launchpad comes with 2 x 16-bit microcontrollers, a USB cable, free download of software, and emulation built in. You can hardly go wrong. I have a batch of them at home and even if I just use them as LED flashers, it's still about as cheap as buying and hooking up a 555 and a couple of LED's. They are ultra-low power devices so really useful for battery powered applications. Coding for them in C is a little tricky - only because they have a squillion peripherals that need setting up in an arcane kind of way, but there is a free software tool called GRACE from TI that helps with that part. I can't recommend the TI deal highly enough... but of course the old YMMV disclaimer applies and also, I have no affiliation with TI whatsoever. |
Ti launchpad is out of Stock "Please contact us for an estimated ship date." on ti.com VK4MU MicroController Units |
Thanks. I didn't know about that cheap MSP430 board. DuinoMiteMegaAn - I googled endlessly but most people seem to think very cheap is $99 or $49. What search terms did you use? I also found (clones of) the USBASP but anyone know whether they can be reprogrammed? There used to be a $3 PIC10F... board but seems no longer. John |
According to this, there is an Arduino like IDE but you need to have bigger micros than the ones provided in launchpad. Somehow, is a worthy investment for both educational and pro. areas. Gettig Started Hobbit name: Togo Toadfoot of Frogmorton Elvish name: Mablung Miriel Beyound Arduino Lang |
Try this "world's lowest cost microcontroller board" This will point to TI and indirectly to the LaunchPad on TI web page.
The LaunchPad is 16 bit with a full development system. It can't be beat anywhere at any price. Like CrackerJack, I also own "5 boxes" of LaunchPads in my lab.
BTW ... In the LauchPad kit they give to two microcontrollers. Subtract the price of one microcontroller and the price drops to $2.00 USD <---- unbelievable Get this ******* 1.58 euro.******* Better stock up. |
elproducts![]() Senior Member Joined: 19/06/2011 Location: United StatesPosts: 282 |
Vasi, I don't know how you find this stuff. Thanks for sharing. I didnt even know this existed. www.elproducts.com |
You do realise it is HEAVILY subsidised at that price.
Absolutely, but it really doesn't matter - that's why I got five LauchPad boxes. Once you got the board (emulator) then thats all you need. TI has been "heavily" subsidizing, this LaunchPad product for the last two years and they are NOT going out of business. They have deep pockets. |
There are the CHIPAXE boards at Howtronics.com . 8-pin to 28-pin. Use internal oscillator. Plug directly into PICkit 2. www.elproducts.com |
Still can't beat the 16 bit MSP430G LaunchPad for "about" $5.00 USD |
5 - No wonder they are out of stock VK4MU MicroController Units |
